Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 03-28-2003, 07:27 PM   #1
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
Question Will the STi driveline be less lossy?
A 227 HP WRX dynos at about 165. Would a 227 WRX with DCCD, mechanical rear LSD, and front viscous LSD dyno higher, lower, or about the same?
I'm hoping the DCCD and mechanical rear LSD are less lossy than the two viscous couplings the WRX currently has. Certainly the front viscous LSD will be more lossy than an open differential, but the benifits will easily outweigh the costs
If the DCCD could send 100% of the power to the rear (even though we know it can only do 65%) wheels, then there should be much less loss than a 50/50 split. So, maybe when cruising in the STi and not drifting around corners, the DCCD will put more power to the rear to reduce driveline losses
This could make the STi better than the WRX "from a roll" all else (power and gearing) being equal.
Corn-Picker is offline
Old 03-28-2003, 09:40 PM   #2
WRSport
Member#: 2060
00 2.5RS Coupe
01 black boxster hardtop
Very good question. My unfounded guess is the overall "losses" will be about the same or less given the inherent sophistication of the STI drivetrain, even with the additional diff up front.
WRSport is offline
Old 03-29-2003, 12:30 AM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
> front viscous LSD
It is not, it is a Suretrac.
As far as losses go, certainly the planetary center diff of the DCCD one would think is less lossy than a VC.
Also, the 6MT layshaft and mainshaft are 10mm further apart than the 5MT meaning the gears are slightly larger diameter (overall) - whether that affects friction, I am not sure. Given the 6MT is a newer design I'd assume that it is no worse than the 5MT.
My vote: probably no worse, don't know how much better.
PS not in the driveline, but there are other friction "optimizations/reductions" in the STi. I saw that on the Japanese Subaru website somewhere.
ANZAC_1915 is offline
Old 03-29-2003, 09:14 AM   #4
Corn-Picker
Member#: 8679
2010 The most hated
Originally posted by Glenn Wallace
> front viscous LSD
I've been looking for more information on the differential. Looks like it's still a viscous differential, but it's a "ratcheting cone" type differential. Supposedly it's better for uneven surfaces because it transfers torque more quickly. Also it supposedly makes turning easier than a "standard" LSD.
Hopefully we do have a less lossy driveline than a standard WRX
Old 03-29-2003, 11:05 AM   #5
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Most limited slip differentials rely on the viscocity of something (e.g. the diff fluid) --- when you typed "viscous" I assumed you meant "sealed viscous coupling".
My understanding is that the AP Suretrac is a torque biasing/sensitive differential.
edit: Having a look through some "other" documentation I have, it is definitely not sealed. It requires GL-5 for the entire front diff assy, and it appears to be open to the diff fluid.
Glenn
Old 03-30-2003, 03:31 AM   #6
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
This page shows part of a line drawing of the Suretrac diff (no text, but trust me that is the front diff):
http://www.subaru-global.com/lineup/...uspension.html
Will the STi ever be on the Subaru.ca site ??? Extraze Canada Region Forum 0 07-05-2003 05:02 PM
when will the sti be at the dealers imprezach STi Forum Archive 6 04-21-2003 08:27 PM
Will The STi Have Problems Being A First Year Model??? xfactor834 STi Forum Archive 9 01-14-2003 04:51 PM
Will the STi tranny be able to handle up to 400 hp or hold better than the five speed acss Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-07-2002 11:24 PM
When will the STI be realesed in America??? fatrash News & Rumors 5 02-18-2002 02:30 PM
