Old 03-28-2003, 07:24 PM   #1
Kazushi
Member#: 30550
02 2.5RS
platinum silver
Default valve adjustment - now CEL
hey
had cobb street cams installed 6000km ago and no problems. Had my valve lash done, and a week later i have a CEL. I can't help but think the CEL is related ...
any ideas?
I'm gonna reset it in the morning and see if the CEL comes back just for kicks.
Kazushi is offline   Reply With Quote
Old 03-28-2003, 11:14 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
How about getting the code pulled for kicks, so you know what caused it ? It could well be completely unrelated to the Cobb cams and/or valve lash adjustment- you won't know if you simply clear it.
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
http://www.deniedmywarranty.org
Old 03-29-2003, 07:59 AM   #3
Kazushi
Member#: 30550
02 2.5RS
platinum silver
Maybe i'm in denial, but i figure if I clear the CEL and it doesn't come back it wasn't something to get too worried about in the first place...
I'm in Ottawa, not to sure where i can go to get CEL's pulled on the weekend anyways.
Old 03-29-2003, 12:46 PM   #4
codger
Member#: 13486
06 Legacy GT wagon
It's worth phoning around a bit. You may have an Autovalue store in Ottawa. They pulled my code for free, and I ended up buying my own code reader from them. Check your Yellow Pages, probably under "Automobile" or "Automotive Parts". Probably best to just leave the orange light on until you can see what code it is.
How do you like the cams?
Jim
codger is offline   Reply With Quote
Old 03-29-2003, 01:14 PM   #5
Kazushi
Member#: 30550
02 2.5RS
platinum silver
the cams are good and do what they are advertised to do, they are expensive though.
I reset the ecu and cel is gone, i'll get the code pulled for sure if it comes back. How much was the OBD scanner?
Old 03-30-2003, 04:06 AM   #6
codger
Member#: 13486
06 Legacy GT wagon
They had an Equus Innova 3100 instock for $245CDN. Instead I ordered the AutoXray 10155 for $276 CDN. It should arrive in about 2 weeks. Just got another CEL though, probably the P-0420 from my Brullen header again.
Jim
Old 03-30-2003, 12:10 PM   #7
Kazushi
Member#: 30550
02 2.5RS
platinum silver
I thought brullen had a CEL fix? Cobb sells some sort of header CEL fix too.
Old 03-30-2003, 03:15 PM   #8
imprezive
Member#: 746
I have the same problem and I got the codes pulled. It is a misfire in all cylinders. I only happens at cold starts though. a couple people have said that the adjustment may be to "loose" due to settling. I'm about to have them re-adjusted, so I'll let everyone know if that helps
imprezive is offline   Reply With Quote
valve tick or valve adjust? ali dashty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-06-2008 06:15 PM
Should valves be adjusted now? ulei eagle Service & Maintenance 0 07-19-2006 02:09 PM
Cleaning now that heads are off? And Valve adjust question? yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 4 07-13-2003 05:44 AM
Has anyone done valve adjustments MY99 2.5GT Normally Aspirated Powertrain 2 06-27-2001 05:55 PM
Valve adjustment Pinoy Southern California Impreza Club Forum -- SCIC 0 06-13-2001 10:42 AM
