Old 03-28-2003, 07:31 PM   #1
BADWRX
Member#: 3792
2002 6MT almost GDB
Default -6AN, or -8AN fuel lines, the question at hand.
Getting ready to run SS fuel lines in my engine bay tomorrow. I don't ever want to have to do it again. Should I run -6AN, or -8AN?
I am running it with a SX FPR Vishnu fuel rails.
BADWRX is offline   Reply With Quote
Old 03-28-2003, 08:54 PM   #2
Gerry
Member#: 1829
It all depends on how much HP you are pushing..
I would say -8 for up to 400hp..and -10 anything above that..Gerry
Gerry is offline   Reply With Quote
Old 03-28-2003, 10:45 PM   #3
JustDSM
Member#: 17502
-8 is a little excessive for ~400hp...
JustDSM is offline   Reply With Quote
Old 03-28-2003, 11:28 PM   #4
Gerry
Member#: 1829
How do you figure? If he's going to do it once, why not do it rite the first time...
Old 03-28-2003, 11:29 PM   #5
Bolster
Member#: 22290
2002 WRB WRX Wagon
I'm running -10.....on my oil cooler. I can't imagine -8 for fuel lines, but I'd love to make enough power to require that!
Bolster is offline   Reply With Quote
Old 03-29-2003, 12:16 AM   #6
tifosi77
Guest
Member#: 14110
2002 2002 WRX
Swirly Black
As a general rule I thought that use always used at least -8 lines with fuel applications that is waht we are putting ont the Group N car.
tifosi77 is offline   Reply With Quote
Old 03-29-2003, 11:28 AM   #7
vinster02
Member#: 7888
02 wrx
WR Blue
Go with the -8, I ran -6 under my hood & each time I look at it I wish that I had run The -8. I don't think i would ever need it & when shiv put 43 runs on his dyno we never had a fuel shortage issue. But what the heck "bigger is better" right!?
vinster02 is offline   Reply With Quote
Old 03-29-2003, 05:50 PM   #8
STEALTH-WRX
Member#: 7822
Multi layer snot green
-6 can support up to 500 wheel hp with enough fuel pressure.
STEALTH-WRX is offline   Reply With Quote
Old 03-29-2003, 08:44 PM   #9
Gerry
Member#: 1829
I'll put it to you guys this way...Would you rather have you gas going through a cocktail straw or a 7-11 Super Big Gulp straw? Bigger is always better when comes to fuel..And if there is too much fuel going through it will always go back to the tank..Also the fuel pump won't have to work so hard supplying fuel with bigger lines..
Old 03-29-2003, 08:49 PM   #10
STEALTH-WRX
Member#: 7822
bigger is better in most cases. i would never go bigger than -8 though. i am trying to put -8 lines on my perrin fuel rails but its not going very well. so far i can only fit -6 and then a -8 feed line.
Old 03-29-2003, 09:26 PM   #11
JustDSM
Member#: 17502
I know for a fact that -6 line is capable of 400+wheel hp (432 to be a little more exact). This is with 93 octane pump fuel and 660cc injectors. We could go into the math but I'll let the real world application of the hose in question speak for itself.
Old 03-31-2003, 04:12 PM   #12
BADWRX
Member#: 3792
2002 6MT almost GDB
I went with -8. What a HIGH COST PITA!
Done, and seems to be working well.
$430 for the line/fittings + $300 for the rails + $150 for the FPR later I have a good setup. Whoa, that is a lot of dough!
I am pushing 40PSI static, and my egt's seem so much lower. I still hear a little det with my ECUTEK, but that will be resolved soon.
Those are some big fuel lines! I am happy...but I am also now broke!
Andy
Old 03-31-2003, 04:16 PM   #13
STEALTH-WRX
Member#: 7822
BADWRX. what fuel rails are you running and what injectors.
Old 03-31-2003, 04:20 PM   #14
BADWRX
Member#: 3792
2002 6MT almost GDB
STi(GDB) injectors, Vishnu rails.
To install the Sway Bar or not that is the question. . . last lemming alive Transmission (AT/MT) & Driveline 1 05-14-2010 10:04 PM
Does your wife or girlfriend ever leave the purse at home? mikeythejew Off-Topic 25 04-19-2010 02:57 PM
Update on the issues at hand. DuoMaxwell Subaru Conversions 8 11-13-2005 09:39 AM
To perform the Snorkusectomy or Not...that is the question RacerinLSL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-27-2002 01:54 PM
16G or 20G? That is the question...... wrxman555 General Forum Archive 4 03-25-2001 11:35 AM
