Old 03-28-2003, 08:45 PM   #1
Will98RS
Member#: 15816
1998 Impreza RS
Unhappy urgent help needed
hey.
i installed a rallispec intake and now my car wont start. details: i started the car w/out reseting the ecu could that be the problem? now it starts but stalls
help
will
Will98RS is offline   Reply With Quote
Old 03-28-2003, 08:50 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Did you plug the MAF back in?
Old 03-28-2003, 08:51 PM   #3
Will98RS
Member#: 15816
1998 Impreza RS
yeah i never unplugged it, and i reset the ecu
Old 03-28-2003, 09:14 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
Reseting the ECU or not wouldnt cause the problem. Id take the plug for the maf off and put it back on.
Old 03-29-2003, 06:17 PM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
or make sure the maf is on the correct way.
sidewayz is offline   Reply With Quote
Old 03-30-2003, 01:37 PM   #6
rhdude
Member#: 6637
2009 Acura MDX Sport
hum, '98, I had the same problem at first, I then realized I had bought an intake for a '99 and it did'nt have the correct vacuum line fittings, there was one house coming off the block, or the IAC (I forget which one) that had nothing to connect to... all I did was buy a "T" fitting and pluged it in with the crankcase vent hoses... car started up and ran fine... so yeah, make sure you have ALL the vacuum lines hooked up to something...
rhdude is offline   Reply With Quote
Old 03-30-2003, 03:52 PM   #7
Will98RS
Member#: 15816
1998 Impreza RS
i did a pretty creative (bad) job with the vacuum lines. would that make it stall?
Old 03-30-2003, 10:23 PM   #8
rhdude
Member#: 6637
yes... I'll go take some pics of how I have mine T'd if you want...
Old 03-30-2003, 10:38 PM   #9
rhdude
Member#: 6637
basicly, I have the two vent crankcase hoses T'd, then I have those T'd in with the Idle Air Controller then I have those run into the intake... I have the vent coming off the block going into the intake as well... hit me up on AIM if you need more help...
Old 03-30-2003, 11:06 PM   #10
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I've seens cars smoke like a chimney when the valve cover vent hose was "T"'d to the Idle Air Control, so it seems you are luckier with the crank case venting.
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 03-30-2003, 11:46 PM   #11
rhdude
Member#: 6637
so you are saying I should leave the crankcase vent hoses open and not connect them to anything? (get a small breather filter) ?
Old 03-31-2003, 11:06 PM   #12
ImprezaRS dot com
over boosted again
Member#: 1458
No, just saying that the valve cover vent hose T'd to the IAC will make the motor smoke like an Iraqi Oil Well
Seems like you don't have the same problems T'd into the crank vent...
Old 04-01-2003, 06:39 AM   #13
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
make sue you don't have a foam filter either... i went out to the desert and dirt got through the foam and messed up my MAF
gokou006 is offline   Reply With Quote
Old 04-01-2003, 09:48 AM   #14
Will98RS
Member#: 15816
1998 Impreza RS
i do have a foam filter. i just read someone saying how well designed they thought it was. what gives?
will
Old 04-01-2003, 10:29 PM   #15
ImprezaRS dot com
over boosted again
Member#: 1458
The oiled foam air filter is superior for trapping dirt on a dusty road.
It has more surface area to trap the dirt, and doesn't restrict air as much when dirty. I plan to ditch my K&N style cone filter for an Amsoil foam cone/pod filter soon because on a trip in the mountains to Cripple Creek the K&N style clogged completely and it wouldn't even idle properly at the end of the drive.
Bratmantlz and I sat there and beat out about half a pound of dirt from the filter to get the car to run properly!
Larry
Old 04-01-2003, 11:09 PM   #16
Will98RS
Member#: 15816
1998 Impreza RS
mine doesnt seem very oiled
Old 04-02-2003, 01:56 PM   #17
Will98RS
Member#: 15816
1998 Impreza RS
Unhappy
ok so i tried to fix my car today. no luck. the maf is on the right direction and is plugged in.
on my rallispec catch can there are 3 bungs and i have 4 hoses i think should hook up to them. maybe one of them shouldnt be hooked up.
help
will
Old 04-02-2003, 07:24 PM   #18
ImprezaRS dot com
over boosted again
Member#: 1458
The IAC vacuum hose (from the TB to the intake) MUST be hooked up as the first vacuum line behind (after) the MAF, or the car will not idle. Hook it up after the other vent hoses and you may have a lot of smoke out of the tail pipe.
If you T some other lines together, you can get all 4 connected to the three vacuum nipples, and you'll be okay.
Old 04-02-2003, 08:29 PM   #19
Will98RS
Member#: 15816
1998 Impreza RS
my rallispec doesnt have bungs on the intake just a catch can, what do i do?
Old 04-03-2003, 01:55 PM   #20
Will98RS
Member#: 15816
1998 Impreza RS
ok one more question: in the 2nd picture there is a black hose next to the spark plug wires coming off the throttle body. where does this hose go?
Old 04-03-2003, 03:38 PM   #21
ImprezaRS dot com
over boosted again
Member#: 1458
You will NEED to install a bung right behind the MAF for the IAC vacuum line.
Larry
Old 04-03-2003, 05:25 PM   #22
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
If you have an intake NOT made for a MY98 Impreza, you might have a slight problem. I believe they changed things around between the MY98 and MY99's to have a different layout for the intake.
The 98's had the vacuum hoses and the like spaced down the intake, where the earlier years have them at the airbox. If you have a rallispec intake that is made for the 99 and newer, the bungs probably aren't there.
JC Sports (when they were still around and trying to do work) had an intake tube made up that has all the correct bungs on it for the '98. Here's my install of that tubing on my car. The pictures are out of chronological order, but thank ImageStation for that. And yes, the filter is on backwards in those pictures. I have long since corrected this.
The rest of the parts I got from the nice fellow who posted above me, Larry Ganz. Picked the necessary stuff up from his site, ImprezaRS.com. However, it looks like many of those things might be discontinued at his place, so who knows.
Hope you get this worked out, and you may need to put your stock intake back on while you get this straightened out.
AJ711 is offline   Reply With Quote
Old 04-07-2003, 10:19 AM   #23
Will98RS
Member#: 15816
1998 Impreza RS
ok i'm going to try to make this work. where does the large tube that connects right after the MAF go? also where does the tube that comes off the TB go?
im thinking that i will put on one bung right after the MAF and then use the catchcan.
thanks
will
Old 04-07-2003, 10:35 PM   #24
ImprezaRS dot com
over boosted again
Member#: 1458
use the catch can for the other stuff, and run a line from the IAC at the TB to the intake right behind the MAF adapter.
You could drill a hole in the intake just a little smaller than the IAC vacuum line, and smoosh the vacuum line into the hole.
We get short pipe sections with a 1" vacuum nipple made for us, for our 1998 and older intakes, and could sell you one, with two 3x3" silicone connectors and 4 hose clamps to attach it between your intake and MAF adapter for about $89 + S&H. This is basically our 1998 intake minus the filter, the MAF adpter, a hose clamp and bracket. Obviously it is cheaper to do the first option.
It is only the 1999 and older PRM intakes we discontinued, as well will be selling Cobb intake for the MAF models very soon.
Larry
Old 04-08-2003, 12:59 AM   #25
Will98RS
Member#: 15816
1998 Impreza RS
hey thanks larry, im going to try to get an exhaust shop to put a bung on. if not i will consider buying your set up. ive always heard about your great customer service and you live up to your reputation.
thanks again
will
Urgent! help needed Urgent! iamrazor Legacy Forum 20 01-02-2006 03:43 PM
Urgent Help Needed on Truck Flood ! Im'Pat'za Interior & Exterior Modification 3 04-01-2001 10:23 PM
Urgent help needed with 91 Acura Intake. munkis General Forum Archive 12 01-01-2001 03:37 PM
Urgent Help Needed for Buying Kumhos! VALENTA New England Impreza Club Forum -- NESIC 1 06-11-2000 11:37 PM
Urgent Help Needed about Kuhmo Tires VALENTA General Forum Archive 3 06-11-2000 01:52 PM
