Old 03-29-2003, 03:36 AM   #1
kidatari
Member#: 10441
Default Oil cooler/remote filter mounting locations?
Here's the deal, folks-
I'll eventually be joining the RS-T crowd, but for now I am working on building up everything but the motor for a big power setup. I'm trying to piece together a oil cooler and remote oil filter setup. I'm looking at Setrab oil coolers, and CM (Canton/Mecca) filters, as well as Canton Racing oil filter relocation kit. Paired with all AN fitting and stainless lines, as well as an oilstat, this should do the trick. I tend to over-do things, but it can't hurt.
So, the question is, anyone have a good place to mount a remote oil filter, and an oil cooler? I'm trying to keep the hose runs down the a minimum, and keep everything out of the way and in a safe place from flying debris. Opinions, anyone?
Thanks in advance
-Josh
kidatari is offline   Reply With Quote
Oil Cooler Moved to Top Mount Intercooler Location Special Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-17-2007 06:25 PM
oil cooler and remote filter setup questions hybrid gti 2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-04-2006 09:27 AM
ByPass Oil Filtering System- Mounting Location? IN YOUR MOUTH Service & Maintenance 6 05-25-2003 08:30 PM
Where are my oil cooler and trans cooler located at? Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-28-2002 09:40 AM
oil cooler mounting location newbie sewbie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-09-2002 09:43 PM
