Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 03-29-2003, 04:24 PM   #1
gumby1976
Member#: 26248
2013 Crosstrek
Ice Silver
Default Short ram intake question
I got a OBX sr intake in my rs and realized today the pipe is getting fairly warm and am concern if i might be slowly damaging something, and what can i do to keep the air from getting hot. I don't know what to do it runs next to the engine. Any ideas or suggestions will ge greatly appreciated.
Thanks ahead,
The Boostless Wonder
gumby1976 is offline   Reply With Quote
Old 03-29-2003, 06:28 PM   #2
obyone
Member#: 16523
this anymore???
Try touching the iengine. Feels hot right?...Now you know where the heat is comming from.
BTW...it's normal unless the intake is so hot you can't touch it.
obyone is offline   Reply With Quote
Old 03-29-2003, 06:37 PM   #3
gumby1976
Member#: 26248
2013 Crosstrek
Ice Silver
thanks for the sarcasm and some what of an answer
Old 03-30-2003, 12:16 AM   #4
jeddy
Member#: 7711
2005 WRX STi
There's not a lot you can do to prevent the intake from soaking up heat in the engine bay. The thing is, the stock intake is plastic, so it doesn't soak heat as fast, and doesn't retain it either, so it never feels as hot. However, the air going thru it is probably just as warm.
It's not going to hurt anything if the intake gets hot, if you want to try to keep the intake air cooler, you could wrap the intake in insulation of some kind, but that will only slow the heat soak, so it will eventually reach the same temperature on a long trip.
I use a piece of stainless exhaust pipe for my intake, it gets hot, but hasn't caused any problems in the year and a half i've had it.
jeddy is offline   Reply With Quote
Old 03-30-2003, 02:37 AM   #5
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
It won't damage anything, since it can't get all that hot relative to combustion temperatures. It will just affect your engine's efficiency and power output (but not by all that much). Wrapping it or insulating it would help that. Also, change from a short ram to a cold air intake, which will give you more power.
And the sarcasm was funny man. You have to admit you kinda set yourself up for it...
BAN SUVS is offline   Reply With Quote
Old 04-01-2003, 06:47 AM   #6
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
Default Re: Short ram intake question
Thanks ahead,
you can go to Home Depot and pick up about 2feet or less of that dyer hose stuff and create a ram air tube that starts in the fender behind the turn siganl light next to the fog ilght and go throught the fender and go through the hole in the side of the engine bay next to the air filter.
or you can use what's left of the silencer and turn that into a ram air
and the intake are will get hot... you can't stop the inevitable.
gokou006 is offline   Reply With Quote
Short Ram Intake Question? 2002SUBIE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-13-2007 02:35 PM
short ram intake question ttatsumi Legacy Forum 11 05-09-2006 10:33 PM
Short ram intake question subeforlife2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-01-2006 08:26 PM
Short ram intake question subeforlife2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-19-2006 02:17 AM
short ram intake question dj00crusty Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-02-2005 07:53 PM
