Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 03-30-2003, 03:07 PM   #1
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Default MAF or fuel problems?
My car has a problem that only seems to happen in 1st gear at WOT, but has started to happen at partial throttle, still only in 1st gear. It starts cutting out, as if the fuel was cutting off intermittently. I was thinking this culd be the MAF going bad, but there is no CEL. Another thought is that the fuel system may be dirty. Any thoughts?
Fred Zaplitny is offline   Reply With Quote
Old 03-30-2003, 03:54 PM   #2
Cujo31
Member#: 19843
2000 2.5 RS Sedan
Silverthorn Mettalic
no idea if its even the same thing, but.....
mine did that occasionally, except not even just in 1st... sometimes while cruising at the same speed, such as on the highway, I would feel the RPMs drop, and then recover without me moving the pedal. also, no CEL code
I checked out a bunch of stuff, to no avail, then I pulled the spark plugs and they were pretty eroded down, i.e. huge gap. I also had a split wire inside boot on the number one terminal,
I was surprised that this didn't give a code, but anyway I changed plugs and wires (Beck/Arnley blue match and NGK's) and it seems to have fixed the problem...
Cujo31 is offline   Reply With Quote
Old 04-01-2003, 07:51 AM   #3
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
Default Re: MAF or fuel problems?
darn shotty stock ignition wirers
i had the chance to have a member number under a 100. i got my car 5/11/99. i knew about i-club for the longest time bet never signed up... i was such a fool...
gokou006 is offline   Reply With Quote
Old 04-01-2003, 10:13 AM   #4
Fred Zaplitny
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Actually the problem ended up being a bad intake design of my own doing. The MAF wire has been hitting a valve in the engine compartment when the engine is under heavy load, after a while the insulation of the wire has stripped off so that when the MAF wire hits, the wire shorts. I put it back to stock for now until I can figure out another intake option. BTW, after all that abuse, the MAF is still fine.
Old 04-02-2003, 05:02 PM   #5
Soob
Member#: 7631
1999 Impreza RS 2.5
Black Pearl
Wow.. surprised that the MAF survived after all that punishment. I guess those new MAF's were finally built to last
Soob is offline   Reply With Quote
fuel problem, is it the fuel pump or FPR? Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-24-2012 05:42 PM
FS: 04 STi ecu, 83mm mega maf, stock maf sensor, Fuel line and fittings.... trbowrx Engine/Power/Exhaust 11 02-08-2009 12:55 PM
Bad alternator or fuel problem? Mrhappy Mid Atlantic Impreza Club -- MAIC 11 11-09-2008 03:44 PM
Blowthrough Speed Density via UTEC OR Blowthrough MAF Based fueling via ECU? simon021 UTEC 9 11-07-2008 02:12 PM
better way to reach target afrs: adjust maf scaling or fuel map? nhat Open Source Reflashes 37 06-16-2008 09:07 PM
