Old 03-31-2003, 11:26 AM   #1
Will98RS
Member#: 15816
1998 Impreza RS
Default nonunderdrive lightweight pulley
i dont want to get underdrive pulleys because of my stereo. is there anything else out there besides GFB? recomendations?
will
Will98RS is offline   Reply With Quote
Old 03-31-2003, 12:01 PM   #2
kickin_81
Member#: 16679
2004 Forester XT
I am currently using MrJosh43's lightweight crank pulley. I don't know if he is still selling them. They were $95 for the pulley. Look up "MrJosh43" and send him an email if you're interested. So far, this is the cheapest lightweight crank pulley out there. There is also the Perrin crank pulley that goes for $130 I think. They're both stock size.
kickin_81 is offline   Reply With Quote
Old 03-31-2003, 12:33 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Unorthodox does make a normal sized crank pulley too.
Legacy777 is offline   Reply With Quote
Old 03-31-2003, 02:50 PM   #4
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Also www.imprezars.com has a set of N1/Scoobysport Crank/alt/PS lightweight pulleys for $250 for the set.
DDMan is offline   Reply With Quote
Old 03-31-2003, 03:54 PM   #5
watcher in the sky
Member#: 3513
1997 Legacy Outback
ditto on the Mrjosh pulley. I have it. If you want one that has something written on it, go ahead and spend 40-50 more dollars.. but if you just want a well built pulley that is just as functional as the rest of em.. get the one from Mrjosh.
watcher in the sky is offline   Reply With Quote
Old 03-31-2003, 10:29 PM   #6
imprezey
Member#: 17178
2001 2.5RS Coupe
Silverthorn Metallic
i was thinking about getting a nonunderdrive pulley that was just lightweight. however i want to also get a flywheel. i know you the consensus is to not run both so which one would you guys/gals choose? how about the people who run both, how is it holding up?
imprezey is offline   Reply With Quote
Old 03-31-2003, 11:11 PM   #7
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
Hello stalling!
nitrohuffer is offline   Reply With Quote
Old 04-01-2003, 01:05 AM   #8
obyone
Member#: 16523
But they are hella expensive.
N1 makes a 3 pully set that is completely stock size, just lightened.
obyone is offline   Reply With Quote
Old 04-01-2003, 02:26 AM   #9
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
I have MrJosh's pulley. He gave great customer service and his pulley definitely freed up the advertised 4-8 HP. I definitely recommend it to whoever is interested in a non-underdrive lightened crankshaft pulley.
DrBoy01 is offline   Reply With Quote
Old 04-01-2003, 10:55 AM   #10
Will98RS
Member#: 15816
1998 Impreza RS
i cant find mrjosh. also i figure i will want lighter alt and power steering pulleys right?
will
Old 04-01-2003, 12:07 PM   #11
kickin_81
Member#: 16679
2004 Forester XT
Here's his website: http://tpi.mrjosh43.com/contact.html
The complete pulley set will free you, at most, an extra 1-2 lbs. The crank pulley is teh one that will give you teh most weight loss (from 5lb. to 1lb.). If you just have to get teh complete set, get teh N1 that Larry Ganz is selling. I have heard very good reviews on that set.
From recent posts, a lightened flywheel is better than a set of lightened pullies. For one, it takes off a lot more rotational weight; and second, you'll have teh benefit of teh vibration dampener if using your stock crank pulley. The flywheel comes from teh factory w/o a dampener, so just having that lightened won't harm a thing. Then again, it will cost you a bit to have it installed by a technician.
ps- why are all my 't h e's changed to teh's?
Old 04-01-2003, 03:49 PM   #12
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Lol, I just noticed that, too.
What's this about a Vibration Damper? How would I know if my block was "vibrating"? (no, I'm not speaking in metaphors)
Old 04-01-2003, 04:12 PM   #13
DDMan
Member#: 11221
2002 2.5 RS
Nah...you need to learn about engine harmonics (and no I dont mean teh exhaust note).
As thecrank spins, it creates a vibration. Our cars are pretty much naturally balanced due to the engine design, but for like a V8, teh vibrations can get very bad. They put a giant rubber dampener (which acts as a gyroscope) on teh crank to slow the vibrations and prevent teh crank form moving around (what tiny tiny bit it can) and destroying the bearings. A lightweight pulley removes that dampening and thus allows teh crank to move that tiny bit...and over time will wear some stuff out a little quicker.
But again, our cars engine design is naturally balanced (or teh vibrations are tiny in comparison to a big V8), so teh need for teh dampener is not really tehir. I dont think iv heard of teh crank bearings or seals being destroyed because of a Lightweight crank. I in fact have one and have no problems (had them on for about 10-12k miles).
edit: I think nick is playing a joke on us Cuz I cant seem to spell T H E either!!!
Old 04-07-2003, 12:42 PM   #14
suby01
Member#: 34104
suby AWd
BLUEwhatelse
a quick ? would it be bad to get a underdrive pulley if a got a big
stereo? for my 2.2 any suggestions would help thanks because they just came in the mail and i was suposed to insatll them but now i got questions bout what you said
suby01 is offline   Reply With Quote
Old 04-07-2003, 06:01 PM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Dont get underdriven. Search around but someone did a test with the pulleys REMOVED!!! This should have been greater gains that that of just underdriven. The gain was so small they couldnt tell if it was sampling error or not (read 1-2hp).
On the other hand a lighened crank pulley has been proven to allow the engine to spin up faster. Reliability is still a question but most have decided its worth the risk.
Old 04-07-2003, 07:49 PM   #16
Legacy777
Member#: 4800
I've had my unorthodox underdrive pulley on for about 2 years and 30,000 miles.
It is more of a difference.....especially in the quickness in how the engine revs.
If I had to do it again.....I'd probably just get a lightweight one though.
Old 04-07-2003, 08:30 PM   #17
ciper
Member#: 15543
90BJ Legacy LS ABS
In my excitement I typed that wrong. I meant to say with the belts removed, not pulleys removed
The MR Josh pulley is a hard deal to pass, around 100 shipped is very good for the gain.
Old 04-07-2003, 09:56 PM   #18
silent_rob_95
Member#: 29200
can has more bell
pepper power up
Also you can try the Perrin Crank Pulley. I've had mine with more then 2k miles and no problems so far.
silent_rob_95 is offline   Reply With Quote
Old 04-08-2003, 12:32 AM   #19
98imp
Member#: 32316
98 2.5RS
Blackish...
I too would like hear this as I am looking to get a flywheel and I already have lightweight pullies.
98imp is offline   Reply With Quote
Old 04-09-2003, 12:40 PM   #20
Blindeye_03
Member#: 4418
2016 Focus ST
What dampener??? There is none on the stock crank pulley...
ive had an unorthodox underdrive pulley on my car for over 40k miles and I have had NO problems thus far. *knock on wood* .
-justin
Blindeye_03 is offline   Reply With Quote
Old 04-09-2003, 04:22 PM   #21
Legacy777
Member#: 4800
-justin
Yes there is a damper built into the stock pulley.
If you look very closely on the stock pulley you will see that the pulley is infact a two-piece setup, with a rubber piece sandwiched between the two. This combination/setup acts/is the harmonic damper.
Old 04-09-2003, 05:28 PM   #22
Blindeye_03
Member#: 4418
2016 Focus ST
WEll, when my motor falls apart, Ill let you know...dont count on it though .
The boxer motor is so balanced that a friend of mine that autoxs was going on 3 our of his 4 cyl, because of a bad plug. He noticed that the car was slower than normal, but he couldnt tell that it wasnt firing b/c it felt SOO smooth.
Think what you want... bmws have harmonic dameners and so do v8s and v6s...along with most ofther types of motors.
Honestly, have you ever heard of an underdrive pulley destroying a subaru motor???
-justin
Under pulley VS Lightweight Pulley Siphoyn North West Impreza Club Forum -- NWIC 16 11-10-2008 06:52 PM
Perrin lightweight pulley VS Cobb pulley? Fab's STI Newbies & FAQs 29 09-25-2007 03:15 PM
WTB/WTT: Underdrive Alternator pulley (&belt?) or lightweight pulley trade tooocool49723 Private 'Wanted' Classifieds 1 01-06-2005 06:25 PM
Underdrive Pulleys/Lightweight Pulleys UGotBoost? Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-22-2003 11:32 AM
STi Lightweight Pulleys Piyoscuby Vancouver Impreza Club Forum -- VIC 9 05-03-2001 01:10 AM
