Old 03-31-2003, 08:49 PM   #1
bobsterswrx
Member#: 31555
Default What are your UTEC CLB stg 4 settings?
I am running TXS stg 4 with TMI on closed loop boost. In order to get 17+ psi I need to run my boost at 400 and 3 1/2 turns on the abc. I would like to know what everbody is doing to get these levels of boost. I am in Phoenix and it was 91 deg today so our density altitude is appox 3,500 ft. Is there a big difference in settings? If so, is due to individual factory boost solenoids or utecs? Please share your stats and thoughts.
Bob
bobsterswrx is offline   Reply With Quote
Old 04-01-2003, 04:40 PM   #2
Mad Max 03
Member#: 24852
2003 WRX
My UTEC clb settings to get 18 psi in 4th are 270 tapering down to 250 at redline. I would assume environmental factors have something to do with it. Which turbo are you running? I'm using the VF 34.
Mad Max 03 is offline   Reply With Quote
Old 04-01-2003, 08:24 PM   #3
bobsterswrx
Member#: 31555
I'm running vf 30. Today I decided to follow the directions and just use the clb map # that got the desired result. I used 450 and was able to turn the abc way down to get 18+ psi. It seems that all cars are different. I think that the factory boost solenoids are different and that is the major cause of the differences. I use 3 different maps, the 450 map is for race gas.
Bob
Old 04-01-2003, 10:23 PM   #4
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
For 18psi I'm at around 350-370 range.
MAD REX is offline   Reply With Quote
what are your tokico d-spec settings? ASpec818 Brakes, Steering & Suspension 7 07-30-2006 06:26 PM
All you with PE650's...what are your Utec idle settings? STR8OUT Engine Management & Tuning 55 01-06-2004 03:19 AM
What are most of you guys setting your monkey at? Camperguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-28-2002 12:11 PM
What are your Blitz boost control settings? ScoobieSnaX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-19-2002 02:20 PM
What are your S-AFC settings with Turbo Greg 99 Normally Aspirated Powertrain 2 12-28-2000 06:17 PM
