Old 04-01-2003, 04:27 PM   #1
buraddo
Member#: 27218
1998 Impreza 2.5RS
Default E-manage on 98RS
I've searched and searched, but I have yet to see anyone try it on a 98RS. BOY has it on his 99RS with good luck according to him. I know that there are difference between the 98 and 99 ECUs (according to LINK the 98RS requires a special ECU). It's a wire in system right? So is it just a matter of finding the right wires? I know it won't be that easy, but to make the connections, that it isn't it?
What would be a better option for a 98RS? 6psi turbo in the coming months, nothing now.
buraddo is offline   Reply With Quote
Old 04-01-2003, 10:50 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
well the 98 and 99 RS are much close than say a 98 and a 2000
i don't know of any thing other than the pin out that would be differnt than boy's setup
Old 09-08-2005, 10:33 PM   #3
combatzx2
Member#: 92953
1998 2.5RS w/EJ20G
black
i did it on a 98 rs using a 92 legacy turbo setup, non-intercooled, and never got it tuned right, swapped in and wired for OBD2 a 89-92 ej20 w/ AWIC, i pulled 8 degrees of timing using the greddy pressure sensor as the scale, and pulled 30% of airflow. use the boost limiter cut feature to cap the MAF sensor voltage at about 4.8 volts. i have a tdo5 on the engine and the intercooler is just still water 'cause i don't have the water pump for it (it would be stupid to run it of the engine coolant). i have 440cc injectors and with all that stupid looking setup i run 9 psi all the time and was running 11.7 all last week, running pig rich.
combatzx2 is offline   Reply With Quote
Get A/C to work on 98RS with v3 STI swap? Bakemono-Imports Pre-2002 Factory Turbo Powertrain 8 06-25-2008 05:24 PM
STi cluster swap on 98RS maddhatteroo7 Electrical & Lighting 0 08-10-2007 02:16 PM
Budget Turbo on 98RS Stealth_RS Normally Aspirated with bolt-on Forced Induction Powertrain 21 11-08-2005 08:03 PM
Whose using E-Manage on 2.2 L Turbo GC4 Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-13-2002 11:54 AM
Vacuum Tube on 98RS Intake.... what to do? hacman Normally Aspirated Powertrain 4 02-05-2001 09:37 PM
