Old 04-01-2003, 07:57 PM   #1
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
Default 6 spd conversion on 2002 2.5 RS?
OK, so I've got a 6 spd tranny on the way, and the guy I got it from says that I has all the parts necissary to install it into a USDM WRX. I just want to know what else I'm going to need to get this thing into an RS. I've already ordered the STi rear LSD, axles, and hubs (I'm not even sure I needed all that). Can anyone tell me what else I'm going to need?
Thanks.
PunKidd is offline   Reply With Quote
Old 04-01-2003, 09:02 PM   #2
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
If you are using the STi R180 rear/axles/hubs you will need the brembo brakes also. Don't forget about the driveshaft, either the STi one or an AT WRX one. But not the WRX MT one.
-Jim
mr2guru is offline   Reply With Quote
Old 04-02-2003, 12:02 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I just helped with a 6 speed swap in a wrx. He used stock shafts and did'nt need different brakes.
This swap is a bear, the trans is heavy.
Good luck.
Tim Sanderson is offline   Reply With Quote
Old 04-02-2003, 01:37 PM   #4
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
IF you use a R180 you can't use the stock rear shafts. The diff is wider. So the shafts are shorter. The STi rear shafts don't spline up to our hubs (WRX) STi hubs won't work with our brakes. The front shafts (WRX) fit perfectly with the six speed. You can use a 3.90 R160 out of a turbo legacy. That will work with your stock stuff.
Tim- If your friend used a R180 with the stock rear axles that would be a first that I heard of.
Jim
Old 04-02-2003, 02:38 PM   #5
Kha0S
Member#: 8808
2011 WRX
DGM 5D
You can use the 3.90 rear open diff from a turbo legacy, but the 3.90 rear LSD version from the 1991 cars uses different flanges and axles, as far as I know.
For LSD, you'd need to swap the ring and pinion gears on a stock LSD with the ones from a 3.9 open.
/Andrew
Kha0S is offline   Reply With Quote
Old 04-02-2003, 04:27 PM   #6
PunKidd
Member#: 8533
2002 2.5 RS-T
OK, so I'm using the STi rear LSD, axles, and hubs. Now I have to get STi rear brakes too? Damn. Anything else that will fit on the STi hubs?
Jared.
Old 04-02-2003, 04:38 PM   #7
PunKidd
Member#: 8533
2002 2.5 RS-T
Do I need the discs and calipars or just the calipars?
Also does anyone know for sure if the stock RS front shafts will work w/ the STi tranny or am I going to have to convert the whole front half over to WRX/STi as well?
Just an update of what I've got coming so far:
6spd tranny
shift linkage
cross member
STi hardened tranny mounts
STi propshaft
Rear STi diff, axles, hubs, and brake calipers
STi flywheel and clutch
Still not sure about rear discs and front axles/hubs/brakes.
Old 04-02-2003, 04:57 PM   #8
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
All your front stuff will spline into the 6-speed just fine (if splines are same as WRX). You will also need brake pads for the rear the parking brake pads and associated hardware if the hubs don't come with it and the rotors are different so you will need them too.
Old 04-02-2003, 06:27 PM   #9
PunKidd
Member#: 8533
2002 2.5 RS-T
I think I'll hold off on getting the e-brake untill I find out if I have to install the new rotors.
Isn't it funny how parts for projects like this just keep adding up?
Old 04-02-2003, 08:39 PM   #10
PunKidd
Member#: 8533
2002 2.5 RS-T
Anyone know if the RS has the same splines up front as the WRX?
Old 04-02-2003, 11:02 PM   #11
Kha0S
Member#: 8808
2011 WRX
DGM 5D
You think a 6spd swap is harsh... try doing an AT to MT swap.
/Andrew
Old 04-02-2003, 11:19 PM   #12
PunKidd
Member#: 8533
2002 2.5 RS-T
I could see how that would not be much fun. I bet getting a clutch pedal in there is no easy trick is it.
Old 04-03-2003, 01:46 PM   #13
alex_umn
Member#: 11874
1992 SVX 6MT
Claret
Default Not to toot my own horn...
But how abot an AT to MT swap in a car that never had an MT? Yay SVX
alex_umn is offline   Reply With Quote
Old 04-03-2003, 01:49 PM   #14
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Tim was talking about my swap, I used a R160 rear diff with a 3.90 final drive swap in it.
Phil
Old 04-04-2003, 01:35 AM   #15
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Ya, what he said. He changed the rear diff.
Rear Sway Bar on 2002 2.5 RS OJL Normally Aspirated Powertrain 4 03-18-2003 07:14 PM
Advice on 2002 2.5 RS Setup GlennZippy Normally Aspirated Powertrain 20 12-18-2001 10:49 AM
Sighting: Silver 2002 2.5 RS ~7pm on thursday in la jolla village drive cRayZee Southern California Impreza Club Forum -- SCIC 1 08-19-2001 06:39 PM
ROAD TEST: 2001 2.5 RS VS 2002 2.5 RS WantaSubaru Normally Aspirated Powertrain 4 06-11-2001 10:05 AM
