Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 04-01-2003, 07:59 PM   #1
Farfrumwork
Member#: 10202
'07 Spec B
'85 EJ25 Syncro Westy
Question underhood heat gaurd?
I want to take the backing plate out from under the hood scoop on me '98 Legacy GT come spring - I would also like to remove the heat "pad", as I imagine it has some weight and I would need to pull it anyhow to get the plate out.
any advise? is it alright to keep it out? and what does it do anywho (the pad that is)?
-Chad
Farfrumwork is offline   Reply With Quote
Old 04-01-2003, 11:13 PM   #2
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
It keeps the hood from absorbing all of the heat from the motor. Ever notice on some older cars the paint flaking off on the hood?? Personally I'm leaving mine on since I know Subaru paint is well errrr yeah can't think of a good word for it.
Buster
www.awdcars.com
EvasionOfTruth is offline   Reply With Quote
Old 04-02-2003, 01:52 AM   #3
gokou006
Member#: 8387
99 GM8 EJ20g
86F blue steel mica
Default Re: underhood heat gaurd?
-Chad
Do not remove the heat pad. you'll mess up your hood, plus the wait of the heat pad will not make a difference... if your trying to reduce the weight remove the bumper beams
mark
gokou006 is offline   Reply With Quote
Old 04-02-2003, 10:50 AM   #4
99OBSter
Member#: 14324
1999 OBS 4eat
But definately take off the backing plate off of the hood scoop. You might not have an intercooler under there, but that doesn't mean the scoop won't keep the engine bay cooler.
99OBSter is offline   Reply With Quote
Old 04-02-2003, 03:25 PM   #5
Farfrumwork
Member#: 10202
'07 Spec B
Thanks for the relpies...
I will leave it in - but yes, I am taking out the backing plate. I wasn't looking for a weight reduction, just thought why not if it was ok - but I like my hood, so I'll keep the pad in
An open scoop and the throttle body coolant line disconnect should get me a cooler air charge and thus Mo Powa! haha
I will reconnect the coolant line for winter though
later
-Chad
WTB: wrx underhood heat shield thingy wrxmyers Tri-State Area Private Classifieds 3 01-08-2010 08:29 PM
WTB : underhood stock parts : turbo heat shield and more! Mehdik Private 'Wanted' Classifieds 1 07-15-2009 09:49 PM
High underhood temps after heat wraping exhaust Sausage Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-06-2007 09:03 PM
MISSING: exhaust heat shields/splash guard klie5111 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-17-2005 11:25 PM
Which reduces underhood heat more? rallytuned Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-06-2002 06:08 PM
