Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 04-01-2003, 11:15 PM   #1
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Default Is DCCD teh weakest link now
Does anyone have any info as yet on how much HP teh DCCD can handle.
I searched in Australia and UK forums. The Aussie discussion gets muddled and teh UK doesn't state what HP it can handle.
http://www.mrtrally.com.au/forums/to...?TOPIC_ID=5426
http://www.scoobynet.co.uk/bbs/threa...hreadid=143750
I've also read this post. Most are just guessing HP.
http://forums.nasioc.com/forums/show...D&pagenumber=1
Wombat North is offline
Old 04-02-2003, 12:39 AM   #2
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Any comments about the old DCCD don't apply to the new system. It has a heavy duty planetary gear controlled by some pretty smart gizmos.
Basically look at a diagram of the front bit of a VTD auto gearbox.
It is essentially the same (with a manual mode, a knob and of course a different control system).
Of course there is an upper limit with it but it is probably well beyond the limits of the current WRX bits (5MT, driveshafts etc).
Glenn
ANZAC_1915 is offline
Old 04-02-2003, 03:46 AM   #3
P2x
Member#: 6016
MY05 Toyota Prius
Considering that previously DCCD has only been released in the more highly specced STi's out there (JDM & RA versions), I'd say logic would dictate that it won't be a terribly weak link.. ?
P2x is offline
Old 04-02-2003, 06:51 AM   #4
deadbolt
Member#: 990
96 Brighton and...
many
As far as I know, even though they redesigned the axles, they are still the weak link.
deadbolt is offline
Old 04-02-2003, 09:27 AM   #5
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
On the axles, it depends what you mean: torque or rotational speed?
Both front and rear axles are increased dia, the wheel bearings are increased dia, the CV's are bigger, the driveshaft has bigger U/J's etc. You get the idea.
I'd say at this stage the tires are the weakest link , perhaps followed by the clutch, and even then you probably wouldn't blow it, just wear it quickly.
I have heard stories of 6500 RPM clutch drops.... though it is fitted with the delay valve.
The old DCCD was essentially a magnetic clutch --- it is a lot more sophisticated now. Really, find pictures of the VTD gearbox from the Outback or WRX and you will see how "built" it is.
Glenn
Old 04-07-2003, 07:47 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Is the DCCD always in manual mode? Or can you let it be and it will decide on setting like the automatic transmission?
(I searched and this was the thread I found)
ciper is offline
Old 04-07-2003, 08:02 PM   #7
dlowman
Member#: 22998
2004 WRX STi
GT35R 572 whp 93/meth
It stays in auto mode until you make it manual.
dlowman is offline
Old 04-07-2003, 10:34 PM   #8
ciper
Member#: 15543
90BJ Legacy LS ABS
Thats exactly what I was asking for. Thanks!
ciper is offline
Old 04-09-2003, 05:14 PM   #9
akoshy
Member#: 20931
09 Subaru
Talking
In other words, the DCCD is the strongest link in the STi with additional points like the 2.5L turbo and the 6-speed just icing on the cake.
I would really love to go for the STi, even taking a hit on my current WRX, just for the DCCD.
akoshy is offline
Weakest link of the Subaru suspension? (02-03 RS/WRX) HolyCrikey Brakes, Steering & Suspension 12 07-07-2005 02:23 PM
What is our weakest link? XLR8 out the turn Normally Aspirated Powertrain 6 07-17-2004 12:43 AM
What is my weakest link (boost wise) Unsung Boxer Normally Aspirated with bolt-on Forced Induction Powertrain 16 12-10-2003 11:35 AM
Weakest Link custus General Community 1 12-01-2003 12:26 PM
STi's weakest link MethodX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 10-23-2003 04:11 PM
