Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 04-02-2003, 10:17 AM   #1
GregUnd
Baaleted
Member#: 11800
Default I think I've got some fuel problems or ECU is screwed up. Maybe a bad sensor too(MAF)
Ok. Ever since the night we meet at Nick's Place last I've been having some problems under WOT.
1. The car runs good WOT all the way up until 4000RPM. Between 4K and 5K RPM it feels almost as like you were putting 0 psi of boost, relativley speaking. Then when it hits 5K it takes off like it's supposed to. It is more noticible the higher the gear, of course. Almost like a fuel hole.
2. A couple of times since then I've had double backfires on WOT. One time it felt like the engine may have missed pretty badly WOT, it felt like hitting the first *bump* on the rev limiter but I was at about 5500RPM but I heard no backfire or anything.
3. After a run in with an M3 in Austin off of 360 and him leading me to this BAD ASS windy, elevation changing backroad. After running the engine hard for 20min, the car no longer had problem number 1. But it's back now.
4. Power has been inconsistant also.
Any ideas?
GregUnd is offline   Reply With Quote
Old 04-02-2003, 10:40 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Try resetting the ECU, see what you notice or what problems stay or go away.
Legacy777 is offline   Reply With Quote
Old 04-02-2003, 11:00 AM   #3
D_REX
Member#: 8945
MY02 WRX
I've had similar problems, although not to that extreme, when I got a bad tank of gas. Power was flat in the mid range but started to pull hard again as boost started to taper.
What are you using for engine management now?
D_REX is offline   Reply With Quote
Old 04-02-2003, 11:38 AM   #4
GregUnd
Baaleted
Member#: 11800
Still stock ECU @ 13-14psi. I've got 565cc's, fuel pump, fuel rail, and unichip sitting in my room. I'm waiting on the GOD DAM GEARS to get in before I install everything I have and go up to FIS to get tuned. Chalak is really starting to piss me off. I'm giving him until this Saturday to either come in contact with me, deliver my gears, or refund my money before I RUINE his reputation here in America....... and also I'm going to be taking this from a legal stand point. Since it was paid with a Credit Card, I can get my money back.
Old 04-02-2003, 01:28 PM   #5
D_REX
Member#: 8945
MY02 WRX
Just stop driving your car hard until you get the engine management installed. As far as Chalak goes, many others here have tried to ruin his reputation, you still bought his product
Old 04-02-2003, 01:32 PM   #6
Big_Hitter
Member#: 10831
2011 Ferd Ranger 4x4
2009 FXT VF52/E85
worst case, sounds like an opportunity to try out the tuner at turbochargers.com
let us know how they do
Big_Hitter is offline   Reply With Quote
Old 04-02-2003, 01:56 PM   #7
GregUnd
Baaleted
Member#: 11800
I heard bad things about his first gen gear sets and great things about his second gen gear sets so I bought them. Depending on his response to this letter I just wrote to him, I may let it loose on everything that's been hapening in the past few months between him and I. But until then, I have to keep hush hush.
Old 04-02-2003, 02:05 PM   #8
GregUnd
Baaleted
Member#: 11800
To hell with that idea!
No one is going to be doing any field testing on my car, such as...
"Let's see if the center diff holds up on this dyno or not"
Sheeeeeeiiiiiiiittt, you must got me straight trippin'... on tha real tho, dawg.... fo real, fo real doe
Old 04-02-2003, 02:14 PM   #9
Big_Hitter
Member#: 10831
2009 FXT VF52/E85
It's evident that you've been hanging out in the Shepherd/Crosstimbers area WAY too long!
Old 04-02-2003, 02:48 PM   #10
GregUnd
Baaleted
Member#: 11800
Straight'd up, main, fo real doe. We'd just been kickin' it down at "lil' dope's" crib hittin' da killa, know whad'Im sayin dawg... buu we abaut to go'down to dat bitch, Shaquifa'tifa's, crib and I'm'on break dat ho' off dawg, fo'real doe main... make a muafuka say "UUUUUUUHHHhhhhhh" Main howd up!!
Old 04-02-2003, 02:50 PM   #11
jmott
Member#: 6713
2007 Prius
brown
you have big injectors and a stock ecu and you are surprised your car isnt running right?
jmott is offline   Reply With Quote
Old 04-02-2003, 02:51 PM   #12
GregUnd
Baaleted
Member#: 11800
Shouldn't make a difference if they're not installed.........
Old 04-02-2003, 02:57 PM   #13
jmott
Member#: 6713
2007 Prius
brown
ah
I thought you meant just the unichip was sitting in your room
Old 04-02-2003, 03:00 PM   #14
GregUnd
Baaleted
Member#: 11800
ah
just messin with you anyway
Old 04-02-2003, 03:47 PM   #15
supermarkus
Member#: 6971
2008 WRX STi
SSM
Jon[inCT] outlined a procedure that makes the stock ECU relearn the long term fuel trim and allows you to run the STi injectors. I haven't tried it myself, but the guy he was helping said his stuttering and open loop performance got better. It seems as if the stock ECU can handle the bigger injectors just fine as long as they aren't low impedance injectors.
supermarkus is offline   Reply With Quote
Old 04-02-2003, 04:01 PM   #16
jmott
Member#: 6713
2007 Prius
brown
The stock ECU can learn to adjust for almost anything you throw at it in closed loop mode.
but in open loop mode (what happens when you floor it), you can't count on a simple correction factor thrown into the static maps to work. bigger injectors throw that system way out of its useful range.
it might almost work, or work when the weather is a certain way, yadda yadda yadda. Whatever hack you do to get the air/fuel ratio right, its really best to have a wideband O2 in there to monitor it and KNOW that you have it right. rather than just saying "oh well its not stuttering now, must be ok" who knows, maybe it got too lean!
Old 04-02-2003, 04:23 PM   #17
supermarkus
Member#: 6971
2008 WRX STi
SSM
It was just a stop gap until the guy got engine management anyway. I never said anything about his open loop performance being tuned and perfect. He said it got better.
Old 04-02-2003, 11:34 PM   #18
datdudedennis
Member#: 3928
2002 WRX sedan
WRB use to be MBP
are you running the txs hpbc? if so i had the same problem due to the bleeder valve being fully closed.
datdudedennis is offline   Reply With Quote
Old 04-03-2003, 12:05 AM   #19
GregUnd
Baaleted
Member#: 11800
Nope, I'm running the ProfecB.
Actually after hooking up the deltadash this evening and then resetting the ECU, everything is %400 better and the engine is running like it should after data logging before and after the reset.
Old 04-03-2003, 12:28 AM   #20
supermarkus
Member#: 6971
2008 WRX STi
SSM
could it be that your boost solenoid is kaput? I've heard bad things about the profec line of boost controllers. They're single solenoids right? Those can be prone to spiking.
Old 04-03-2003, 10:04 AM   #21
GregUnd
Baaleted
Member#: 11800
dual sol's.
Old 04-03-2003, 11:00 AM   #22
supermarkus
Member#: 6971
2008 WRX STi
SSM
I did a search and it seems the Profec A series were the ones people were having troubles with. Do you see any knock events in your datalogs? Do a bunch of DD runs and see if anything shows up.
Old 04-03-2003, 12:23 PM   #23
GregUnd
Baaleted
Member#: 11800
I've done MANY DD runs and haven't seen knock once. Ussually knock correction is about 8.5-9.0max, which is good.
Madison, WI: think I've got alignment trouble Zongo Mid West Subaru Owners Club Forum -- MWSOC 21 01-13-2004 04:45 PM
I've got some problems thetikler1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 08-11-2003 05:54 AM
By Jove I Think I've Got It BOY Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-04-2003 09:18 AM
Screwed up my front O2 sensor the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 10 08-28-2001 12:48 PM
('93-'01) I'm about to do some business but the board is screwed up! HELP ARG Impreza Forum 1 06-06-2001 09:41 PM
