Old 04-02-2003, 09:14 PM   #1
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
boat, dirt bikes, bobcat
Default Can someone please confirm the correct hoses I need to get for my Perrin Fuel Rails?
Hi,
If anyone could confirm the correct size Fuel and Vacuum hoses I need for my Perrin Fuel Rail install this weekend I'd appreciate it.
I searched and only found one person saying that its:
3/8 Fuel Hose &
1/8 Vacuum
Can someone let me know if this is in inches and how long the pieces need to be? Any help is greatly appriciated. Im installing the rails and PE1820 on Saturday dont want to mess up anything. Im sure I'll have to do some major Utec tuning also.
Any tips on Tuning and Installing are VERY helpful. Thanks guys!
Best regards,
-Brian
STR8OUT is offline   Reply With Quote
Old 04-02-2003, 09:34 PM   #2
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
You could always look at the instructions on their website
PARTS YOU WILL NEED:
* -1/4 VACUUM HOSE 3FT
* -1/2 FUEL HOSE 4FT........
driggity is offline   Reply With Quote
Old 04-02-2003, 09:53 PM   #3
Bolster
Member#: 22290
2002 WRB WRX Wagon
I think the 1/2" hose must be outer diameter, because 1/2" ID is WAY too big. I got 4 feet of it and only used a small portion (like 1 foot or less). The vacuum line needs to be at least 3 feet long depending on how you route it (you'll probably trim it some, but that should give you plenty to work with).
'edit'- the fuel hose I used was indeed 3/8"
Bolster is offline   Reply With Quote
Old 04-02-2003, 09:56 PM   #4
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
Thanks for the responses guys but I swear I've heard that the hoses Perrin tells you to get are the wrong sizes or something.
Arent they to big or something? Please more people chime in.
Thanks for the lenth measurments Bolster. That helps a lot. Im not trying to be running to Pep Boys or Home Depot in the middle of this install or anything.....
Thanks again,
-Brian
Old 04-02-2003, 10:06 PM   #5
Bolster
Member#: 22290
2002 WRB WRX Wagon
I didn't use 1/8" vacuum line for my install since I had some silicon hose that was the same size, but 1/8" should do the trick. In fact, I noticed this evening that I had a tear in the line and had to fix it. Usually silicon is pretty tough.
Old 04-03-2003, 12:01 AM   #6
WRX-Hellfire
Member#: 9978
2002 WRX Platinum
Tuned by I-Speed
Thanks again,
-Brian
I found the ones that Perrin recommends were too large. I ended up running to my local parts store to get the correct sizing. I think it came out to 3/8" fuel and the smallest hose I could find for vacuum(1/8" I think).
WRX-Hellfire is offline   Reply With Quote
Old 04-03-2003, 10:24 AM   #7
Egan
Member#: 12670
01 M Coupe,
05 Legacy GT, 05 Titan
The 1/2" hose for the evap and the 1/4" (I think it is 1/8") for the FPR come with the Perrin kit! Check the bottom of your box.
At least they came with mine. I installed the rails on my removed intake manifold last weekend. Simple install with the manifold out. Taking the manifold out was another story.
Egan is offline   Reply With Quote
Old 04-03-2003, 11:16 AM   #8
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
Be sure you use fuel injection hose and not carbuerator. The carb hose can't handle the pressure.
cavymeister is offline   Reply With Quote
Old 04-03-2003, 11:21 AM   #9
Egan
Member#: 12670
01 M Coupe,
Neither hose actually runs fuel (at pressure). The small hose connects the intake manifold to the port on the FPR. It's used to detect boost and raise the Fuel Pressure accordingly (IIRC). The larger hose is part of the evaporative system (3rd "fuel" line). All of the pressurized fuel lines are SS hose and part of the Perrin rail system (pre-assembled).
Old 04-03-2003, 11:50 AM   #10
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
Thanks for all the info guys. I hope this thread is useful to others who are installing Perrin Rails.
I am very surprised that Perrin still hasnt changed the directions on thier website.
Thanks again, please let me know if you have any other tips for me. I'm gonna go and buy the hoses today after work. Can I get them at Pep Boys?
Brian
Old 04-03-2003, 11:54 AM   #11
Egan
Member#: 12670
01 M Coupe,
I was at Pep Boys yesterday and they do have various sizes of fuel line and fuel injector hose.
Does your reply mean your kit did not come with the hoses? I bought mine a couple of weeks ago and it did come with the necessary hoses. That seems odd.
Old 04-03-2003, 02:14 PM   #12
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
I bought my kit a couple of months ago and never got around to installing them. They didnt come with any hoses. It even says in the directions that I will need to buy these hoses......
Im sure the hose isnt more than $10 so its cool. I also got a great price on the rails so it works out ok..
Thanks again everyone.
Going to japan, what do i need to get for my car? Dragicon General Community 25 05-19-2007 06:04 PM
Question for you Perrin Fuel Rail Owners ErikAnderson North West Impreza Club Forum -- NWIC 0 02-16-2005 08:18 PM
Can someone please confirm Cusco GC8 rear sway bar#'s BIGSKYWRX Brakes, Steering & Suspension 2 06-12-2003 03:28 PM
which dual inlet FPR to get with my Vishnu Fuel Rails latinskllz Normally Aspirated with bolt-on Forced Induction Powertrain 8 09-26-2002 10:21 PM
Can someone please post the link to the silver vision bulbs? WRC WRX Interior & Exterior Modification 6 09-21-2001 04:21 PM
