Old 05-03-2001, 12:46 AM   #1
T-REX
Member#: 11
2002 Impreza WRX
World Rally blue -Sedan
Post How to use a buffer.
Hi guys,
I bought a buffer off a guy. Trouble is, I have no instructions on how to use it. And have never used one/Never seen one used.
Does anyone use one and offer some tips on how to use it.
Specifically, do I leave it on one area until it shines? or move around alot.
Do I apply wax first over the entire car? and buff after? or same has hand waxing, apply small parts, then buff accordingly.
TIA,
Terry
T-REX is offline   Reply With Quote
Old 05-03-2001, 09:09 AM   #2
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
I'm hoping this is a random orbital buffer and not just a normal one. Otherwise I say don't use it or you'll burn edges of the paint. Anyway
Put some liquid wax in circles on the buffer's pad. Not a lot. Place the buffer on the car then turn it on (or you'll get hit with wax splash trust me) move the buffer back and forth and up and down. don't press or stay in one place keep it moving. Let the buffer do the work. Do all the flat surfaces. Then take the pad off and use it to get the nooks and crannies by hand. Let the wax dry, change to a clean pad and then take it off pretty much the same way. Change the pad if it gets real dirty with the wax removal. That's how I do it anyway and I'm far from an expert on the subject. Maybe someone who know's better can chime in.
Peaty
Peaty is offline   Reply With Quote
Old 05-03-2001, 09:46 AM   #3
tora
Member#: 5851
09 Forester XT
+ NA Miata
Post
You've got the right idea. I would do one section at a time. (like your hood). Move the buffer in a figure eight and make sure to cover all areas evenly. You can sometimes get swirls if you're always going in the same direction. Make sure your uffer clothes are extremely clean. Any dirt will scratch your paint. I like to do three steps. First apply the wax as previously explained. When it dries to a nice haze, change the clothes on your buffer and remove the wax. Once it is all removed buff it with a buffer cloth. This should bring out a nice shine if you have done it right. Even with an electric buffer this will be time consuming but the payoff is worth the effort. Good luck.
tora is offline   Reply With Quote
Old 05-03-2001, 01:39 PM   #4
nikkicalves
Member#: 3608
Location: the T-dot - The green igloo billowing black smoke
2000 Impreza
Tanned - BRP
Post
Honestly,
I would try to get someone who knows how to use one before you attempt this. I tried it with my first car to get rid of all the swirl marks. I can tell you that it didn't exacly work out as I planned - I ended up waxing the car with Eagle One wet look and it looked better than what the buffer did. The only time I would ever use a buffer woiuld be to take out inconsistancies in the paint. ie: faded areas. I realized that it is more work than it is cut out to be, mind you if it is done right you will get a showroom shine.
almost forgot... you can get kits at Canadian Tire with all of the bonnets you will need to finish the car.
[This message has been edited by nikkicalves (edited May 03, 2001).]
nikkicalves is offline   Reply With Quote
How to use a buffer/polisher HAL1 Interior & Exterior Modification 5 07-15-2006 01:40 AM
Anyone care to show me how to use my new Digi Rebel XT? KC Off-Topic 16 06-20-2006 01:44 PM
How to use our superior subie knowledge to save on gas burrito007 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 09-07-2005 07:54 PM
How to use a whole day to install a cat-back eclip5e New England Impreza Club Forum -- NESIC 5 11-23-2003 12:23 AM
Touch up paint - Where to buy and how to use? Jing Southern California Impreza Club Forum -- SCIC 3 09-11-2002 06:07 PM
