Old 04-03-2003, 01:20 PM   #1
dingo dave
Member#: 33177
2000 Impreza RS coup
white
Default Mechanic can't extract bad O2 sensor
I took my '00 rs to my mechanic to install a new O2 sensor i picked up at the dealer. My mechanic said the old sensor was somehow stripped from some one trying to extract it before, I guess with the wrong tool. He said to get it out he would have to pull out the whole exhaust and heat it (weld it, i guess) in order to get it out. This would cost $185.
Before I took it to my mechanic i asked the sub dealer how much it would cost to replace the O2 sensor, and they said $120 for labor(part costs $80).
I don't know if i should go ahead and take it to the dealer. If this is a problem they will obviously charge more than the $120, but if there is a trick to getting it out it may just be the $120.
I just got this car about 2 months ago, and i know from the dealer that the recalled O2 sensor had already been replaced.
Does anybody know what could have happened to this O2 sensor to get it stuck inthere like that?
dingo dave is offline   Reply With Quote
Old 04-03-2003, 10:22 PM   #2
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Like the mechanic said, somebody stripped it using the wrong tool. Unfortunately you may be stuck paying the extra $$
Mike Wevrick is offline   Reply With Quote
Old 04-03-2003, 10:26 PM   #3
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Talking
Here is your reason to go aftermarket on your exhaust now
Flowmastered87GL is offline   Reply With Quote
Old 04-03-2003, 11:01 PM   #4
dingo dave
Member#: 33177
white
what aRE SOME ideas on an after market exhaust. How much am i looking to spend(not much) and what are the benifits?
Where would i go to shop for one?
Old 04-04-2003, 08:27 PM   #5
obyone
Member#: 16523
First off....was it the first or second O2 sensor that is the little bugger?
If it's the first one, and you don't want to spend too much money, go with the borla headers. They fit onto all stock locations, are pretty cheap ($300 I think), and will give you a nice HP improvement and exhaust tone improvement. The only down side is that they do not give you the most HP for a header replacement, but to get those, you'd have to spend wayy more than $300.
obyone is offline   Reply With Quote
Old 04-05-2003, 07:49 AM   #6
zoinkssooby
Member#: 18910
2000 mr2 spyder
the headers are not directly connected to an o2 sensor on the MY00 RS (just did mine last week). the first sensor is on the cat section just behind the header. the second sensor is further back but, im not sure what part since i didn't need to know at the time.
www.rallitek.com has a hi-flow cat for $395
check the vendors section of i-club for a random tech cat for $338
IMO, you should buy the new exhaust piece and tools that you need and do it yourself.
zoinkssooby is offline   Reply With Quote
Old 04-05-2003, 10:32 AM   #7
Keith Cournoyer
Member#: 16764
Default 2nd o2 sensor
Hi, I had the exact situation with my headers, except I don't think the Sensor is stripped. I think it's probably melted inside there, mine was! This will give the appearance that it is stripped. The exhaust shop guy simply heated up the surrounding area with a torch and turned like hell. You can run your car with the second one removed, but will sound like crap because of the hole, unless you can plug it up. Also, there will be a check engine light. Look for the MRT header if your staying NA. Nice gains! If going turbo, stay with the borla or stock unit. Good Luck, Keith
Keith Cournoyer is offline   Reply With Quote
Old 04-05-2003, 11:12 AM   #8
spiralsmurf
Member#: 16085
2005 STi
actually the first sensor is in the headers, not behind the cat.
spiralsmurf is offline   Reply With Quote
Old 04-05-2003, 01:55 PM   #9
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
I have stock headers and cat sections from a 99 RS. I could sell you whichever part you need for cheaper than its going to cost to fix. Let me know if you you want them.
Surb00 is offline   Reply With Quote
Old 04-05-2003, 06:42 PM   #10
zoinkssooby
Member#: 18910
2000 mr2 spyder
as i said... i just put on borla's (4th gen.) last week. i have a MY00 RS and i did not have to pull out the sensor because it is not on the headers. it is just before the cat on the cat section. maybe the other versions of the header had the sensor bung on them but, mine did not.
Old 04-06-2003, 08:47 AM   #11
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
$185 to take off a small section of pipe and remove an O2!?!?! Crap, you should just take the pipe off yourself and bring it to him to heat up and take the old 02 out. Install the new O2 yourself and put it all back together. If you have some decent pliers and a MAP gas torch from Wal-Mart you could probably even get the old O2 yourself. If you don't have tools, $185 will BUY you some.
-Brad
ChicksDigWagons is offline   Reply With Quote
Old 04-06-2003, 04:51 PM   #12
matt8416
Member#: 34929
2004 sti
07 Lexus Breakwater Blue
Default O2
the o2 is in the cat on stock exh. if you do not want it mess up any further take the car or undo the 6 nut to the head, the one bolt on trans hanger, the two bolts to the B-pipe and take your cat to the dealer. i would take the car, ask for a master tech they have the tools to do the jod right
matt8416 is offline   Reply With Quote
Old 04-06-2003, 06:48 PM   #13
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default dingo dave
dingo dave,
Why not take it to the dealership to see what the cost will be? They may or may not charge extra for it being 'difficult' to pull out. Just don't say anything about the problem and take it in to get the job done for $120. If they say they are going to charge extra (post $185), then say nevermind.
Kevin Thomas is offline   Reply With Quote
Help! I can't find my O2 sensor plug gregsatt Texas Impreza Club Forum -- TXIC 5 11-10-2006 02:58 PM
Bad Mil Eliminator or Bad O2 Sensor? jalow72 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-06-2005 07:49 AM
Bad O2 sensor bad for your car? kodakeos Normally Aspirated Powertrain 3 09-23-2004 08:39 AM
bad O2 sensor on MY99 Girl'sRS Service & Maintenance 5 02-12-2002 11:51 AM
Bad O2 sensor? tomas General Forum Archive 0 03-25-2001 09:51 PM
