Old 05-03-2001, 08:49 PM   #1
phastimprezaRS
Member#: 4979
2001 2.5 Rs
Black Diamond Pearl
Question how to turn off AWD?
Does andyone know how to turn on and off the AWD in the 01 2.5Rs? From what I hear it can be turned off through a the computer. Just wondering cause I miss having my corvetter to burn out in every so often. I am just getting the slight urge to light them up a few times. Any help please???
phastimprezaRS is offline   Reply With Quote
Old 05-03-2001, 08:52 PM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Arrow
If you've read your owners manual, you'll see that only automatics have the ability to turn on or off the AWD. If you've got a manual transmission, the only way to change your car to 2WD is to open up the transmission and tinker around in there.
LaterZ!
Darren!!
ps -- next time, do a search!
Penphoe is offline   Reply With Quote
Old 05-03-2001, 08:52 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Lightbulb
when rallycrossing... i turn mine off by just pulling the AWD fuse...
j. www.subiegal.com
Old 05-03-2001, 08:56 PM   #4
IMPREZA GUY
Member#: 4119
2011 Mitsu Evo X
Graphite Gray
Post
hmm will the impreza move faster with awd off? since AWD sort of lags, and when it is off it turns into front wheel drive correct???, because i think you have to pull a fuse and move it for when you get a flat tire
IMPREZA GUY is offline   Reply With Quote
Old 05-03-2001, 08:59 PM   #5
Penphoe
Member#: 269
Post
Like I said before, it's only the automatics that have the ability to "turn off" AWD by pulling the AWD fuse. Subie Gal's "old" rally-x machine was her Legacy GT which was automatic -- that's why she was able to turn off AWD.
LaterZ!
Darren!!
Old 05-03-2001, 10:15 PM   #6
Loki
Member#: 4543
2003 WRX
Exclamation
Well, I've thought about this myself. I was skimming the owners manuel, and it says that you can put it in FWD if you want/need to. Now it does make sense that only an automatic has this ability. HOWEVER, I have a 98RS 5spd. If you open the trunk, there's a black fusebox on the right hand side. Open that, and you'll have a fuse slot that is empty marked FWD. Toss a 20amp fuse in there while the car is off, and you should be in FWD.
Now. I have never done this, never seen it done, and you could very well break something trying it.
I remember another post somewhere where someone had it in FWD for a day, and it was very easy to spin the front tires. I guess the traction control isn't effective in FWD.
Again, be careful, I don't want to hear someone tried this and broke their motor. I'm no expert in this.
<IMG SRC="http://www.theloki.org/sig.gif" border=0>
Loki is offline   Reply With Quote
Old 05-03-2001, 10:18 PM   #7
steppin16
Member#: 6010
Post
Anyone know if they sell the thing that the 22B has to change the drive settings from front to rear and anywhere in between. I know its something like a switch inside the cabin that does it. but as you can see I don't know much more!
steppin16 is offline   Reply With Quote
Old 05-03-2001, 11:25 PM   #8
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Post
The 22B has a center diff with electrical control (dunno if it is mechanical or hydraulic). You can put the diff and the control dial in MY98 and earlier Imprezas (how much earlier, someone else can answer). MY99+ change the number of bolts, so it won't work with them.
bsquare is offline   Reply With Quote
Old 05-04-2001, 12:14 AM   #9
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
Post
this is interesting...in an auto RS you can make it FWD by pulling a fuse?? enlighten me a bit more please...besides Suby Gal has anyone done it in an RS? consequences?long term ?short term.
ATX25RS is offline   Reply With Quote
Old 05-04-2001, 12:50 AM   #10
SuBaRu-ImPrEzA_RS
Member#: 2053
Post
ive done it once or twice in my 2000 auto RS, not for more than 5 miles though..then i did about a 5 second burnout with it in FWD too hehe... left a nice lil black mark and some smoke...
when you go around turns fast in FWD the steering wheel seemed sorty jerky in mine..and you can definitely tell the awd isnt there..
~~PeAcE~~ john www.impreza25RS.cjb.net
SuBaRu-ImPrEzA_RS is offline   Reply With Quote
Old 05-04-2001, 01:19 AM   #11
Andrew
Member#: 1170
2005 STi
Post
theres also simple tricks to make it into 50/50. all you need is some resistors
Andrew is offline   Reply With Quote
Old 05-04-2001, 08:12 AM   #12
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Post
You can put the auto in FWD because the AWD system is electronic. The MT has a mechanical AWD system. That's why one can and one can't.
garface is offline   Reply With Quote
Old 05-04-2001, 08:13 AM   #13
Herbie
Member#: 415
2002 WRX Wagon
2002 BMW Z3 3.0i Coupe'
Post
Loki, again check the manual and all the internet info, the fuse only works for Auto cars.
Here's the skinny folks: The non-VSD autos (all Mk1 and RS Mk2 Imps, and non 3.0L Legacies) use a clutch-pack center diff. Torque split front/rear is varied by pulsing the clutch pack with a solenoid.
By INSERTING the aforementioned fuse, you can defeat the clutch pack pulsing, which will make the car MOSTLY FWD. NOT ALL FWD. There's always some residual drag sending a small amount of power to the rear, but you won't have any dynamic compensation for wheelspin which is why people can spin the tires when doing it.
Now, that being said, I'd read the manual again to be sure, but IIRC the manual also says ONLY do this for short distances at LOW speeds. Rallycrossing and or doing hard burnouts probably isn't what Subaru had in mind...
Herbie is offline   Reply With Quote
Old 05-04-2001, 08:23 AM   #14
skeletor25rs
Member#: 1844
1970 Scout
Gold, Tan, Rust, Primer
Post
Trey Cobb made his manual RS rear wheel drive for a while to dyno test it. You could ask him. I think it was a full swap of some kind, not a quick change over
skeletor25rs is offline   Reply With Quote
Old 05-04-2001, 09:14 AM   #15
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
Why would you want to make an AWD car into a FWD car for a rally cross event?
Sorry if this is a stupid question.
remarcable is offline   Reply With Quote
Old 05-04-2001, 03:02 PM   #16
Poseidon
Member#: 4864
2004 WRX
Post
What does this have to do with "Dress-Up and Style?"
Jordan
Poseidon is offline   Reply With Quote
Old 05-04-2001, 03:02 PM   #17
GooseMan
Member#: 2462
2012 Audi A4 Avant
S-Line Titanium
Post
You can make your car FWD or RWD.....just remove the CV joints from either end! Or maybe right drive or left drive? No?
Jon
GooseMan is offline   Reply With Quote
Old 05-04-2001, 03:33 PM   #18
Scoober01
Member#: 3649
2001 Impreza 2.5 RS
Blue Ridge Pearl-Red acc
Post
I have a MY01 MT 2.5RS and have done this for a short time. I took it on the HW around 70 and normal street. It is possible on MT. Though I myself would not due it for more than a few miles.
Scoober01 is offline   Reply With Quote
Old 05-05-2001, 12:31 AM   #19
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
Post
Please be careful if you try to run your car in FWD. When I bought my car, the dealership warned me to engage FWD ONLY in an emergency. For example, if you get a flat tire and have to run on the spare, or if your car needs to be towed and there are absolutely no flatbed tow trucks available, then you should engage FWD.
The guy at the dealership mentioned that several people in the past have disengaged AWD thinking they'd have better fuel economy and ended up doing damage to the drivetrain over time.
I don't know if those things are true, but I personally wouldn't risk it. After all, Subies were not designed to be FWD cars, so you're probably going to wear something out in trying to make it a FWD car.
BJamerican is offline   Reply With Quote
Old 01-13-2002, 09:35 PM   #20
Joelk
Member#: 7790
2009 wrx
I would really like to know how to do this. Do you have any more information or some links?
Thanks.
Joelk is offline   Reply With Quote
Old 01-13-2002, 09:58 PM   #21
JRC 666
Member#: 2950
JRC 666 is offline   Reply With Quote
Old 01-14-2002, 04:19 AM   #22
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Default Re: how to turn off AWD?
I think that is the "dress up and style" part
Old 01-14-2002, 10:15 AM   #23
live311
Member#: 10801
2008 Outback
I did a search and found this thread. You might find it interesting.
http://www.i-club.com/forums/showthr...5&pagenumber=1
live311 is offline   Reply With Quote
Its almost 2009..How the **** do people still not know how to turn off a computer???? I25 Off-Topic 15 11-25-2008 02:53 PM
how to turn off stock alarm... or at least the horn. ratboy Car Audio, Video & Security 10 01-12-2003 12:32 PM
How to turn off the turbo Stranger Normally Aspirated with bolt-on Forced Induction Powertrain 18 04-18-2002 04:35 AM
how to turn off password store? pbnj9786 Newbies & FAQs 5 05-31-2001 05:48 PM
