Old 04-04-2003, 02:23 AM   #1
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
Default advantages of external wastegate over internal wastegate?
what are the advantages of going with the external wastegate setup over the internal wastegate? will boost creep be eliminated completely? i'm wondering cause i am getting the aps d/r 500 front mount intercooler and was planning on going with the external wastegate setup, but will have to modify the the piping for the intercooler. seeing how the aps intercooler is, it'll be quote tough to reroute the piping to accomodate the external wastegated turbo. thanks in advance!
peter
petawabit is offline   Reply With Quote
Old 04-04-2003, 02:54 AM   #2
yellowWRX
Member#: 17457
2002 Impreza WRX
Yellow
Default External reacts quicker
The external wastegate bleeds off boost faster because it acts like a BOV for the exhaust gases. The internal pressure is bled off using a swing valve, which takes time to open. In order not to overboost, the swing valve will need to start opening earlier to slow the exhaust gases from spinning the exhaust turbine wheel. With the external wastegate, you can stay on boost a little longer since there isn't as much delay to bypass the exhaust turbine wheel. The same is true to close the bypass to get on boost.
In short, the external wastegate allows the turbo to stay on full boost longer and allows the turbo to get on boost sooner. In actuality, I personally don't think it is worth it to spend an extra $500 for the external wastegate and another $200 to get the piping done for a little better response. I think it is more cost effective to match port the bypass hole to the swing valve (sorry, but I don't know what it is called) and get a divorced wastegate downpipe which will save you about $500.
I don't have any comparisons, so I can be wrong.
Just my $0.02...
yellowWRX is offline   Reply With Quote
advantages of Utec over unichip? David Medina Engine Management & Tuning 1 06-22-2005 10:16 PM
Adobe PS bastards: Advantages of CS over 7.0 eurojax Off-Topic 21 09-10-2004 10:53 PM
What are the advantages of components over coax? Ilford Car Audio, Video & Security 1 07-27-2004 05:44 PM
Any advantage of METRIC bars over IMPERIAL psi? samwY Electrical & Lighting 3 04-10-2004 07:27 AM
Stock Turbo on WRX External or internal Wastegate??? VallejoWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-11-2002 10:12 AM
