Old 04-04-2003, 10:58 AM   #1
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Default Head Gasket composition?
Can someone tell me what material the stock head gasket is made of.
maciek is offline   Reply With Quote
Old 04-04-2003, 01:38 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
i believe there is a guy on here that has a website with all the different types of headgaskets, and their composition.
I can't for the life of me find the link.......grrr.
Legacy777 is offline   Reply With Quote
Old 04-04-2003, 04:45 PM   #3
rhdude
Member#: 6637
2009 Acura MDX Sport
ok the '98 the headgasket is a metal/rubber gasket... it blows pretty easily.. they now make a 4pc/layer metal gasket, sorry I do not know what kind of metal it is...
rhdude is offline   Reply With Quote
Old 04-04-2003, 08:56 PM   #4
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default Head Gasket Composition
Most head gaskets are made of that pure blue rubber with steel core laminate inner. The good head gaskets are copper, and reusable. A lot of people also like graphite head gaskets, but copper is the best. The downside to this is that the copper gaskets cost around 5x the regular price of the cheapest gasket. This is a job you only want to do once, so, I recommend you go with piece of mind and go with a high quality gasket. I understand that everyone's pockets aren't deep, so, do what you can afford. I haven't had to deal with any Head Gaskets, nor do I want to, so I'm sure what types are available for the Subaru I-RS. Hope this helps.
-Charles-
Found this website about a 1998 Subaru I-RS-T with a blown Head Gasket.
http://www.forcefed4.com/25rs/head_gasket/
ImprezaVA is offline   Reply With Quote
Old 04-08-2003, 04:32 AM   #5
rhdude
Member#: 6637
ok, see the bottom left how the rubber has dissapeared? this is what mine looked like after I blew my headgasket... this is why so many '98 owners blow the stock gaskets, because subaru used cheap quality parts...
Blown head gaskets, warped heads and a piston melted to the cylinder wall Borjaq Warranty Issues & SOA Problems 13 05-22-2010 10:16 PM
Help! FAST! Do I need to use gasket sealer, when replaceing my head gaskets?! wighti Tri-State Area Forum 5 10-05-2003 10:19 PM
Which head gaskets on EJ22T with EJ25 SOHC heads? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 22 05-11-2002 11:08 AM
Leaky Head Gasket & Water Pump Gasket - MY00 Forester lark6 Normally Aspirated Powertrain 20 11-10-2001 10:22 PM
EJ22T with 2.5 SOHc heads. which head gasket? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-03-2001 11:40 AM
