Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Old 04-04-2003, 11:12 AM   #1
psbfan
Member#: 34802
96 Celica
red
Default Which downpipe to get?
Which downpipe will work with Blitz nur spec exhaust and hopefully no CEL problem.....
psbfan is offline   Reply With Quote
Old 04-04-2003, 11:16 AM   #2
dman918
Member#: 11202
2009 Infiniti G37X
Prev: 2006 STi with stuff
I love my Perrin. If you are looking catted, it is by far the best IMO. Catless would be Perrin or PDE.
dman918 is offline   Reply With Quote
Old 04-04-2003, 05:04 PM   #3
Chris Morgan
Member#: 28219
2007 Speed3
True Red
Lightbulb PDE
Yes, I am getting a PDE 3 inch bellmouth downpipe installed very soon! Heard its the best if you have the money!
-Chris
Chris Morgan is offline   Reply With Quote
Old 04-04-2003, 08:23 PM   #4
lawn boy
Member#: 16345
2003 WRX- Sold
E60 BMW 545i
the helix is the best for those on a budget. stainless steel and a bell mouth
lawn boy is offline   Reply With Quote
Old 04-04-2003, 09:17 PM   #5
Greg 99
Member#: 1388
I think HKS is best bang for buck. You don't need a bellmouth downpipe unless you are running high amounts of boost. Save your money and buy an up pie with the difference.
thanks,
Greg
Greg 99 is offline   Reply With Quote
Old 04-04-2003, 09:48 PM   #6
Sandkicker
Member#: 6954
05 FXT
Pre: 02WRX, 98RS, 99RS
I wouldn't know how to prove that it's the best, but i've got the twin-dump design Bosal pipe and it seems to be doing pretty well. I don't have anything to compare it to though. I got it because it would allow me to keep the 3rd cat and stock midpipe while most replace the 3rd cat as well. Probably depends on whether you care about teh last cat or not.
Sandkicker is offline   Reply With Quote
Old 04-04-2003, 10:36 PM   #7
lobelsteve
Member#: 31992
2007 STI
UGM
My Invidia arrived today. Outstanding build quality. Won't know for a week or two when I install it if fit is right on or not. It replaces the downpipe and midpipe, includes rear gasket, has drilled and welded bung for rear O2 sensor, no cats so I'll need a mil elim.
lobelsteve is offline   Reply With Quote
Old 04-05-2003, 03:08 AM   #8
WuWrx
Member#: 30887
2003 wrx
thanks,
Greg
WuWrx is offline   Reply With Quote
Old 04-05-2003, 08:30 AM   #9
modvp
Member#: 25215
the bosal is a good choice.
modvp is offline   Reply With Quote
Old 04-05-2003, 09:26 AM   #10
Stavros g
Member#: 1526
Rally Blue
I also have a NUR spec and installed my bosal yesterday. From my research, a custom mid-pipe will be required. I would recommend a flex joint if you get one made.
The contruction was good, not GREAT. There we're some small rough spots in the polish, there we some globs of solder where the seperate pipe for the wastegate meets the main pipe.
My dealer that installed it, said it fit like a glove. no problems at all (he liked the pipe a lot).
I must say I felt the difference right away. Pull into the RED like a champ.
For 225us @ stranoparts I believe it's great bang for the buck.
BTW.... the NUR spec is even LOUDER. Hard to believe but true. Don't lose you're silencer like I did.
Stavros g is offline   Reply With Quote
Old 04-05-2003, 02:06 PM   #11
CRXguy
Member#: 25370
2003 WRX wagon
Played Out Blue
Originally posted by WuWrx
x2
CRXguy is offline   Reply With Quote
Old 04-06-2003, 05:47 AM   #12
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Question
does the Bosal need a CEL eliminator? i'm going to order a bosal DP sometime soon. and maybe a stromung 3rd cat eliminator.
how do u guys like the bosal DP?
AK_2002_WRX is offline   Reply With Quote
Old 04-06-2003, 01:10 PM   #13
thetikler1
Member#: 24096
2010 Outback
bump!
thetikler1 is offline   Reply With Quote
Old 04-06-2003, 01:47 PM   #14
mlambert
Member#: 13831
yes it needs one, all downpipes that remove cats need one...especially if you remove the 3rd cat!
mlambert is offline   Reply With Quote
Old 04-06-2003, 02:19 PM   #15
SLowery
Member#: 15736
06 STI
crystal grey
Default bosal dp?
I was thinking Bosal too and leaving the 3rd cat. Will I be missing out on significant gains by leaving the 3rd cat?
-Slowery
SLowery is offline   Reply With Quote
Old 04-06-2003, 06:22 PM   #16
Brewmaster
Member#: 16856
"I work until BEER
O clock" Stephen King
Ive run the APS for 10 months and no cel's
Brewmaster is offline   Reply With Quote
Old 04-06-2003, 10:48 PM   #17
Sandkicker
Member#: 6954
05 FXT
Default Re: bosal dp?
-Slowery
I've got the Bosal and left the 3rd cat. I think replacing the 3rd cat and midpipe will help add more power, but i'm not sure how much.
for reference, i've got a catless PDE uppipe and the prodrive muffler, bosal downpipe and stock mid&Cat pipes (no other power mods) and on a dyno run pulled 197 HP & 203 ft/lbs torque at the wheels... i think that's soemthing like 255-260hp @ the crank i think...
I think replacing the stock cat/midpipes would add a bit more torque... but i have no idea how much.... maybe someday i'll swap those out and do another dyno run.... but that'll be some day down the road.
Old 04-06-2003, 11:26 PM   #18
SLowery
Member#: 15736
06 STI
crystal grey
Default bosal dp
sandkicker,
Are you happy with the sound and build quality?
Old 04-06-2003, 11:36 PM   #19
Sandkicker
Member#: 6954
05 FXT
Yeah, I'm stoked on it. Build quality was awesoem... I'm no welder though, but the build quality looked good. I'm into the twin-dump design too... I'm not sure if it can be proven better, but i have yet to see anyone prove that it's a "BAD" idea.... so i figure it can only help. And it sounds like the twin-dump idea will come in handy if i ever go to a bigger turbo.
I'm not sure what you want to know as far as sound though, i don't have much to compare it too other than stock, but replacing the stock downpipe (with it's cat and all the shielding on the pipe) definitely allows you to hear the turbo and air-flow a bit more. I think it sounds cool. But if you want it to sound like you're sitting in a nice cooshy quiet BMW (where you can't hear/feel the engine at all), then you don't want to replace the downpipe (or anything else on the exhaust, i guess)... Not that it makes it a LOT louder, but you can hear many more sounds than you did before.
Old 04-07-2003, 12:01 AM   #20
SLowery
Member#: 15736
06 STI
crystal grey
thanks for the info. As far as I'm concerned sound is a good thing, unless it's whiny. A good heavy pipe should make a throaty sound, a thin pipe probably won't sound as good...... I guess that's what I was trying to assertain. I'm the kind of guy that doesn't even play music half of the time when I drive because I like the way my car sounds......
-Slowery
Old 04-07-2003, 01:55 AM   #21
03 Silver Bullet
Member#: 27222
2oo5 PlatinumSlvrSTi
JDM voyeur on the loose
I've got me a PDE. No CEL from cat inefficiency code yet.
Looks nice, sounds mean. And you can hear that turbo wind!
03 Silver Bullet is offline   Reply With Quote
Old 04-07-2003, 09:49 AM   #22
modvp
Member#: 25215
I got a CEL with my Bosal. I installed the "resistor mod" and all is fine after 5000 miles.
Old 04-07-2003, 11:40 AM   #23
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Question
if i have my stock up pipe and stock third cat still in place, will i pass emissions with the bosal DP?
so is the turbo noise louder? like the whine and spool up sound? i thought an intake would give me the sounds i wanted, but it wasnt enough
Old 04-07-2003, 12:03 PM   #24
Sandkicker
Member#: 6954
05 FXT
I think you'd probably pass emissions with any 2 of the cats... unless you're in california. Some people seem to think you could pass with just 1 cat... i'm not sure though... i'll find out next month.
Old 04-07-2003, 12:58 PM   #25
Dr. Zevil
Member#: 7091
2011 DGM STi Hatch
02&06 WRX; '05 LGT Wagon
This is without the resistor fix? I was thinking about going APS, but I wasn't sure yet. I was also considering TXS. Please post more comments about your APS stuff!
Dr. Zevil is offline   Reply With Quote
Which PDA to get. 3 To choose from STEALTH-WRX Off-Topic 2 09-20-2006 02:26 AM
I need soundclips to determine which TBE to get Vampyr Newbies & FAQs 20 10-31-2005 05:20 PM
Which FMIC to get to use with UR stage 3 kit WRXSTINUT Factory 2.5L Turbo Powertrain 18 02-10-2005 09:06 AM
help me to decide which lip to get chobits Interior & Exterior Modification 0 04-19-2003 05:55 PM
Which JDM downpipe to get.. Jake Steed Factory 2.0L Turbo Powertrain 4 11-15-2002 11:34 AM
Message Board Statistics All times are GMT -4. The time now is 03:33 AM.
