Old 04-04-2003, 11:08 PM   #1
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Default What does ping and knock sound like?
I was driving this past week on a long roadtrip out east and back and on the way back from the east coast i noticed my car would make this funny noise.
While i was driving at freewya speeds from 50-80 mph whenever i lifted my foot off the throttle, i would hear the chirping sound that i normally expect from the WRX exhaust and custom midpipe i had installed. However now i noticed a snapping/rattling sound that would only occur when i lifted my foot off the gas. I could stop this sound early by pressing my foot back on the gas. It would start off fast then gradually tail off after a few seconds, but it was noticably loud and almost sounded as if something on the underbody of the car was snapping to pieces and i could feel the force of the sound in the gas pedal. However i dont think anythying is actually falling apart.
I'm wondering if its related to engine knock/ping at all, because I was wondering if i was hearing some misfiring in the exhaust manifold. I usually run regular octane gas, but for a change i ran premium 91 octane for nearly a full tank and the frequency of these sounds was significantly reduced but not altogether gone. When I filled my next tank with regular gas, the sounds came b ack again with the same 'lift-off-throttle' pattern. So far my engine seems to be running ok at constant cruise and accelration and other than the weird sound, i can't tell if this is anything serious. But its a new sound and its concerning me. Plus i haven't seen a CEL again, but i'm not sure if that could pop up at any time.
Just wondering if anyone knows what this may be. Thanks
Ed
edkwon is offline   Reply With Quote
Old 04-05-2003, 04:48 PM   #2
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
they said the pinging sounds like marbles rolling around in a tin can..I never heard the sound myself but it would be nice for a recording..
SubaruImpreza_power is offline   Reply With Quote
Old 04-05-2003, 10:45 PM   #3
dcoty
Member#: 3149
01 V7 GC/R32 sky
I had rod knock before, my con rod spun a bearing and trust me, you know something is really wrong (clacl clack clack) all the time which correlate to the rpm's (obviously). I had detonation before (due to nitrous) too and the car wouldnt climb past 5000 rpm at WOT and made a funny noise, like escaping gas and engine noise mixed together (and the engine sounded liek it was really straining), the my engine went to crap after I took my foot off the gas just a second too late.
dcoty is offline   Reply With Quote
Old 04-06-2003, 08:25 AM   #4
SUBY2.5
Member#: 31985
06 Outback Wagon
I know a subaru tech when I told him my car was making a noise similar to what you describe, he told me it is normally the tensioner,these cars are known for that.Try taking it to subaru and have them check it out.
SUBY2.5 is offline   Reply With Quote
Old 04-06-2003, 09:55 PM   #5
obyone
Member#: 16523
To further explain what he just said, read my old thread. It's very interesting.
http://forums.nasioc.com/forums/show...hreadid=297045
obyone is offline   Reply With Quote
Old 04-07-2003, 09:11 AM   #6
Jack
Add Lightness
Member#: 13699
2004 45k mile Outbac
(From General)
If it was pinging, you'd hear it under full throttle, not when backing off the gas. It sounds a bit like very small ball bearings inside a cast iron box being rattled around.....or like sleet on a skylight.
jack
Old 04-08-2003, 05:00 PM   #7
Vcarbs
Member#: 22851
Ed if you want to hear what pinging sounds like I'll take you for a ride in my truck. I would need to put 87 oct. and put a load on it, but you will diffently learn how pinging sounds.
Vince
Vcarbs is offline   Reply With Quote
what exactly does a rod knock sound like? peterdaniel Normally Aspirated Powertrain 1 03-30-2008 02:13 AM
what does a broken shock sounds like? awd4ever Brakes, Steering & Suspension 1 03-03-2003 11:32 AM
What does turbo death whine sound like? WR-REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-25-2003 12:49 AM
What does timing belt noise sound like? 98legacy Service & Maintenance 6 01-13-2003 06:29 AM
What does an exhaust leak sound like? protouring72 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-28-2002 12:09 AM
