Old 04-05-2003, 01:52 PM   #1
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Default will a WRX clutch fit on a EJ18?
Hi, I was wondering if the clutch off of an 02 WRX would fit on a ej18 engine. I am turbo charging my 1.8L and am going to need a new clutch. I have the WRX flywheel clutch and pressure plate along witht the WRX engine but I'm selling the WRX engine and was wondering if the I could hold on to the clutch and all and use it for my EJ18T. Does anyone know? Any help is appreciated.
Thanks, Micah
Old 04-05-2003, 10:55 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
You'll most likely want to use a WRX trans to go with the flywheel/clutch. Others have had troubles with clutch engagement or operation. Not to mention that the 1.8 clutch is a pull type where the WRX is push.....
ymmv....
Jay Storm
www.sourcemotorsports.com
Old 04-06-2003, 01:12 AM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Clutch, possibly. Flywheel, no. With the EJ18 transmition you need that specific flywheel, its not the same specs as the newer cars (and actually lighter). I found this out when I got my clutch and flywheel replaced in december...
Old 04-07-2003, 08:54 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
Anyone else have any ideas or thoughts on this idea?
thanks, Micah
Old 04-10-2003, 10:37 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
so it's basically a no go?
Old 04-10-2003, 02:21 PM   #6
5spd Alcyone
Member#: 34383
1992 SVX-T3/T04E
Dark Teal Metallic
dont forget to grab the bolts as well, trust me .....
5spd Alcyone is offline   Reply With Quote
will an 02-05 wrx clutch fit on 95 Impreza L azn0boi04 Transmission (AT/MT) & Driveline 1 03-02-2008 01:40 PM
will a stock wrx clutch fit on a 98L? rufracer Normally Aspirated Powertrain 6 04-12-2007 01:29 PM
Will 16" WRX rims fit on 06 WRX Mike Burke Tire & Wheel 2 10-13-2005 10:42 PM
Will 2003 WRX Fenders fit on 2002 WRX? samwY Interior & Exterior Modification 11 10-27-2004 12:46 PM
Will a WRX clutch fit on a GC8? Is it better? jay25RS Transmission (AT/MT) & Driveline 8 12-06-2001 10:43 AM
