Old 04-07-2003, 09:38 PM   #1
AntonioS
Member#: 23233
2000 2.5RS-T
white
Default Tuning a 2.5 RS
My 2000 2.5 RS has this mods
2.25 catless exhaust, injen intake, gfb pulley kit, port and polish trottle body and intake manifold, stage 2 heads and greddy e-manage. I want to know whats a safe exhaust temp should my car be running and what water temp since the engine will have a higher compresion than stock. and what oil pressure while I'm wide open trottle
AntonioS is offline   Reply With Quote
Old 04-08-2003, 12:44 AM   #2
dcoty
Member#: 3149
01 V7 GC/R32 sky
Im getting my built N/A 2.55 L engine installed tomorrow (ready thursday) and i can answer your questions after I get it back. Its 11:1 compression, are you upping yours? I have oil pressure and fuel pressure, i need EGT though. Ill let you know what my tech says, ill ask tomorrow.
Dan
dcoty is offline   Reply With Quote
Old 04-08-2003, 10:34 AM   #3
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Antonio, keep the EGTs under 1600F max (aluminum starts to melt just north of 1600F). Shoot for 1550F (or 850C) as a good target. As for oil pressure, not sure.
Old 04-08-2003, 11:01 AM   #4
AntonioS
Member#: 23233
2000 2.5RS-T
white
I do a lot of autoX and drag so i was thinking og trying t achieve around 1400 so I have a safety factor. What do you think? give me your thoughts to see if thats a good number or to low and I will need a more agressive number
Old 04-08-2003, 11:23 AM   #5
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
I'm tuning my RS-T for 1500F in 4th gear at WOT. I see closer to 1400 in the lower gears. What injectors/fuel pump are you using? What duty cycle are you seeing on the E-Manage? What are your timing settings? Are you using both fuel maps (Air Flow Adjust and Additional Inj)?
Old 04-08-2003, 11:51 AM   #6
AntonioS
Member#: 23233
2000 2.5RS-T
white
I'm using stock injectors with wrx fuel pump and I about the e-manage I haven't start to deal with it cause probably my car is finish by friday then I will have to start tuning it to get out the most hp possible
Old 04-08-2003, 12:09 PM   #7
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
I heard an SCCA rally driver say that "1600F is the magic number..." and "use your EGT gauge as a tach" but I don't like being that much on the edge. I know in a turbo application a good "street tune" will have EGTs quickly jump to 850C and then slowly drop toward 700C-750C at WOT. With your CR you should try for something similar. Remember, det=bad and timing=power... that should help you tune
Cobb Tuning Lightweight crank pulley for 99 2.5 RS Assassin4457 Normally Aspirated Powertrain 9 11-16-2005 12:35 AM
4 Sale (Sacramento) - Tune up parts for 01 2.5 RS. jotarou1 Bay Area Impreza Club Forum -- BAIC 0 06-05-2003 06:14 PM
Tuning a 2.5 RS? Imprezafan1 Normally Aspirated Powertrain 9 03-06-2003 04:22 PM
99 2.5 RS w/ S-AFC and ITC..help on proper tuning Murray Engine Management & Tuning 0 11-27-2002 09:32 AM
Tuning my Bro's 99 2.5 RS, Need help from Expert psaeko Newbies & FAQs 2 06-03-2001 06:08 PM
