Old 04-08-2003, 12:16 AM   #1
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Default stripping paint off of abs plastic
Anybody know of a stripper that is safe to use on ABS plastic to remove paint?
MAD REX is offline   Reply With Quote
Old 04-08-2003, 12:24 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
None that I know of since most will have ingredients that would probably melt the plastic as well. The safest thing to do would be to just sand it off. You don't necessarily have to sand down to the plastic, just down to the primer. Then you can just spray another coat of primer and wet sand before applying the color coat.
Calvin
cnk is offline   Reply With Quote
Old 04-08-2003, 12:26 AM   #3
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Ok if I have a front lip that got chipped and has peeled about 6 inches off the front...
Is it possible to sand down and prep that section, spray it, and clear coat everything?
Or should I sand the whole thing and repaint the whole thing?
I don't wanna have to do this again.
Old 04-08-2003, 12:31 AM   #4
cnk
Member#: 10757
You can sand that area down, prime it, and paint it. You'll have to spend some time feathering in the section with the rest of the lip. Then put on some clear coat and let it dry for at least 3 days. Then use some rubbing compound to bring the shine out of the clear coat. If it's peeling back, I would sand down to the plastic, then use adhesion promotor before using primer. Make sure you use paint with flex additive as well.
Calvin
Old 04-08-2003, 12:34 AM   #5
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Ok thanks, so just clear coat that section not the whole lip?
I got the paint from www.paintworldinc.com
Old 04-08-2003, 01:22 AM   #6
cnk
Member#: 10757
You shouldn't have to clearcoat the entire lip again. . just the area you re-painted. You'll have to feather the clearcoat as well. Then just use rubbing compound to blend the 2 together. Then polish and wax.
Calvin
Old 04-08-2003, 12:00 PM   #7
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Thanks for your advice!
Old 04-08-2003, 09:09 PM   #8
dunk
Member#: 15359
Sorry to butt into your thread, but what type and grade of sandpaper would be used for this. I have a c-west front lip with a similar problem.
-Duncan
dunk is offline   Reply With Quote
Old 04-08-2003, 09:32 PM   #9
cnk
Member#: 10757
You can use a 220 grit at first to get the paint off. When you wet sand, use something like a 600 grit. Then move on to 1000 grit if you'd like. Don't sand the final color coat or the clear coat won't have anything to stick to. You don't have to sand the clear coat as the rubbing compound will take care of that.
Calvin
Old 04-08-2003, 11:57 PM   #10
dunk
Member#: 15359
Just to be clear I intend to repaint the entire front lip.
So I would need to sand the entire lip with the suggested grits of sandpaper? The paint is competely peeled off on part of the lip. I suspect that no adhesion promotor and little to no prep work was done before painting. Should I sand the paint all the way down to the plastic again? If that is not the case, how do I smooth out the area where the paint has completely flaked off. I have a feeling that this condition will only continue to deteriorate, every day I go out to the car I find little bits of paint ready to float away in the breeze.
Sorry if I'm rambling a bit. Thanks for your time.
-Duncan
Old 05-18-2004, 01:17 PM   #11
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
Bringing this one back from the dead....
Does anyone know if you can blast some sort of medium (plastic beads, or walnut shells) on ABS plastic (specifically my side skirts) to remove paint?
Thanks!
-Nathan
crash is offline   Reply With Quote
Old 05-18-2004, 01:23 PM   #12
cnk
Member#: 10757
I would be very leary of doing that because plastic is so soft. The heat from using a blasting medium may deform/melt the plastic as well. The safest way is to just hand sand it down. Bodywork is an art and it takes skill, a good eye, and "feel" to get things right. If you blast it with a medium, you may also get a lot of high and low spots that you'll have to fill in to make it look even after painting.
Calvin
Will stripping cheap paint off of stock wheels with a heat gun damage the wheels? sburck Interior & Exterior Modification 6 11-10-2008 04:35 PM
Does anyone know where in DFW that would have access to large sheets of ABS plastic? extol1337 Texas Impreza Club Forum -- TXIC 7 04-01-2008 02:59 PM
how to get wax off of textured plastic? Bonzo Off-Topic 12 04-12-2005 01:04 AM
stripped paint off brakes, okay? petawabit Brakes, Steering & Suspension 2 05-16-2004 11:28 AM
Does anyone know where I can buy a 1/8" sheet of ABS plastic? MattDell Off-Topic 12 12-26-2003 11:58 AM
