Old 04-08-2003, 01:04 AM   #1
takumi
Member#: 6964
2001 impreza
pearl ridge blue
Default crank question
i was wondering if anyone know how strong is a 2.5 rs crank, i want to know how much power can it hold hold up , and how strong is the block, how much can it hold up.
the reason i am asking is b/c i have a 2.5 block and crank , and i want to build it up to a turbo motor. well here hear me out
i wan to take a 2001 rs block and crank
throw on 98 2.5 rs heads (dohc)
rs intake manifold
aftermarket piston,rods, valves, and etc
i plan to sleeve the block and lower the compression
what u think, would it be a bulletproof plan?
if this goes good, i will have rs heads, piston, rods forsale
takumi is offline   Reply With Quote
Old 04-08-2003, 04:23 AM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
get some WRX heads, the MY98 heads flow like crap
rhdude is offline   Reply With Quote
Old 04-08-2003, 08:38 AM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
The crank would be the last thing I would worry about.
You're going to kill your rods/pistons/rings/heads long time before you kill your crank.
The amount of main bearings and the smaller size of the crankshaft makes the bottom end very good.
Legacy777 is offline   Reply With Quote
Old 04-08-2003, 10:27 AM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
You may want to move this into the AFI forum but Legacy777 is dead on.
Old 04-08-2003, 11:50 PM   #5
obyone
Member#: 16523
The trans would go out long before the crank does.
obyone is offline   Reply With Quote
Old 04-08-2003, 11:53 PM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Out of curiosty, why would you want to throw on a set of 98 DOHC heads???
Eric SS is offline   Reply With Quote
Old 04-08-2003, 11:54 PM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Default Re: crank question
PS: how many A and how many B pistons will you have for sale. I might buy them
Old 04-09-2003, 11:51 AM   #8
takumi
Member#: 6964
2001 impreza
pearl ridge blue
cool thanks for the info,
first i thought of using 98 heads is b/c they are dohc unlike mine they are sohc, the other thing i don't understand is why would u use a ej20t heads which goes on a 2.0 litler and put it on a 2.5 litler it just doesn;t makes sence. the reason i thought of that was b/c i heard a wrx used 2.5 litler heads makes it so much better. but then again i am still looking in to this. so keep it coming.
i do plan to use aftermarket pistons and rods, like i stated, i kinda of knew that those are the parts that goes first, thats why i plan to sell them.
and i would not be selling my heads, rods, piston till the end of june or so , if u are interested please e-mail me at [email protected] so i can e-mail u back when i have them out, unless u can wait that long.
thanks for all the info, please reply with more info. thanks !
Old 04-09-2003, 12:56 PM   #9
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
the SOHC heads flow better than the DOHC heads and they are both 4-valve/cylinder heads. stick with your SOHC heads
Old 04-09-2003, 07:17 PM   #10
rhdude
Member#: 6637
The reason you want to go with the EJ20T heads is because they flow more... the EJ25 heads are built for N/A.. the WRX heads are build for Forced induction... I would almost say wait until you can get some EJ25 STi heads, but they have the variable cam's and you would need the STi ECU and you would only run into problems...
Old 04-09-2003, 10:04 PM   #11
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I honestly don;t have any flow numbers on the SOHC EJ25 heads or the EJ20T heads but I would be willing to bet that with the stock heads and cams, the EJ25's would flow better than the EJ20T heads.
Remember that the EJ25 heads and cams are made to supply enough air to a 2.5L engine that doesn;t have any help from a turbo but the EJ20T heads and cams are only built to supply a 2.0L engine that has help from a turbo, while also keeping it emmissions legal.
There is a reason that an EJ22T transplant with EJ25 SOHC heads and cams make so much more power than an EJ20T motor with the same amount of boost. It's mostly in the heads and cams of the EJ25.
Old 04-09-2003, 10:15 PM   #12
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
BTW, on Cobb's website, he has the stage 1 WRX DOHC cams listed at 208/206@.050 duration and .366 intake and .362 Exhaust.
on the stage 1 SOHC 2.5RS cams, he has it listed as 211@.050 duration and .410" Intake and .350" Exhaust lobe. the STOCK 2.5RS SOHC cams are .375" Intake and .310" exhaust with 232/236 degrees of duration (but this is advertised.
This tells me that the stock 2.5RS SOHC cams are already bigger on the intake than the stock WRX cams. I'm guessing that the stock exhaust duration is larger than the WRX exhaust stock duration which makes up for the lower lift and helps with scavenging. that's probably one main reason that they make so much more power stock for stock.
quick crank question wordlifewrx Built Motor Discussion 4 04-28-2009 12:19 AM
Crank Question waldo Newbies & FAQs 2 02-04-2009 09:58 AM
2.5 open deck on a TD04 stocker/crank question drrice Built Motor Discussion 1 09-27-2006 10:34 AM
wrx crank question silverstreakwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-20-2005 10:32 PM
wrx crank question silverstreakwrx Subaru Conversions 1 06-20-2005 02:57 AM
