Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 04-14-2003, 11:07 AM   #1
slinger99
Member#: 32217
Default short ram for sti.
does anyone know if a short ram intake will be able to replace the stock air box on the sti?
Also, does anyone think that these types of air intakes will hinder or improve hp. Regarding the wrx I have heard of both significant increases of hp and minimal losses as well.
I appologize if this has been previously posted.
slinger99 is offline
Old 04-14-2003, 12:10 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
it will screw up the air flow just like it does with the WRX .. sell it if you have one
due to the design of the stock intake aftermaket intakes will give incorrect air flow readings.. leaning out the mixture .. this is where the power comes from .. its just not a good idea
Jaxx is offline
Old 04-14-2003, 12:25 PM   #3
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
I have yet to see an Intake for the WRX thats has a proven gain most have lost a few HP. The factory intake flows extremely well anyway
DonA is offline
Old 04-14-2003, 02:23 PM   #4
briank
Member#: 3568
2002 WRX EcuTek
Default Re: short ram for sti.
Turbo cars don't need to "RAM" the air in, they have a turbo to compress it.
It is possible that by having a less restrictive intake, you could reduce lag, but as these other guys have stated, no one has produced an intake worth while for the WRX. The stock intake works fine.
Same probably goes for the STi. Its not running any more boost than the WRX.
-BrianK
briank is offline
Old 04-14-2003, 05:28 PM   #5
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The car makes 300 BHP. It is likely the stock intake is already quite adequate.
ANZAC_1915 is offline
Old 04-14-2003, 06:08 PM   #6
zacek
Member#: 19467
02 WRX
WR Blue
actually I suspect there are minor changes done to the plastic tubing to allow for a bit more air flow. There might not be more boost however a 2.5L engine will indeed suck in more air per second than the WRX. At either rate, yes of course, it all comes down to the modified MAF readings. It wil be a little while before an apropiate intake along with their corrected MAP (if any) is released.
But 1 thing that WILL HELP for sure is that piece made up by generationplastics.com and hopefully the very same piece will fit the STi. Hey.. $35-$45 is the best bang for the buck ever besides the 3/16" restrictor mod.
zacek is offline
Old 04-14-2003, 06:29 PM   #7
slinger99
Member#: 32217
Thanks for the info regarding the short-ram, just trying to find the quickest/cheapest way to 350hp
slinger99
Old 04-14-2003, 06:49 PM   #8
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
slinger99
I think 350 should be relatively simple. Throw on a turbo back exhaust, add some intercooler hoses, port and polish the throttle body and you should be there or pretty close. Might need an ECU reflash too, we don't know how well the US STi's ECU takes to mods yet.
Corn-Picker is offline
Old 04-15-2003, 12:24 AM   #9
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I think the quickest way to 350 BHP is a new boost/fuel/ignition map. Based on the components used I'd be surprised if anything else needed changing.
Glenn
Old 04-15-2003, 11:02 AM   #10
wrrrx
Member#: 23993
2004 STi, Surgeline
WR Blue
Okay, let's say you're greedy - what might be the fastest way to 400 hp??
Do you think a combo of the above mods (polished TB, hoses, turbo-back, and new maps) would get you to high 300's? Say 375hp?
Just wondering/dreaming...
Russ Rainforth
wrrrx is offline
Old 04-16-2003, 12:31 AM   #11
944 turbo guy
Member#: 12601
2004 WRX-STI and wrx
white on gold
Default think again......
Glenn
Glenn i know you of all people got under the car at the car show and saw how small the exhuast is,..so are saying the exhuast is adequate?....
Anyway, I will be replacing the intake tract that goes to the turbo with the unit from the S202, being as its much larger and will match (should match) better to this "new" secret turbo the car comes with. Other than that waiting for the word from Scott @ Prodrive USA as to when the 400hp kit will be available for the STI.( ECU, full exhuast, intercooler hoses, etc ) Adding a STI oil cooler kit and J-spec type RA front spoiler. 18 inch Prodrive forged wheels and AP 6 piston calipers with 14.4 inch motorsport rotors.
--nothin' special ,.just the regular stuff !!
Glenn, for sure you are at least doing cat back right,some Pagid pads, a drop in filter ??
944 turbo guy
944 turbo guy is offline
Old 04-16-2003, 05:45 AM   #12
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I think that just a full exhaust system (including headers) plus a ECU remap would = 350hp or more. Especially considering how much power simular mods for the WRX effect it...
Kostamojen is offline
WTT APS short ram for Another Short Ram Thran SCIC Private Classifieds 11 11-14-2006 07:03 PM
K&N Typhoon Short Ram for WRX/STi Group Buy! Z1 Performance Vendor 'Group Buy' Classifieds 186 09-11-2005 07:13 PM
SOCAL WTB short ram for 05 sti iluvmywife Private 'Wanted' Classifieds 0 07-02-2005 05:10 PM
KS: WRX/STI AEM Cold air intake and Short Ram for sale MPOWERD Private 'For Sale' Classifieds 3 10-08-2004 02:04 AM
FL: Short ram for WRX/STi QwikRex Private 'For Sale' Classifieds 8 11-24-2003 06:10 PM
