Old 04-08-2003, 06:14 PM   #1
kaos200
Member#: 2692
Default Injectors 99 RS -> WRX?
If WRX and STi injectors fit 99 manifolds, does that mean my RC engineering injectors on my 99 manifold will fit a wrx manifold and rail?
thanks guys
Kian
kaos200 is offline   Reply With Quote
Old 04-08-2003, 09:13 PM   #2
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
Talking
YES!
Mariano is offline   Reply With Quote
Old 04-09-2003, 01:59 AM   #3
kaos200
Member#: 2692
Originally posted by Mariano
YES!
how did you find out? did you try it?
thanks
Old 04-21-2003, 04:48 AM   #4
kaos200
Member#: 2692
bump
Old 04-23-2003, 12:52 AM   #5
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
NO THEY WONT!
The WRX fuel rails have smaller inner diamiters.
When you install WRX injectors into a 99 you have to use the big fat o-rings off of the RS so that they will seal in the rail.
The body of the RC injectors will be too big to fit inside the WRX rail.
PunKidd is offline   Reply With Quote
Old 04-23-2003, 01:26 AM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
thats what she said
Ben
Old 04-23-2003, 03:39 AM   #7
kaos200
Member#: 2692
does anyone know what Ill need to do to use 99RS (RCeng) injectors in a wrx manifold?
Old 04-23-2003, 01:32 PM   #8
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Either a 99 fuel rail or a set of WRX RC injectors. Sorry if that's not the answer you were looking for.
Old 04-23-2003, 02:27 PM   #9
kaos200
Member#: 2692
that actually makes me really happy
I have vishnu rails right now for my 99, and dont want to have to buy another set for the wrx heads
Kian
Old 04-23-2003, 08:21 PM   #10
PunKidd
Member#: 8533
2002 2.5 RS-T
Are the injector bungs on the intake manifold the same distance apart on the RS as the WRX?
Old 04-23-2003, 09:23 PM   #11
kaos200
Member#: 2692
yes, just need different mounting brackets, and dont know what needs to be done to the bottom of the RS injector to make it fit the wrx manifold.
Kian
Old 04-23-2003, 09:34 PM   #12
PunKidd
Member#: 8533
2002 2.5 RS-T
I imagine that they are almost identical, bings the tip of the WRX injector doesn't have to be modified to fit into the 99 manifold.
99 legacy-> wrx swap scubienick Subaru Conversions 2 10-24-2008 10:19 AM
RS ---> WRX Brake Rotor Conversion Mods Page Up, Part #'s Included North Ursalia Brakes, Steering & Suspension 16 06-05-2002 07:56 PM
RS -> WRX front brakes, SS lines, Valvoline Dot 3 & 4 fluid DoorKnob Car Part Reviews 0 02-18-2002 07:23 PM
RS -> WRX swaybar swap DDMan Brakes, Steering & Suspension 5 01-28-2002 04:13 PM
RS -> WRX airbag swap.... DoorKnob Bay Area Impreza Club Forum -- BAIC 0 10-28-2001 12:30 AM
Message Board Statistics All times are GMT -4. The time now is 02:33 AM.
