Old 04-08-2003, 06:47 PM   #1
imprezive
Member#: 746
Default $1000
Well it looks like my finanaces may not be quite capable of purchasing any form of forced induction. So I need some Ideas
Current Mods:
Engine:
Cobb CAI
Borla Header
Blitz Nur-spec exhaust
Cobb Cams
Suspension:
Kyb agx
H&R springs
Whitline adjustable anti-sway bar
Brakes: Drilled Fronts with carbon fiber brake pads
Drivetrain:
Kartboy short shifter and bushings
exedy clutch and flywheel
Basically I have another $1000 I'd like to spend
on the engine what are my options
I know the chip and UD pulleys are options, but is there anything else (NO NOS) that can give me some more HP
PS> I'm gonna get some better brakes too. Not happy with the drilled rotors
imprezive is offline   Reply With Quote
Old 04-08-2003, 07:01 PM   #2
JC
Member#: 692
2011 Grand Cherokee
Triumph Speed Triple R
High flow cat, throttle body.
JC
JC is offline   Reply With Quote
Old 04-08-2003, 07:05 PM   #3
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
Hm, you seem pretty well-covered already!
For your next mods, I suggest:
1) ProECM or TC2v.X -- I'm going to buy mine pretty soon. An easy increase in HP throughout the power-band and some high-end kick as well, or so I've been told.
2) New tires -- Throw out the RE92s if you still have them. I stumbled upon a cheap set of Michelin Energy MXV4 +s and bought them on impulse...even though they're not the best "sports" tire to choose, they do much better in all conditions than the RE92s and provide a more comfortable ride. I suggest Kumho 712, Sumitomo HTR+, or Falken Azenis. They won't eat up the whole $1k!
3) Lightweight Crank Pulley -- Installing my Mr. Josh's lightened crank pulley was a pain in the arse, but let me tell you, even my parents can feel the power increase to my AT 2.5 RS, while in the passenger's seat! Best bang for the buck mod I've done thus far.
4) Ground mod -- See the SPG thread for more info.
5) High-flow cat like a Random Tech -- The only missing link in your very nice exhaust sytem
Hope this helps! Let me know how you like those Cobb Cams, too, I'm interested to see if they're worth the dough.
DrBoy01 is offline   Reply With Quote
Old 04-08-2003, 07:45 PM   #4
joefocker20
Member#: 13745
2015 STI
Well, I'd skip the chip, hold out until Cobb has the AccessFlash available for 2.5s. Other than that, a high flow cat would be a good idea, Mr Josh 43's Pulley is a very good deal, or save more $$$ and get some heads..
joefocker20 is offline   Reply With Quote
Old 04-08-2003, 09:05 PM   #5
imprezive
Member#: 746
I have 5zigen FN01R-C wheels (16lbs)with kuhmo 712s
and I don't have the blitz exhaust on yet, it is in the mail, but I will have the in between part of the exhuast done custom with a high flow cat.
Could I maybe get stiffer valve springs and raise my rev limiter, or maybe higher compression pistons?
I don't know much about engine internals (just bolt ons)
Old 04-08-2003, 09:06 PM   #6
imprezive
Member#: 746
crank pulley's are not the sames as underdrive pulleys?
the N1 pulley kit doesn't include a crank pulley?
Old 04-08-2003, 10:11 PM   #7
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
It does, but the N1 kit is overpriced and the best bang-for-the-buck is to just get a lightened crank pulley.
What's the Accessflash from Cobb? I've seen it mentioned before but I don't really know anything about it :P
Old 04-09-2003, 01:56 AM   #8
joefocker20
Member#: 13745
2015 STI
Well, its ECU reflashing I would guess that is similar to a Unichip without an additional module. You can probably change the timing, a/f ratio, and redline. I dont know what else you can change, but check out Cobb Tuning's Webpage, they have info on it. The chip dosent make a consistent and worthwhile difference in my opinion. I think ECU Reflashing, a Stand Alone ECU, or a Unichip will offer much better gains when combined with an aggressive N/A build.
Old 04-09-2003, 09:45 AM   #9
FstEddie22
Member#: 10938
2001 Impreza 2.5RS
Silverthorn Metallic
Default Cams
Imprezive,
I was wondering what you thought of the Cobb Cams and where you got them installed. I was thinking about getting some and I live in Gainesville. Not too far from Deltona.
Thanks,
Ed
FstEddie22 is offline   Reply With Quote
Old 04-09-2003, 11:37 AM   #10
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I'd say, highflow cat, and ecu reflash...
the next steps are FI after that, maybe heads, but those aren't cheap.
AO
m750 is offline   Reply With Quote
Old 04-09-2003, 01:07 PM   #11
joefocker20
Member#: 13745
2015 STI
Well, you can buy upgraded valvesprings and titanium retainers and raise your redline to a max of about 7000 rpms. Anything higher than that, you're going to have the bottom end also..
Old 04-09-2003, 04:02 PM   #12
imprezive
Member#: 746
Tom from ludespeed did my install. $300 His "shop" is in orange city, right next to deltona.
Old 04-09-2003, 04:16 PM   #13
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
You could almost do a turbo for that and there's always n2o
Old 04-09-2003, 06:06 PM   #14
imprezive
Member#: 746
I don't beleive in doing anything halfway, and I need my car to go at least 200,000 miles with no MAJOR engine problems. So there is no way I could get any reliable form of forced induction for $1000-1500
Old 04-09-2003, 06:12 PM   #15
imprezive
Member#: 746
Oh yeah DrBoy
I LOVE the cams, my favorite mod so far. The only mod that I REALLY could tell a difference in the "butt dyno"
Although My CAI sounds really sick. And I'm sure I'll love the sound of the blitz exhaust, but power wise the cams are the best.
It pulls big time past 4000rpms
Old 04-09-2003, 07:38 PM   #16
joefocker20
Member#: 13745
2015 STI
You can also get some lightweight bumper beams for $120 bucks.. You cant "reliably" turbo your car for that much. To reliably turbo an RS to hold up for the long haul, you'll need to lower the compression, close the deck, and a bunch of other things. I figure it would cost at least 7000 to reliably turbo your car if you're handy.
Old 04-10-2003, 09:10 AM   #17
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
I did, including engine management and clutch. It can be done if you play it conservative and buy good used parts. Shoot, my fuel system and electronics will support more power than my internals or tranny will take. The turbo I'm using is very small (too small) but upgrading is just a matter of $$/time away. With the influx of OE WRX parts you can to a custom built turbo reliably for $1000-$1500.
That being said, if you're looking for strictly N/A performance you should really look at a l/w flywheel/clutch combo. Everything you have right now will translate to F/I if you choose to do so later (you do have the street cams right?). I had a very similar setup to you (except I had a UD pulley, ProECM, and a few other mods) and they transitioned to F/I very well. The only thing I wish I would've done different is installing a flywheel/clutch while still n/a.
Old 04-10-2003, 03:23 PM   #18
imprezive
Member#: 746
I don't have the knowledge to properly tune that kind of setup. It is possible if you know what you are doing. And I don't a wrx setup when I have a lower redline and more displacment. I would rather a kit desinged for a RS.
PS I already have a lightweight flywheel. and clutch.
PPS> Nothing is set in stone. I might still go forced induction. I just want to know my options. It kinda depends of how long I can live off ramen noodles
Old 04-10-2003, 05:02 PM   #19
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Just noticed you're from Fl. You may want to email Graham, he's a FL native but goes to school here in Texas. He might have some local shops for you to check out for labor, etc. He also did a DIY "kit" and he was my inspiration. Just keep the option open and it looks like you have (street cams, etc) all will compliment F/I very well when you turn to the dark side
Old 04-10-2003, 06:04 PM   #20
imprezive
Member#: 746
tom's shop (ludespeed) is only 10 minutes from my house, so he can help me with the install. Or just bribe the JAX mod squad to help me
Old 04-11-2003, 04:32 AM   #21
Basshead
Member#: 112
2011 Jetta TDI
random tech cat....300
then spend the rest on some dba wrx sized slotted rotors(400) for the front and a h6 rear upgrade(200)... and throw some axxis ultimates(120) on those calipers...now you can stop too!!..so i went a little over budget
Basshead is offline   Reply With Quote
Old 04-11-2003, 05:40 AM   #22
imprezive
Member#: 746
I have the Cats taken care of!
Old 04-11-2003, 09:56 AM   #23
nySulli
Member#: 32617
2008 STi
go for a set of gfb pulleys, replaces the alternator, crank and power steering pulleys with smaller, nonunderdriven ones, buddy of mine just put them on his wrx and said his engine response is MUCH better now, and felt a small improvement in power.
then go after the brakes, or the ecu reflash when its available
nySulli is offline   Reply With Quote
Old 04-12-2003, 04:16 AM   #24
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
If you do much canyon carving or autocross, you'll benefit from racing seats & harnesses. You'd be amazed at how much faster you can corner when you're not white-knuckling the steering wheel trying to hold on...
-s-
things to look at:
throttle body coolant bypass, lightweight stuff (bumper beams are said to make a big difference), or save for Cobb heads, or maybe the DNT supercharger kit that's coming soon.
scotty305 is offline   Reply With Quote
Old 04-12-2003, 08:37 AM   #25
imprezive
Member#: 746
Yeah I guess the only the other option is to go lightweight.
thanx
