Old 04-08-2003, 09:53 PM   #1
03mbpREX
Member#: 33953
2015 STI
Default advice on how to read A/F guage?
I just installed autometer boost and A/F guage, i know how to read the boost, but kind of confused on how to read the A/F guage, theres lean, and rich, and it jumps back in forth, please give me some insight, thanks alot
03mbpREX is offline   Reply With Quote
Old 04-08-2003, 10:18 PM   #2
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
Default Re: advice on how to read A/F guage?
0-1 volt O2 sensors like our rear sensor are only useful for tuning emissions. They're designed to be accurate only at about a 14:1 A/F ratio. That's the ratio where you get near perfect combustion, so there's no fuel left in the charge. That's not where you tune for power. Basically the only thing it's good for is telling you if you're running super super lean. If you have your foot to the floor and that thing isn't in the green, then you have problems.
If you have cats before the O2 sensor then that things gonna read lean. If that's the case then the thing is completely worthless.
I have one though. It looks nice, I guess that's the only practical use for it.
kenshiro is offline   Reply With Quote
Old 04-08-2003, 10:42 PM   #3
teiva-boy
Member#: 22825
If you haven't also installed an additional 1V sensor pre-cat/post turbo.. the readings are flawed.
teiva-boy is offline   Reply With Quote
Old 04-08-2003, 11:19 PM   #4
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
Yeah the top of the downpipe is a sweet spot to put a bung. I just did that tonight.
Old 04-08-2003, 11:23 PM   #5
teiva-boy
Member#: 22825
I've got two bungs.... Err, that came out wrong
Old 04-09-2003, 02:25 AM   #6
KapaFool
Member#: 2679
2010 WRX4FD
How much accurate would the A/F gauge be if the sensor is installed into a catless uppipe? I am reading lean at WOT so far.
KapaFool is offline   Reply With Quote
Old 04-09-2003, 02:29 AM   #7
atomicapples
Member#: 12626
02 2.5 rs
i was always told that the a/f is installed after the turbo.
atomicapples is offline   Reply With Quote
Old 04-09-2003, 04:02 AM   #8
teiva-boy
Member#: 22825
You are correct. Putting it pre-turbo can influence it's readings due to the high pressure the sensor sees. Jon in[CT] has a great post about this somewhere.
Old 04-09-2003, 12:05 PM   #9
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
What's with all the A/F thread all of a sudden?
Anyway most aftermarket O2 sensor work the best at around 600 C which works out to be 12-18" from the turbo in the downpipe. Don't put an O2 before the turbo as there is positive pressure and the reading will be wrong.
mbiker97 is offline   Reply With Quote
Old 04-09-2003, 12:28 PM   #10
codean
Member#: 10186
All the autometer A/F gauge is good is blinking lights unlike the greddy A/F gauge which works ok.
codean is offline   Reply With Quote
Need advice on how to install gauges on A-pillar maxpower_454 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-06-2005 10:19 AM
Need advice on how to drain my hog imprezton Off-Topic 52 01-03-2005 09:49 AM
Need advice on how to train my dog timo Off-Topic 42 12-31-2004 04:58 PM
Need advice on how to deal with wapce mklier1218 Off-Topic 33 09-22-2004 12:32 PM
