Old 03-26-2001, 04:34 PM   #1
au112
Member#: 4412
MY01 Impreza 2.5RS
BRP
Smile Body care
i wonder what brand of cleanser and wax you prefer for your car?
Can you name the brand, the type, and also the steps for the procedure?
Thanks all.
au112 is offline   Reply With Quote
Old 03-26-2001, 05:53 PM   #2
Jazz95
Member#: 4600
Da Ridge
Racer
Cool
Well, my brother sells Amway products, and they make a great car wash. It's called Mint Condition. It is sooo nice. Just wash as you normally would. It even removes bugs and tar without bug n tar remover.
I've tried almost every wax product out there, and I can tell you that Meguiar's is hands down the best. Stay away from that Prolong Paint Sealant stuff, cause it will take the paint right off your car. I usually use a coat of cleaner, then two coats of polish wax. The shine is unbelievable. In between waxes I use the Meguiar's Quick Detailer, and it keeps it nice.
As for upholstery, I use Blue Coral Dry Cleaner. This stuff was made by the man upstairs. However, don't follow the directions on the can, because it tells you to let the foam sit for 15 minutes. Get yourself a Shop Vac, a detailers brush, and a bucket of water. As soon as you have sprayed your desired area, use your scrub brush to thoroughly cleanse your joint.
I know this sounds like an infomercial, but it really works, trust me.
Just an opinion I guess.
Jazz95 is offline   Reply With Quote
Old 03-27-2001, 12:37 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
Meguiar's...
i should have stock in them!
*detail clay
*paint cleaner
*polish
*wax
*car wash
*tire shine
*wheel cleaner...
i could go into business for myself!
very good brand, very good stuff...
j. www.subiegal.com
Old 03-27-2001, 02:54 AM   #4
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
Post
Use Meguir's 1-2-3 Step Cleaner/Polish/Carnuba... seen pictures on this board of ppl that used it. NICE and worth ur buck and ur ~2hours.
STi-Nismo Dood is offline   Reply With Quote
Old 03-27-2001, 07:31 AM   #5
nick dickitt
Member#: 4532
Post
http://www.zainobros.com/
Check this..............
nick dickitt is offline   Reply With Quote
Old 03-27-2001, 01:28 PM   #6
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
Never buying Meguire's crap again...
Their clay bar sure worked, by the end of the first swipe there was no clay left on the bar.... it was all over my car! Took me about an hour to scrape it all off then buff with wax to get the specs of clay off.
Lousy!
Sucks!
I use Mother's Carnuaba wax and whatever car wash soap I have lying around.
Don't forget the RainX on the windows!
remarcable is offline   Reply With Quote
Old 03-27-2001, 02:02 PM   #7
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Post
Did you use the clay after spraying the area with the detailing spray bottle...the liquid will make the area frictionless and allows the claybar to do its magic...Clay bars are like magic...even if you run your hands on a hood that has been wax, you will feel some fine grits...use the clay bar on half of the hood and then was/polish...you can defiently feel difference...SWEEEERTTTTTT!!!
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 03-27-2001, 02:12 PM   #8
Pinoy
Member#: 400
1990 300ZXTT
Post
Ditto what Ken said. You prolly forgot to spray before using the clay bar. Whew, bet you were tired after all that buffing Detail clay works wonders!!! (when used with detail spray) heheheh
Pinoy is offline   Reply With Quote
Old 03-28-2001, 11:32 AM   #9
MattJP
Member#: 1280
Post
Be careful with the clay bars because it is real easy to add scratches to the finish if you get road grime/grit caught up in it. Body shops will use it to remove overspray. A good cleaner/polish, such as Meguires, contains a very fine abrasive particles which actually smooth the surface coat. Follow up with a coat of wax containing good grade carnuba, again, something like Meguires.
Use a good quality 100% cotton cloths, like diapers or especially flannel.
Do not do the 'wax on, wax off' circular motion unless you like circular swirl marks in the reflections. Apply and remove as air would flow over your vehicle (for that all important HP bump). And speaking of swirls, use a good glaze such as fill 'n glaze prior to the protective wax coat.
Hope this helps.
MattJP is offline   Reply With Quote
I don't give a crap about that storm, I don't care about that tornado... doubledribble Off-Topic 17 06-03-2010 11:12 AM
Body Care subaru_steve Newbies & FAQs 5 03-09-2010 09:44 PM
What kind of body care products do you use? rice h8r Off-Topic 26 01-14-2009 06:44 PM
Couple ?s' body damage, and water spot care subby00 Interior & Exterior Modification 2 09-17-2004 12:59 AM
A gc8 body mod idea ... anyone care to photoshop it? funscooby Interior & Exterior Modification 9 12-20-2001 10:42 AM
