Old 04-09-2003, 09:55 AM   #1
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Arrow Legacy Turbo 5MT into 4EAT WRX
Just sort of starting a place-holder thread in here for the work I'm doing to put a Legacy Turbo 5MT transmission into a 4EAT WRX.
Current plan:
Gearbox/flywheel/pressure plate/shifter/linkage - stock Legacy Turbo
Rear diff - ring/pinion swap from 3.9 open into current 4.11 LSD
Pedal box - WRX salvage
Clutch master cylinder - WRX salvage
Propshaft - WRX salvage
ECU - unknown if it needs replacement or just modification
Starter - Legacy Turbo salvage
Crossmember - unknown .. where should this come from?
/Andrew
Kha0S is offline   Reply With Quote
Old 04-09-2003, 10:35 AM   #2
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
one thing, Andrew. the tranny you're going to be installing has a mechanical speed sensor, and your old one has an electronic one. may want to look into this since it could be trouble down the line.
-IggDawg
IggDawg is offline   Reply With Quote
Old 04-09-2003, 11:54 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
also the starter is differnt
are you shure you want to put an OLD tranny in to a new car
Old 04-09-2003, 12:07 PM   #4
IggDawg
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
the legacy turbo 5MT is much better than the 2001 RS 5MT. it was made to take a little power, whereas the RS tranny was meant for a 80 hp car. the only better one to get would have been the WRX 5MT, but I don't think he could have gotten it for the same price .
-IggDawg
Old 04-09-2003, 07:11 PM   #5
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
Sean is offline   Reply With Quote
Old 04-09-2003, 07:13 PM   #6
Kha0S
Member#: 8808
2011 WRX
DGM 5D
The WRX transmission is also a bastard child, with a 3.9 front final, 3.45 rear final, and 1.1 center, instead the Legacy Turbo tranny is 3.9 all around, which sets me up for a STi 6MT swap in the future.
Similarly, the Legacy Turbo gears are all shot-peened, and the case is actually thicker than the WRX transmission. While heavier, this should minimize the case flex that tends to yield gear misalignment and broken teeth.
Putting the stock Legacy flywheel, clutch, and pressure plate in is probably a stupid idea, but it's cheap, and I'll just take it easy on it until I figure out what I want to do later on.
I just got a speeding ticket for ... well, a lot of money. A few hundred dollars. So my budget is only getting smaller.
/Andrew
Old 04-09-2003, 07:37 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Did the legacy turbo have hill holder?
Old 04-10-2003, 10:23 AM   #8
Kha0S
Member#: 8808
2011 WRX
DGM 5D
I don't know, but probably. What problems do you think that might introduce?
/Andrew
Old 04-10-2003, 04:58 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hill holder ..
... is independant of the tranny
Old 04-10-2003, 06:20 PM   #10
ciper
Member#: 15543
90BJ Legacy LS ABS
True its not internal, the clutch cable attachment bracket is different.
Legacy turbo tranny into WRX? snicker Transmission (AT/MT) & Driveline 4 10-03-2009 03:40 PM
Legacy GT turbo trans into 06 WRX Mechie3 Transmission (AT/MT) & Driveline 1 08-16-2008 12:17 PM
05 wrx 5mt into 02 wrx - can i use my 02 front axles? LatentWagen Transmission (AT/MT) & Driveline 5 05-29-2006 10:14 AM
What years had hydraulic clutches? (99RS 5mt into 4eat wrx) Geek Guy Transmission (AT/MT) & Driveline 7 07-12-2004 05:56 PM
Looking for info on swap of Legacy Turbo 5MT into 4EAT WRX Kha0S Transmission (AT/MT) & Driveline 0 03-24-2003 10:24 AM
