Old 04-09-2003, 11:28 AM   #1
Stroke
Member#: 12208
1998 Pick'm up truck
Default Best Parts for N/A Build up!
I have a dohc MY98, and I was just wondering:
What're the best parts for badass power?
What kind of power can I expect?
How much will it set me back ($)?
Stroke is offline   Reply With Quote
Old 04-09-2003, 11:35 AM   #2
NotAnRS
Member#: 1004
2002 Forester L
Scratch-n-Dent Blue
1) turbo kit
2) 200-250hp or beyond
3)$2-5k depending on kit
Normally aspirated?
You can spend $600 on headers, $500 on exhaust, another bazillion $ on cams, flywheel, head work, underdrive pulleys and get...maybe 185-200hp.
Sad but true, building a n/a Suby motor is a losing proposition.
NotAnRS is offline   Reply With Quote
Old 04-09-2003, 01:01 PM   #3
dcoty
Member#: 3149
01 V7 GC/R32 sky
Here is the "everything possible" N/A build up plan. This is my engine which is being installed as we speak (er...type) and the car will be back to me tomorrow if all goes well.
strommung cat back 2.25"
random tech high flow cat
borla headers
cobb cai
UD pulley
Closed deck block
lightend/balanced/knife edged crankshaft
custom billet con rods from Oliver
custom 11:1 compression pistons from CP (coated for future nitrous use)
Bored out to 2.55+ litres (torque plate boring)
custom ported and poished cylinder heads
Cobb racer camshafts
ported/port matched intake manifold
Cobb springs
Cobb retainers
custom made stainless valves (3 angle valve job)
fully blurprinted
fully balanced
Tuned with Unichip
Redline set at 8,000-8,500 rpm
9lb flywheel
ACT clutch
STi engine mounts
STi tranny mounts
ARP Head studs...not bolts anymore.
Upgraded fuel pump
SVX fuel pressure regulator
NotAnRS- Its not a losing proposition, this will make over 250hp. I do understanfd the cost/benefit ratio, but im just showing that it can be done if done right.
Dan
dcoty is offline   Reply With Quote
Old 04-09-2003, 02:56 PM   #4
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
Talking
Dcoty--
Please please please please, whenever you get a chance to drive your car with the new engine, let us know how it runs
DrBoy01 is offline   Reply With Quote
Old 04-09-2003, 03:33 PM   #5
iON Performance Inc
Vendor
Member#: 7673
strokefactor - We have a complete DOHC EJ25 N/A engine valve train & bottom end supporting mods available.
We have DOHC specific high rate valve springs, Ti retainers, custom lash caps, bucket sets, cams, adjustable cam gears, high compression forged pistons etc (10.5:1-up), equal-length header-back systems, head porting options etc.
It depends on how wild you want to get. Feel free to drop us an email -> [email protected]
iON Performance Inc is offline   Reply With Quote
Old 04-09-2003, 03:58 PM   #6
Stroke
Member#: 12208
ion performance Inc - do you have an online catalouge?
dcoty - that's beautiful. Yes! please get back to us, and whenever you can, post the graph of dyno tuning!
Old 04-09-2003, 04:18 PM   #7
iON Performance Inc
Vendor
Member#: 7673
strokefactor - our online catalogue isn't fully done yet. However, we can send you pictures etc if requred. Our N/A developments are done in conjunction with TWE, our DOHC EJ25 N/A parts will be featured on Irish Mike's MY02 2.5RS that will be racing in the SCCA Road Racing circuit.
Old 04-09-2003, 04:47 PM   #8
dcoty
Member#: 3149
01 V7 GC/R32 sky
Ill keep everyone very well informed, when I get it back, ill post a new thread. Please pray for easy tuning!
Dan
!!ADVISE!!! Best parts for my ej20 build.. Boxer4h Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-17-2010 12:45 PM
would you rather... turbocharge, supercharge or NA build up wop Normally Aspirated with bolt-on Forced Induction Powertrain 26 06-26-2008 02:35 AM
NA Build up need help HopesAndDreamsRacing Normally Aspirated Powertrain 3 05-28-2007 09:14 PM
Ej22 2.2 NA Build up Info Needed! wildfire Normally Aspirated Powertrain 13 04-25-2005 01:12 PM
NA Build-up '99 RS Drifter Normally Aspirated Powertrain 5 05-10-2002 03:41 PM
