Old 04-09-2003, 03:43 PM   #1
protouring72
Member#: 13190
02 Vishnu Stage 2
Default Anyone experiencing backfiring with Vishnu Stage 2 or similar set up?
Just curious, i have a Vishnu Stage 2 and get some backfires occasionally when I rev-match to downshift and sometimes between gears when up-shifting. Is this normal? Am I running rich or something? Any comments or input would be appreciated.
John
protouring72 is offline   Reply With Quote
Old 04-09-2003, 03:46 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Hey John,
It's Calvin. . we met a while back. Most people that have removed cats on their cars will get afterfiring, which is what you're hearing. Even a stock car gets this, but the cats usually drown out the noise. With a catless or highflow cat setup, you will hear it more often. I get it as well on my Stage 1 setup. Nothing to worry about. If you backfire, i.e. explosion in the intake tract, then I would worry. If it's just popping noises when you let off the throttle during shifting, it's just un-burnt fuel igniting in the exhaust.
Calvin
cnk is offline   Reply With Quote
Old 04-10-2003, 10:15 PM   #3
protouring72
Member#: 13190
02 Vishnu Stage 2
Hey Calvin,
Thanks for the response. It did this occasionally, but now it seems to be more frequent, maybe it's the changing of the seasons. I even put on my stock BOV so it would recirculate and not run rich between gears. I'll just ride it out!
Thanks again,
John
WANTED: STock WRX rims with all season tires or similar set fenix327 Mid Atlantic Impreza Club -- MAIC 0 12-04-2003 11:57 AM
UTEC stage 4 map with Vishnu stage 2? ChrisWRX Engine Management & Tuning 1 12-25-2002 02:26 AM
anyone in alberta have vishnu stage zero or sub zero? soon2bwrx Canada Region Forum 8 12-03-2002 12:08 PM
Anyone running Cobb's power package stage 2 or stage 3 with no CEL problem? V6 Normally Aspirated Powertrain 9 05-18-2002 10:52 PM
For those 99-01 RS owners with Cobb stage 2 or 3, will CEL come up? V6 Normally Aspirated Powertrain 2 05-03-2002 01:53 PM
