Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-10-2003, 12:10 AM   #1
Craig_99GT
Member#: 24031
1999 Legacy GT LTD
Black/Deep Purple
Default Idle Problem
I recently had some work done which required the removal of my engine. I had my local mechanic work on it and He did a great job, however now my engine is "hunting" for an idle. It jumps between 300 and 600 rpm back and forth. I almost think its a vacuum line problem for some reason.
Does anyone have any ideas or suggesions as to what might cause that...
Thanks
-Craig
Craig_99GT is offline   Reply With Quote
Old 04-11-2003, 11:39 AM   #2
Pocon
Member#: 17479
1999 Impreza WRX
Silverthorn Metallic
Did your mechanic plugged in the MAF sensor correctly? Either it is not plugged correctly or it may be damaged.
Check the vaccum lines for sure.
Pocon is offline   Reply With Quote
Old 04-11-2003, 12:59 PM   #3
Craig_99GT
Member#: 24031
1999 Legacy GT LTD
Black/Deep Purple
are there any vacuum lines specifically I should check? I looked it over a little and it looked okay but im not sure exactly what to look for. I'll check the MAF now
-CB
Weird idling problem - Very high idle Oodles-of-Noodles Mid Atlantic Impreza Club -- MAIC 21 02-04-2010 10:25 PM
Crap Idle Problem, Can't hold idle, sometimes dies when I push clutch in TROLL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 91 09-02-2008 09:40 PM
Idling problems and wierd Cel problem.. Help please SPOOLME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-26-2008 02:07 PM
Update on my idle problem Warp3 South East Region Forum 0 01-06-2001 09:47 AM
idle problem - with A/C on svxxx-26 SVX Forum Archive 7 11-21-2000 06:43 AM
