Old 04-09-2003, 11:49 PM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Angry Weird thing happens when trying to gas up while on empty. gas doesn;t go in!
Since there is still no "Generic subaru technical questions" thread (which I have been fighting for ) I will post this here.
This is REALLY weird and I can't figure it out.
When my car is really low on gas (gas light is on), there is ONE PARTICULAR STATION (76 station) that I can't seem to fill my car up with.
It's weird. I will put the nozel in and when I press it down to start filling, it goes for about 2 seconds but then clicks off (like when you are full) and I can hear air rushing out of the tank... If I do this enough (like maybe 5 times) a little gas will start to spew out of the opening. but my car is still empty.
SO, I go very slow until I get about 3 gallons in the car and then I can fill it fast just like normal at full speed.
I use this gas station because it is right next to work and it is the cheapest GOOD gasoline station I know of. It is worth the little hastle.
The weird thing is that this doesn;t happen on empty at any other gas station. Only this one.
Has anyone else had any wierd circumstances happen while trying to put gas in your car when it is on empty? I am totally stumped.
Thanks!
Eric SS is offline   Reply With Quote
Old 04-10-2003, 01:01 AM   #2
watcher in the sky
Member#: 3513
1997 Legacy Outback
not in the rs... but in the Grand Vitara i once had.. it did that.. i figured it came from the length of the nozzle itself.. and MAYBe the gas was "bouncing" off the walls of the filler back into the nozzle.. shutting the pump off. .. or something.. dunno..
watcher in the sky is offline   Reply With Quote
Old 04-10-2003, 01:12 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I have tried putting the nozzle in only a little bit and it doesn;t make a difference.
Old 04-10-2003, 01:20 AM   #4
watcher in the sky
Member#: 3513
1997 Legacy Outback
hmm.. that station sucks?
Old 04-10-2003, 08:03 AM   #5
Monas
Member#: 31418
1999 2.5RS
i have had that happen a few times as well, i cant remember if it was at a specific companys station tho. it was on a road trip.
but it is very odd.
Monas
Monas is offline   Reply With Quote
Old 04-10-2003, 08:23 AM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I've had that happen on other cars as well as mine.
The best I can figure is that when you have very little gas in the tank you end up with a lot more fumes. When you go to fill it up the gas takes the place of the fuel vapors, which want to come out the filler opening.
Modern filler nozzles have an auto shut-off. Most likely the fumes are kicking that auto shut-off.
That station is probably just more sensitive then others.
Do they have multiple pumps.......have you tried other pumps at that same station?
Legacy777 is offline   Reply With Quote
Old 04-10-2003, 05:27 PM   #7
SAND_MAN1
Member#: 31535
2007 F150 Harley Dav
2003 Legacy GT
I had that same problem just this past week, never had it before and I had been to that same pump at the same station many times before, it was frustrating to say the least, I just finally threw in about 10 gallons and will probably fill it back up tomorrow at a DIFFERENT station that I usually hit up as well. Wish I knew the answer as to why it happened.
SAND_MAN1 is offline   Reply With Quote
Old 04-11-2003, 11:47 AM   #8
zoinkssooby
Member#: 18910
2000 mr2 spyder
damn, i thought i was the only one with this trouble but, mine seems a bit worse.
for the past 2 months it doesn't matter where i fill up except a chevron thats $0.10 more than everywhere else. damn valve kicks at about 3/4 full and wont lemme add more without kicking every 2 seconds. i've even sat at a station for 15 mins and tried again with no luck. even when my needle wasnt all the way up.
one thing that was pointed out to me was that my gas cap is not oem and is causing trouble (non-stop CEL) with vapors and such. once i get it replaced i hope it makes a difference.
zoinkssooby is offline   Reply With Quote
Old 04-11-2003, 02:00 PM   #9
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
I had a problem like this with another car I had, it was attributed to the style of the pump nozzle.
I had a problem with pumps that have the fat rubber boot on them. Try pulling it back away from the car while you pump. It keeps the nozzle "triggered" as well as letting the vapors escape.
RokketRide is offline   Reply With Quote
Old 04-11-2003, 06:11 PM   #10
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
That's what this one has. Thanks for the tip!
Old 04-11-2003, 06:20 PM   #11
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
I remember seeing at Pep Boys or something a device that would hold the boot back for you. It was a small steel disc that you slid over the filler nozzle, pull back the boot with it, and lock it in place on a raised spot on the nozzle tube.
Old 04-11-2003, 11:20 PM   #12
zoinkssooby
Member#: 18910
2000 mr2 spyder
thanx for the tip. unfortunately i live in a lazy state that wont let me pump my own gas. bought kicked an ass when i first moved here cuz some clown touched my parents car (felt real stupid when i found out why)
How much follow up is too much when trying to get a new job? Kiwi Off-Topic 10 03-20-2009 03:19 PM
So I'm trying to come up with a strategy to go back to school.. Akirasoft Off-Topic 10 03-04-2006 09:34 PM
What is your greatest liability when trying to pick up members of your prefered sex? Asinine Off-Topic 51 06-23-2005 11:07 AM
going to hong kong and trying to pick up some parts for my sti when there mpower22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-08-2004 10:13 PM
Hood trying to come up while I'm driving?! ***? sorny Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 03-11-2002 07:09 PM
