Old 04-10-2003, 11:28 PM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Default 24k miles on car and all of a sudden weird grinding noise when braking cold.
a couple weeks ago I started getting this low speed grinding noise from my stock brakes. It's a 2000 2.5RS with 24k miles on it. stock original pads and rotors, Super Blue fluid.
It only happens when I first brake (about first 5 minutes) when I start driving the car. and then once the brakes are warmed up it doesn;t do it. It does however always squeal when braking lightly.
The grinding is almost like a chattering and It really does sound bad and loud. like metal shaving metal when you have a lathe or drill press turning to slow and the bit starts to chatter a little.
I have checked the pads and wear is excelent. still probably a good 1/2 pad left.
I checked everything out and I don;t see a kicked pad or any cracks in the rotors.
Is it just how these stock pads start reacting after a couple years? anyone else with this problem? Thanks!
Eric SS is offline   Reply With Quote
Old 04-11-2003, 08:28 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I had a set of axxis metal masters that did this.
It wasn't the best sounding thing to hear.....but I couldn't find anything wrong. So about all I could attribute it to was how the pad/rotor combo is.
You could try sanding down the pad to get a fresh mating surface and see how things are.....if the noise stays....or comes back.....
Legacy777 is offline   Reply With Quote
Old 04-11-2003, 01:39 PM   #3
NTP WRX
Member#: 19200
2006 LGT Wagon
If it wasn't going away, I'd suggest that you've got worn pads. Many companies put in warning "stripes" in their pads that, once the pad is worn to a certain depth, it makes a squealing noise to alert you that you need to replace them. Something to check ? The fact that it goes away suggests it's something else though.
edit: DOH! I didn't see that you had checked the wear and it was okay.
Neil.
NTP WRX is offline   Reply With Quote
Old 04-14-2003, 04:33 PM   #4
barrymazza.com
Member#: 5925
2008 R32
Grey
Post
I think it is slight oxidation on the rotor. It is usually scraped off when the brakes are applied once or twice, it usually happens to me the day after it rains...
I could be wrong though.
barrymazza.com is offline   Reply With Quote
Old 04-14-2003, 06:50 PM   #5
dpjef
Member#: 18984
2002 Impreza 2.0
dark blue
Got the same 'problem'. The first few times I hear a slight grinding noise at the front, but maybe it's at the rear too.
I too think that it's oxidation of the rotors. Do you live near the coast ? (i do)
dpjef is offline   Reply With Quote
Old 04-14-2003, 07:00 PM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Opposite... I live in Phoenix. no humidity.
metal grinding noise when rolling cold daprez Brakes, Steering & Suspension 0 04-04-2006 11:58 AM
weird noise all of a sudden from turbo 3 days after v34... rbmour Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-16-2005 10:01 PM
When your car all of a sudden sounds like a HONDA... Firewire Vancouver Impreza Club Forum -- VIC 8 04-21-2005 02:04 PM
Three random thoughts on my mind (comment on any and all of them if you so desire) perret318 Off-Topic 10 08-16-2004 09:45 PM
grinding noise when braking kami333 Newbies & FAQs 6 11-16-2003 04:43 PM
