Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 04-11-2003, 01:29 PM   #1
cboggess
Member#: 30804
87 Yugo
Red
Default Flowpath for the IC
I was wondering what the flowpath of the by-pass air from the IC is. Am I going to have rain/grime/snow/small children/birds/mailboxes running down the back of the engine? Is there a shroud or something under the IC to divert all this past the engine to under the car?
cboggess is offline
Old 04-11-2003, 02:40 PM   #2
mkim797
Member#: 33501
Good question. I'd like to know too. I am sure it will be like the current WRX, but I don't have one so I wouldn't know.
mkim797 is offline
Old 04-11-2003, 02:55 PM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
It just runs down the bellhousing tranny to the ground.
The STi has a longer undertray but still doesn't go back that far.
ANZAC_1915 is offline
Old 04-12-2003, 06:39 PM   #4
XT6Wagon
Member#: 524
04 STi
The engine is open to the outside of the car regardless if there is a hood scoop or not. So it hardly matters unless the new opening provides an access route for water to a previously protected area where electrical connections are and are not sealed in modern connectors. On a WRX the battery is the only thing really left unless you some how manage to get water into the Underside of the fuse box
XT6Wagon is offline
quick ?, swaping WRX IC for STi IC BigSlick Mid Atlantic Impreza Club -- MAIC 12 11-01-2005 10:04 PM
Turbo options for the IC challenged… xcntrk75 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-19-2005 07:03 PM
front spliter for the top mount ic? koki Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-20-2004 12:42 AM
What Hp is too much for the Stock IC??? 4a-geWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 11-22-2002 05:26 PM
Do I have to remove the IC to get the turbo heat shield off? Snowphun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-31-2002 01:38 AM
