Old 04-11-2003, 02:20 PM   #1
Ghomer1
Member#: 8091
2007 335i
Monaco Blue Metallic
Default What the hell is wrong with it?
My car is broken. Situation: When I start the car, it starts just fine, but then as I drive, the car falls on its face. Its almost like its not getting gas, and then all of a sudden it gets gas -- takes off like a bat out of hell.
I have to keep the RPMs extremely high in order to keep the car running...every once in a while when I stop, the car stalls.
At idle, the car runs very rough and tends to lobe pretty noticeably. I can't understand why I hit the gas pedal and nothing happens. Anyone have any ideas?
Fuel pump?
Sensor?
Bad Gas? (I got 100 or so miles on the tank before this happened)
Any help would be appreciated.
Garret
Ghomer1 is offline   Reply With Quote
Old 04-11-2003, 03:02 PM   #2
Brad Pittiful
Member#: 34931
could be fuel pump or clogged fuel line or clogged fuel filter...could even be a tranny problem..or clogged injectors too
Brad Pittiful is online now   Reply With Quote
Old 04-11-2003, 03:06 PM   #3
Ghomer1
Member#: 8091
2007 335i
Yeah, I heard some weird noises too......like the fuel pump whining? I don't know, whining may not have been the best description.
Garret
Old 04-11-2003, 03:58 PM   #4
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Some kind of idle problem maybe?
My friend with a 12 second WRX has that problem once in a while...its really bad at times. Looks like he can't drive what with all the bucking and high rpms needed to keep the car from stalling.
Keiho is offline   Reply With Quote
Old 04-11-2003, 04:23 PM   #5
Brad Pittiful
Member#: 34931
i had a 95 blazer and its fuel pump went , but i didnt hear any noises...i think maybe a trans could make noise...but im not sure
Old 04-11-2003, 06:39 PM   #6
Cabal
Member#: 31159
2006 WRX, 2008 2.5i
San Remo Red
I had a similar problem in one of my old cars when the idle control motor was dieing. I dunno what Subaru uses in the way of that device.
Cabal is offline   Reply With Quote
Old 04-11-2003, 07:14 PM   #7
Ghomer1
Member#: 8091
2007 335i
Doubt that it's the idle control, cause the majority of the problems occur not at idle......its like i have to hold the gas pedal down as it chokes its way up to 3000 rpms....then all of a sudden, it goes like a bat out of hell.
Hard to describe....don't know what the noise was.
Garret
Old 04-11-2003, 08:12 PM   #8
SpamMansXe
Member#: 15920
1999 White Mock 22B
2014 Plasma Blue GR STi
check your TPS sensor....sounds like my car a couple months ago and i checked that and it was fine. Your voltage should be between .45 and .55 i believe...ask Brian (RHDUDE), he can tell you better.
Steve
SpamMansXe is offline   Reply With Quote
Old 04-11-2003, 08:17 PM   #9
Ghomer1
Member#: 8091
2007 335i
Steve
So the TPS was the problem?
Old 04-11-2003, 08:27 PM   #10
SpamMansXe
Member#: 15920
1999 White Mock 22B
ya that and my pcv valve was a bit dirty and wasnt holding a proper seal....
Old 04-12-2003, 07:46 AM   #11
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
The TPS signal should be between 0 and 5v from zero throttle to full throttle - give or take .5v. Sounds like it could be the problem. Has your car even thrown a CEL yet? Might be able to get the diagnostic code even if its not.
-Brad
ChicksDigWagons is offline   Reply With Quote
Old 04-13-2003, 08:18 AM   #12
Ghomer1
Member#: 8091
2007 335i
Yeah, I have a Borla header, so I've had the cat inefficiency code.......out of nowhere, the check engine light went OFF a couple weeks ago. Now this.
Old 04-13-2003, 10:59 AM   #13
NicGordon
Member#: 24827
2008 Kia Spectra
I had a similar problem with my '01 RS last fall. I don't have any idea what caused it, but It stopped doing it after I cleaned my battary posts and connectors. Maybe the car didn't have a good enough ground. I dunno.
NicGordon is offline   Reply With Quote
Old 04-13-2003, 11:33 AM   #14
96imp
Member#: 28237
1996 impreza L
green
check you sparkplugs i had a similar problem then i bought(cheap) plugs that i had to gap myself and it fixed the problem.
also replace you pcv and feul filter pretty cheap DIY job
96imp is offline   Reply With Quote
Old 04-13-2003, 01:44 PM   #15
Ghomer1
Member#: 8091
2007 335i
I have NGKs....one heat range cooler than stock (nitrous).
New development-went out this morning to start the car and see what would happen, and it started fine. Seemed to be running alright, so I let it idle to warm up. I let it sit for about five minutes or so and everything seemed to be alright.
Then I hit the gas and revved it up to about 3000 rpms..It came back down to about 750rpms just fine and then gradually (10-15 seconds) the rough idle/cutting out/shaking started happening again.
Does this shed any light? TPS? 02?
Old 04-13-2003, 06:17 PM   #16
thavy
Member#: 2505
95 Impreza L
I've also had a similar problem for the last two days. My car would idle really bad and when i drive it would hesitate really bad and then go. Would drive really bad till i got to the higher rpms and then i would get a flashing cel light so i pretty much slowly limped it home since i was 2 blocks from it. My guess is i'm getting the cel because of a misfire. Gonna go ahead and try to replace the plug wires since its about time that i should anways. If that doesn't work i'll probably replace the coil see if that helps. Keep us posted and let us know what happens. We might not have the same problems but i'm getting the same hesitation that you are talking about.
Also have you replaced your fuel filter regularly? If not then that could cause ur fuel pump to malfunction early because it would have to work harder to get the gas with the clogged fuel filter. But my guess is that if that were the case your car probably wouldn't start at all and just turnover.
Thavy
thavy is offline   Reply With Quote
Old 04-13-2003, 10:58 PM   #17
m750
Member#: 2278
8Sti | 07 allez
White | Comp
02 sensor sounds reasonable...
It's what my problem was about a year ago.
AO
m750 is offline   Reply With Quote
Old 04-13-2003, 11:17 PM   #18
Ghomer1
Member#: 8091
2007 335i
But why doesn't it throw a CEL?
I can't understand it.
Old 04-14-2003, 10:13 PM   #19
Ghomer1
Member#: 8091
2007 335i
Bumpty Dumpty
Old 04-15-2003, 09:48 AM   #20
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Try an ECU reset, see if it goes away.
Old 04-15-2003, 05:01 PM   #21
Ghomer1
Member#: 8091
2007 335i
Mechanic tells me it is the TPS sensor......we'll see. I should pick it up soon.
Garret
Old 04-15-2003, 07:06 PM   #22
Ghomer1
Member#: 8091
2007 335i
I'm going to try this........it wasn't the TPS sensor - I'm having NO CEL. Taking it to the dealership tomorrow if the problems persist.
Garret
Old 04-15-2003, 08:18 PM   #23
Ghomer1
Member#: 8091
2007 335i
That didn't work.......problem still a mystery. I will take it to the Subaru Dealership tomorrow.
Garret
Old 04-16-2003, 03:18 AM   #24
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
I'll bet you have a fouled plug or wire that is working part of the time. You could have fouled the plug easy with Nitrous. The CEL won't come on if it's not misfiring too bad.
look under the hood at night while the car is running, if it's misfireing you'll see crazy sparks. and you'll hear it arcing.
You probably already know this, but I just figured i'd throw it out there.
Dolphin Overton is offline   Reply With Quote
Old 04-16-2003, 08:11 AM   #25
Ghomer1
Member#: 8091
2007 335i
Thanks for the reply, but that's not it I don't think............They replaced all the plugs yesterday and its still running like crud.....I'm going to try to get it to Subaru today.
Garret
What the hell is wrong with the stupid kids here? T-boner North West Impreza Club Forum -- NWIC 21 05-29-2009 05:52 PM
What the HELL is wrong with the Baby Bommer Generation??? Homerisking Off-Topic 37 03-13-2008 06:49 PM
What the hell is wrong with the News? JC Political Playground 3 06-16-2006 01:28 PM
tri state OT: what the hell is wrong with the phillies? mcu81 Tri-State Area Forum 3 04-23-2004 01:20 AM
What the hell is wrong with 604 Drivers? (long) scoobyman Vancouver Impreza Club Forum -- VIC 10 08-23-2000 12:51 AM
