Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 04-11-2003, 09:04 PM   #1
jaypride
Member#: 33424
2004 STI
Blue/Gold
Default Booooooooost
STI turbo will supprt up to 14.5psi max boost.
I know a few people had been asking about this.
jaypride is offline
Old 04-11-2003, 09:32 PM   #2
dlowman
Member#: 22998
2004 WRX STi
GT35R 572 whp 93/meth
So the wrx max boost is 13.5 .. what does all this mean?
dlowman is offline
Old 04-11-2003, 09:45 PM   #3
jaypride
Member#: 33424
2004 STI
Blue/Gold
STI runs more boost.
Someone asked a while ago, and I found this, I figured some people would be interested.
jaypride is offline
Old 04-11-2003, 09:48 PM   #4
dlowman
Member#: 22998
2004 WRX STi
so is 14.5 good or bad? lol I am guessing when it says max boost... from the way the spec reads it means it is running 14.5 from the factory?
dlowman is offline
Old 04-11-2003, 09:53 PM   #5
jaypride
Member#: 33424
2004 STI
Blue/Gold
14.5 is better than 13.5, aftermarket turbos will run up much higher.
I doubt it will be running more than 12 psi stock.
jaypride is offline
Old 04-11-2003, 09:56 PM   #6
dlowman
Member#: 22998
2004 WRX STi
I know guys that were running more than 13.5 on the stock wrx model. So I assume the sti can run up more as well.
dlowman is offline
Old 04-11-2003, 10:03 PM   #7
jaypride
Member#: 33424
2004 STI
Blue/Gold
It CAN run more. Subaru will not be sending it out of the factory that way.
jaypride is offline
Old 04-11-2003, 11:10 PM   #8
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Making big power on low boost and low compression is a good thing. That means that there is a lot of headroom if the engine and trannie will hold. I wonder if this is where the sweet spot for this turbo is. Hopefully there is room for more boost in terms of efficiency for this turbo. Does anybody have a compressor map for the VF34? This is exciting news.
StiDreams is offline
Old 04-12-2003, 12:07 AM   #9
Scoobz
Visiting NASIOC Timeout
Member#: 33786
I highly doubt that the STi will only run 13.5-15 lbs of boost... i am almost positive it will run more.. if not then damn i gotz to ****ing (sorry excuse my language) congratz suby on this.... maybe in the thank you letter...
Scoobz is offline
Old 04-12-2003, 12:12 AM   #10
IS2000
Member#: 32067
http://www.media.subaru.com/
I read an article on this site, and it also says STi's stock boost is 14.5 psi.
IS2000 is offline
Old 04-12-2003, 01:11 AM   #11
Turbobug
Member#: 27412
1999 New Beetle
FOR SALE!!
that was me who wanted to know about the stock boost. Thanks!
Does that mean that it comes with 14.5 from factory, or that that is the max boost?
John
Turbobug is offline
Old 04-12-2003, 08:17 AM   #12
jaypride
Member#: 33424
2004 STI
Blue/Gold
They say 14.5 is the MAX Boost. It does not say what it is running stock.
jaypride is offline
Old 04-12-2003, 09:25 AM   #13
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
That is the peak of the stock boost curve.
ANZAC_1915 is offline
Old 04-12-2003, 09:56 AM   #14
Jon [in CT]
Member#: 2992
02 WRX Sedan
I'm impressed that the increase in max torque over a stock U.S. WRX (300 ft-lb vs 217 ft-lb) is accomplished with only a 1 PSI increase in max boost (14.5 PSI vs 13.5 PSI).
Jon [in CT] is offline
Old 04-12-2003, 10:32 AM   #15
ha-evolution
Member#: 31556
15 STI WRB ordered
09 Accord Coupe V6 mt
Obviously the displacement increase is a major factor as well. Could the size difference in turbos also be a factor in the torque increase? If so, to what extent?
ha-evolution is offline
Old 04-12-2003, 11:29 AM   #16
jaypride
Member#: 33424
2004 STI
Blue/Gold
Max torque numbers are based on stock boost, not max boost, so until we know what stock boost is, we don't know if it is only a 1 psi difference, it could be more, it could be less.
jaypride is offline
Old 04-12-2003, 11:41 AM   #17
Jon [in CT]
Member#: 2992
02 WRX Sedan
Originally posted by jaypride
Max torque numbers are based on stock boost, not max boost, ...
But the boost numbers I offered, above, are from Subaru and represent the maximum stock boost.
Old 04-12-2003, 12:21 PM   #18
StealthWagon
Member#: 30823
2004 WRX STI
Blue/Gold
Jaypride- you must understand that the 14.5 max boost is the maximum boost the car will hit as it comes from the factory, Subaru would never put the Maximum boost a turbo could put out on their website, it would be like they were inviting us to up the boost.
StealthWagon is offline
Old 04-12-2003, 12:27 PM   #19
jaypride
Member#: 33424
2004 STI
Blue/Gold
I do understand that. The WR isn't tunning 13.5 psi, only 13psi. The STI is capable of 14.5 psi, but will not be there. So the torque and power curves the SUbaru is telling us about are not at 14.5, but at 13.5 or 14, whatever they are running stock. SO, there may be a 1 PSI difference between the WRX and the STI, but it may also be more or less. We need the info from Subaru.
jaypride is offline
Old 04-12-2003, 02:38 PM   #20
Impreza01
Member#: 152
2002 Impreza WRX
jaypride
I don't mean to be rude, but I don't think you quite grasp the concept. Boost isn't a constant application, it builds with the engine rpms (because more exhaust is spinning the turbine and etc etc etc). Thus, 14.5 psi is the max peak boost set at factory. This means that 14.5 is the stock maximum boost the STi will attain. Oh, and the WRX runs a 13.5 max stock boost.
I think what you're getting confused with is what the max boost the VF34 is capable of. That number I believe is near the 20s, but I can be wrong. However, it is higher than the TD04s our WRXs get.
EDIT: After reading your post over, I think what you're talking about is what boost is commonly held over the car's entire rev range. Again, boost relies on the exhaust of the engine. Thus, there is no single boost amount that is held for most of the car's rev range. If you look at the WRX, the boost builds quickly and then tapers off after some point (believe it's somewhere around 6k rpm).
Impreza01 is offline
Old 04-12-2003, 03:28 PM   #21
deadbolt
Member#: 990
96 Brighton and...
many
The 2.5-liter horizontally opposed (boxer) 4-cylinder engine is based on a specially reinforced semi-closed deck
engine block with forged aluminum alloy pistons, forged high-carbon steel connecting rods and sodium-filled
exhaust valves. This advanced powerplant incorporates Subaru AVCS (Active Valve Control System) variable
valve timing technology to optimize the engine’s volumetric efficiency throughout the rev band. The high-boost
turbocharger produces up to 14.5 PSI of maximum boost. The large capacity intercooler includes a manually
operated water spray feature to provide additional cooling.
From the product release materials. Meaning, the car is set with a boost control limit at 14.5 PSI.
deadbolt is offline
Old 04-12-2003, 06:48 PM   #22
jaypride
Member#: 33424
2004 STI
Blue/Gold
You're right. That makes sense now. Thanks, sorry for the confusion.
jaypride is offline
Old 04-12-2003, 09:58 PM   #23
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
AVCS!!
And also the max boost is at a surprisingly low RPM....
The STi's turbo is not a VF34. It think it is a new model IHI, specifically for the 2.5 STi.
Glenn
Old 04-12-2003, 11:02 PM   #24
Impreza01
Member#: 152
2002 Impreza WRX
Glenn Wallace
Thanks for the correction. Everyone's been saying the new USDM STi's turbo is a VF34. Guess not...
Old 04-12-2003, 11:19 PM   #25
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Hey Glenn,
Do you know anymore about this new turbo? How many cfm? Do you have the compressor map? How does it compare to others in the VF series? BB?
Thanks
99 STI MAx Boost FastfreddyRs General Community 2 09-15-2004 08:04 AM
What is STi stock boost in psi, and what max safe psi before you'd rec' head studs? JRock Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-05-2004 05:56 AM
Max boost pressure on a 2.5 sti block Big Bear uk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-26-2003 03:08 PM
what is the max boost for the sti 4 banger Tri-State Area Forum 1 09-23-2003 07:24 PM
what is the max boost the sti can hold 4 banger Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-22-2003 11:44 PM
