Closed Thread
Old 04-12-2003, 04:40 AM   #1
WR-Xtasy
Member#: 6377
WR Blue
Default 60,000 mile service on WRX
Has anyone done their 60,000 mile service on the WRX from the dealer and is it worth it ~$750-800 from Santa cruz
Also I have vishnu stage 0 will the dealer care
WR-Xtasy is offline
Old 04-14-2003, 06:16 AM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
If that number includes timing belt replacement, it's probably not ridiculous for a dealership. All depends on exactly what they do. If you have a good independent Subaru mechanic, you could probably save 20%.
armand1 is offline
Old 04-14-2003, 10:30 AM   #3
WR-Xtasy
Member#: 6377
WR Blue
Thanks armand1
do you know a good subaru mechanic prefer one Between San Mateo to Santa Clara
WR-Xtasy is offline
Old 04-14-2003, 12:03 PM   #4
vile
Member#: 32371
'02 t-rex wagon
platinum
can you list what you're getting for that price? aside from what is done at the 30k service, plus maybe the hoses and belts....what else are you getting for that 750-800 price?
vile is offline
Old 04-14-2003, 12:13 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That's a lot of money for a service. According to the service schedule in the factory manual the 60K service consists of replacing oil, plugs, coolant, brake fluid, air and fuel filters. Otherwise it's just a lot of inspections. Typically the dealer will try to sell you their own recommended maintenance "package" which you really don't need. There isn't $700 worth of work here and it's all stuff you can do yourself.
Recommended timing belt replacement isn't until 105K.
Save the money and have a party for the car for having reached 60K
Mulder is offline
Old 04-14-2003, 01:35 PM   #6
WR-Xtasy
Member#: 6377
WR Blue
Notice the required spark plug cost for the WRX at bottom
Subaru of Santa Cruz
“The Beauty of All-Wheel Drive”
Dealership recommended service-based on manufacturer’s recommended service,
local driving conditions, and years of our professional service staff’s combined experience.
3750 Mile Oil and Filter Change Service (or every 6 months of infrequent use)
q 1. Replace engine oil
q 2. Replace engine oil filter
q 3. Replace engine drain plug gasket
q 4. Set tire pressures / advise on tire condition and wear pattern
q 5. Check / top off underhood fluid levels
q 6. FREE car wash Only $39.95
7,500 / 22,500 / 37,500 / 52,500 Mile Service (includes above)
q 7. Rotate tires (or leave best tires in front)
q 8. Balance tires front and rear
q 9. Check spare tire and set pressure to _______psi
q 10. Inspect brake linings (approx. lining remaining: ______% Front ______% Rear)
q 11. Inspect steering / suspension components
q 12. Check operation of outside lights
q 13. Check and adjust external drive belts
q 14. Check and adjust ignition timing and idle speed
q 15. Road test for proper performance and operation Only $139.95
15,000 / 45,000 Mile Service (includes above)
q 16. Check and adjust parking brake
q 17. Replace air filter
q 18. Add washer solvent / Inspect wiper blades and front/rear washer operation
q 19. Adjust clutch pedal free-play and hill-holder system (if applicable)
q 20. Replace transmission fluid
q 21. Replace differential fluid (front and rear if applicable) Only $276.95
q 22. Service battery
q 23. Check coolant protection (good to _______ degrees F) and Air Conditioning (cools to ______ degrees F)
30,000 Mile Service (includes above)
q 24. Replace spark plugs (excludes 2.5 liter Phase 1 engines-see below)
q 25. Replace fuel filter
q 26. Replace brake fluid
q 27. Replace engine coolant
q 28. Inspect engine cooling system operation Only $474.95
q 29. Inspect intake hoses and PCV system
60,000 Mile Service (includes above)
q 30. Replace cam belt(s) [Note: GL/Loyale models should have cam belts replaced at 52.5K mile intervals]
q 31. Replace external drive belts
q 32. Inspect front engine oil seals, cam belt idler/tensioner pulleys, tensioner mechanism, water pump, oil pump, for leaks/excessive play (while timing covers are removed)
Only $754.95
Note: 2.5 liter Phase I engines use platinum tip spark plugs every 60,000 miles-additional $72.00
Note: Prices different for Justy and 6 cylinder models. Check with our Service Advisors for prices on these services, or for
any other special service needs or concerns.
Note: WRX 2.0 liter Turbo engines use platinum tip spark plugs every 60,000 miles-additional $161.00 parts and labor
WR-Xtasy is offline
Old 04-14-2003, 01:45 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I'd think Subaru knows what they are doing recommending a 105K interval for the timing belt. Older cars needed them done at 60K but the newer ones are made to last longer. It's your call if you want to go for it, probably not necessary. If you want you can remove the left side timing cover to get a good look at the belt and see what condition it is in, it's probably fine. Combined time and mileage are what causes them to go bad, and if you've put a lot of miles on in a relatively short time the belt is less likely to be worn.
You can change the plugs yourself if you are at all mechanically inclined, many vendors here sell them. Drive belts are also wickedly easy to change and you don't have to take anything apart to see what shape they're in.
Mulder is offline
Old 04-14-2003, 04:04 PM   #8
vile
Member#: 32371
'02 t-rex wagon
platinum
if i'm reading that right.....is that another 161.00 on top of the 754.00 for the wrx cuz of the spark plugs? they on crack?
i don't see how they can justify charging that much for 60k service. they include replaceing the cam belt....are they referring to the timing belt? if so, it doesn't require replacing till 105k mi.
as for everything else, seems like you're only getting what you'd normally get for the 30k service, but w/the belts, like i mentioned earlier
i'm surprise there's no mention of replacing your radiator hoses as well, and another thing, how come everyone always overlook the little pcv?
way over price if ya ask me
vile is offline
Old 04-14-2003, 05:37 PM   #9
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
LOL $161 extra for platinum tipped spark plugs. If anyone on this board ever pays that much for plugs I will find you and kick your ass. Go buy some nice NGK copper plugs for $2.00 each and put them in. Personally I would do the rest of the stuff myself as well, but def. don't pay that for the plugs.
slim speedy is offline
Old 04-14-2003, 06:19 PM   #10
C-daleRidr
Member#: 18074
2008 Speed3
I had my 60000 mile tune done for under $300, before I had the LED fuses replaced in the cruise and foglight buttons. I know they do different stuff, but damn, that's pretty expensive. It's still just fluids and checking everything out.
Edit: I'm teh st00pid.
C-daleRidr is offline
Old 04-14-2003, 08:04 PM   #11
dicksosa
Member#: 13742
2002 Impreza WRX
WR Blue
Default Spark Plugs
I'm sure most of that 161 bucks for plugs is due to the amount of labor involved in replacing them. As anyone who has done the replacement on a WRX knows it isn't a simple 15 min job. Not that it's difficult, but it is time consuming.
dicksosa is offline
Old 04-14-2003, 11:13 PM   #12
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Definitely high price; do as much as you can yourself.
I don't think replacing rad hoses is a routine item. They should be inspected, but that's it. (My 95 Legacy has 165,000 miles on it and still has the original hoses. They seem to be fine.)
Mike Wevrick is offline
Old 08-27-2008, 03:59 AM   #13
JCharron2005
Member#: 180365
2015 STI Limited
Darkness
$161 for plat. plugs.......cost me under 40 for my iridiums and it took me 20 min to change them...
JCharron2005 is online now
Old 08-27-2008, 08:03 AM   #14
C_Wood
Member#: 102234
14 WRX
Man thats crazy! Do it yourself and save sooooooo much money. If you don't know how or have any questions just do some searching around and you can find step by step instructions with pics.
C_Wood is offline
Old 08-27-2008, 08:24 AM   #15
Davidwrx
Member#: 141028
2002 WRX Wagon
I did my 60K myself. Buying all of the parts / fluids at a subaru dealer it only cost me about $200. If you have time / patience / willingness - do it yourself. If you don't have the time and $ is not an issue - have a shop do it. You may try an independent - should be less.
Davidwrx is offline
Old 08-27-2008, 11:33 PM   #16
leecea
Member#: 37359
2003 WRX
Modern hoses seem to last forever. When I had my van inspected at 110K, I asked the mechanic whether he thought the hoses needed replacing and he looked at me like I was crazy!
leecea is offline
Closed Thread
What is done at 60,000 miles service SubaruImpreza_power Service & Maintenance 8 10-03-2003 02:41 PM
60,000 mile servicing.....need suby technician MekoNY Tri-State Area Forum 10 06-19-2002 05:46 PM
60,000 mile service Loki General Community 6 03-06-2002 02:07 PM
60,000 mile service? MechBoy2 Technical Forum Archive 4 05-16-2000 10:41 AM
