Old 04-13-2003, 03:39 PM   #1
Gravel-Fun
Member#: 18751
2000 Impreza RS
Default Can you help diagnose a new knocking noise
After having my "Primitive" skidplate on my car for about 2 years, I started getting a knocking noise when sitting at idle. I looked under the car, and sure enough, the oil pan was hitting the skidplate. I did use the included spacers.
I thought: no big deal. Well, yesterday I removed the skidplate, and I STILL have a knocking noise. You can see where the oil pan was hitting the skidplate.
The car has 44,000 miles on it. I only use mobile one oil, and the oil lamp goes out instantly when the car is started.
My guess is the motor or trans mounts. I have not seen this issue on the board.......ever, so I am a little worried.
No engine mods, by the way.
Thank you in advance for your help.
Roy
Gravel-Fun is offline   Reply With Quote
Old 04-14-2003, 12:38 PM   #2
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Did you check all the heatshields on your exhaust? They might be rattling.
maciek is offline   Reply With Quote
Old 04-14-2003, 12:59 PM   #3
Gravel-Fun
Member#: 18751
2000 Impreza RS
It is a low hertz knock, like knocking one knuckle on a hardwood floor. But, thanks for responding
Roy
Old 04-14-2003, 01:10 PM   #4
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
Need more data...
Does it follow the revs, or is it independent of engine RPM?
Engine warm or cold?
Noise comes from front/back, one side, up top, underneath?
Automatic or manual? (don't laugh, ever heard a cracked flex-plate or a loose flex-plate bolt? Sounds really scary).
Any metal shavings in the oil?
Chromer is offline   Reply With Quote
Old 04-14-2003, 01:40 PM   #5
Gravel-Fun
Member#: 18751
2000 Impreza RS
seems to follow revs, but quiets as car is rev'd
5 speed
seems to get worse as car warms up
Sound seems to come from underneath
I can feel it in the brake pedal, sitting at idle
have not changed oil to check for shavings
Thanks
Roy
Can you help me diagnose this leak? joe1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-22-2009 01:16 AM
Can you help me determine whats causing this braking noise? DanZ Brakes, Steering & Suspension 5 11-18-2004 12:46 AM
can you help me figure out what i just blew? very loud clicking noise from the diff sideways slut Transmission (AT/MT) & Driveline 3 09-22-2003 12:58 PM
weird noise, can you help? gooter80 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-26-2003 07:08 PM
Can anyone help diagnose my suspension problem? PaulRex Tri-State Area Forum 10 05-29-2003 03:15 PM
