Old 04-14-2003, 12:33 AM   #1
XeviousR
Member#: 1974
27 James Elterman
TakataTimeAttack.com
Default 98 RS Tranny: Can U Identify These Wires?
I am installing a '98 Impreza manual transmission into a '92 Legacy turbo that was an automatic. Can anyone help me identify these wires? Are they neutral indicator? reverse lights? etc. ???
Thanks in Advance! For more details on my transmission swap project, check the following link.
http://www.shimmysideways.com/tranny_swap.htm
Note: Please excuse this cross post. I posted this at RS25.com and had no response. Moderators feel free to move this to 'Electrical' if you feel necessary.
James Elterman
www.ShimmySideways.com
22 STS - 98 Impreza RS
22 PGT - 92 Legacy Turbo
XeviousR is offline   Reply With Quote
Old 04-14-2003, 04:54 PM   #2
XeviousR
Member#: 1974
27 James Elterman
Shimmy to the top...
Anyone got any ideas?
Old 04-14-2003, 05:33 PM   #3
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 XV, '99 RS
Lightbulb
I think...and this is only a guess.... that:
1 = ?
2 = Reverse Lights
3 = Rear O2 Sensor -I think the top part shown in your picture is where it plugs in [on an Impreza] to the main body harness. It should just run over the top of the tranny then down the drivers side, both wires should split, one going into the reverse light switch and the other going to a connector for the O2 sensor.
Opie is offline   Reply With Quote
Old 04-14-2003, 09:16 PM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I'm not sure what those are specifically but I know from doing my 6MT swap the three things on both trannies are speed sensor, reverse lights and rear O2 extension. So those are likely the three plugs but I'm not sure which is which.
Old 04-14-2003, 09:29 PM   #5
N/A
Member#: 133
TBA TBA
TBA
Speedo, neutral switch and reverse lights I think.
N/A is offline   Reply With Quote
Old 04-14-2003, 10:39 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
If you read the transmission forum often you would have know that 90-97 tranny are compatible while change had been made around 98.
I was comparing two wiring diagrams and it looks as if you could splice the correct wires together if you had a spair transmission harness.
I think the white connection labeled three is the rear 02 extension, which you could just remove.
Old 04-15-2003, 01:10 AM   #7
XeviousR
Member#: 1974
27 James Elterman
Ciper: I choose a '98 Tranny instead of a '90-'97 because that is what I already had in my parts bin. Thanks for the advice. You really hit all the forums don't you!
Thanks for you input everyone. I forgot about the rear O2 sensor.. that clears things up.
Old 04-15-2003, 03:56 PM   #8
ciper
Member#: 15543
90BJ Legacy LS ABS
So will you be running the 98 transmission using the 92 TCU? Im interested in your progress, as I plan to do the same. My reasoning is that I want to grab an auto from a forrester (4.44).
Mud Flap Experts: Can you identify these? YoungKwang Interior & Exterior Modification 10 02-07-2008 08:04 PM
Can you identify these wheels? (PICS) INFIDEL Tire & Wheel 7 08-23-2005 12:43 PM
can you identify these signatures IA Performance Motorsports 18 06-17-2005 03:46 PM
Can you identify these wheels? (pic inside) ChrisMcCall Interior & Exterior Modification 3 10-04-2004 06:00 PM
Can you identify these rims? BlackRS02 Tire & Wheel 2 08-13-2003 12:17 AM
