Old 04-14-2003, 04:22 AM   #1
danci1973
Member#: 19018
1995 Legacy Wagon
Default Air filter affects mileage?
Hi!
After installing a K&N cone filter and a heat shield to form an improvized CAI, I have a feeling that the mileage has gone down quite a bit - I get 16-18 mpg.
Can air filter (better air flow) actually affect mileage even if I try to drive economicaly? Or is it just the fun factor?
In any case, is there anything one can do to improve mileage (I'm reading people are getting 22-25 with EJ25 - why would my EJ20 NA take so much more)?
D.
danci1973 is offline   Reply With Quote
Old 04-14-2003, 03:05 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Did you reset the computer?
Old 04-14-2003, 05:07 PM   #3
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
I 'heard' that you can have better gas milage w/ an aftermarket intake if you drive nicely....shift before 4K.
..but if you drive at WOT, you will get much worse gas milage than stock.
do some gas milage experiments w/ different intake setups and driving styles....post your results.
maciek
maciek is offline   Reply With Quote
Old 04-14-2003, 10:34 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
I dont agree with maciek. If the engine management has had time to learn the filter normal driving should be equal or better assuming the new filter flows better.
At WOT it could increase the amount of Air in relation to the amount of fuel, and since most of our cars run rich it could increase the milage, though I doubt any of us monitor WOT gas mileage
edit: changed "I dont with maciek"
Old 04-15-2003, 04:02 AM   #5
danci1973
Member#: 19018
1995 Legacy Wagon
Yes, I did and I do have this setup for almost almost a year now (except the heatshield, which was added later).
D.
K&N / resusable air filters vs. gas mileage yo vanilla Service & Maintenance 2 08-01-2009 05:32 AM
Tranny fluid affect mileage? help bluestone Transmission (AT/MT) & Driveline 1 03-08-2005 10:18 AM
Air filter mileage? ubcheme Normally Aspirated Powertrain 1 12-21-2004 09:20 PM
air filter and gas mileage bluesube Normally Aspirated Powertrain 3 01-04-2002 09:58 AM
Does air filter affect how fast oil turns dark (observations of K&N vs. Amsoil)? bluesubie Normally Aspirated Powertrain 14 12-16-2000 07:22 PM
