Old 04-14-2003, 05:32 AM   #1
sti27
Member#: 33715
98 2.5rs
rallyblue pearl
Default Need new starter
Anyone know where I can get a starter for a 98rs at a decent price? Mine is on the fritz and gonna need a new one.
Thanks
Sti27
sti27 is offline   Reply With Quote
Old 04-14-2003, 08:00 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
What are the symptoms of your current starter?
just curious...
Legacy777 is offline   Reply With Quote
Old 04-14-2003, 01:52 PM   #3
sti27
Member#: 33715
98 2.5rs
rallyblue pearl
Well, after I start the car, the bendix sticks (kinda like a grinding/squeeling noise for a second or two). Always does it when its cold, sometimes when its warm.
Old 04-15-2003, 01:17 PM   #4
sti27
Member#: 33715
98 2.5rs
rallyblue pearl
Default Bump
Anyone know?
Old 04-15-2003, 01:21 PM   #5
Legacy777
Member#: 4800
have you tried local autoparts store?
Other thing you can do is take apart the starter you have and see if there is anything obviously wrong that you can fix.
Typically the starter motors don't go bad. The solenoid contacts do wear out. I just replaced mine a month or so ago.
You may be able to find replacement parts for particular items if you take it apart. I'd look and see if there are any electrical/automotive places around that carry stuff like that in your area.
Old 04-16-2003, 01:09 PM   #6
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default starter prices
I checked the price for starters at Advance Auto Parts for a 1998 Subaru 2.5 RS and came up with:
Automatic: Part Number: Worldwide 17292
Remanufactured; Mitsubishi Type; Permanet Magnet Planetary Gear Reduction; Automatic Transmission$174.99.
5-speed: Part Number Worldwide 17290
Remanufactured; Mitsubishi Type; Permanet Magnet Planetary Gear Reduction; Manual Transmission $137.99.
Hopefully this gives you starting point on how much you might spend.
http://www.partsamerica.com/SelectPa...rchFor=Starter
-Charles-
ImprezaVA is offline   Reply With Quote
Old 04-16-2003, 01:46 PM   #7
sti27
Member#: 33715
98 2.5rs
rallyblue pearl
Default Thanks for the info
I was quoted by a local subaru garage for about $180 plus labor. $137 seems much better. Are starters difficult to install? Looks pretty easy to get to. My tech skills are probly beginer, cant install a turbo by myself but can change the oil, spark plugs, etc... Has anyone here done one before?
Old 04-16-2003, 03:10 PM   #8
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default Starter Install
I've installed a starter on a couple of cars. Its not really hard replacing the starter, it's taking apart everything to be able to work and remove/replace it. As far as replacing the one on your 2.5 RS I don't have a clue. I have a 2.2 and I really hope I don't have to learn how to change the starter on this car for a long time. In fact, I don't even know where the starter is on my subaru at the moment. I could easily find it, but never looked.
-Charles-
Old 04-16-2003, 06:21 PM   #9
Legacy777
Member#: 4800
The starter is pretty easy to replace.
It is on the driver's side top of the trans bell housing. There is a bolt on the top and bottom. So you still need to get under the car, but it's not that bad.
Make sure you disconnect the battery before starting, or you'll get some nice sparks.
I need a starter for my RS fast! jamesfacts New England Impreza Club Forum -- NESIC 17 06-10-2004 09:07 AM
Need a starter scoobyimprza Mid Atlantic Impreza Club -- MAIC 1 03-10-2004 03:36 PM
I need a new starter at 51,000 miles!! lildragn11 Service & Maintenance 1 02-15-2004 09:51 PM
Need Remote Starter Wiring help WiredWRX Car Audio, Video & Security 0 08-29-2002 04:03 PM
Need remote starters dbrown Car Audio, Video & Security 1 09-27-2001 03:33 PM
