Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 04-14-2003, 06:13 PM   #1
kenchan
Member#: 15106
Default Daikei S-501 Steering Hub for Aftermarket Steering wheels
i got the steering boss from www.japanparts.com
Model: Daikei S-501 works on US WRX
Price: Approx $150 shipped to IL
Lead-time: About 10 days
I bought a Momo Corse wheel locally... i had problems using
the Momo hubs on my 98 Prelude in the past because I had
to modify the horn harness to make the horn sw to work.
The Daikei ones come with factory connectors for the horn
and SRS trick resistor...
so no SRS checklights as well and you will use the factory
coil harness thing behind the steering wheel so no special
wiring needed. the horn switch on the steering wheel
works flawlessly. (only thing you need to do is ground
the switch to the steering hub and plug the horn wire
onto the switch).
fit and finish was perfect. took no more than 30min to install.
this is a must-have mod for anyone using wider aftermarket
tires and agressive offset on their wheels. my steering nolonger
pulls to the grooves of the road...plus, the turn-in is very
agile and responsive.
kenchan is offline   Reply With Quote
Old 05-16-2003, 01:35 AM   #2
kenchan
Member#: 15106
Default AS-01
lately ive been noticing that the steering wheel was a little bit
off center more than i liked. the hub's splines probably did not
match up completely. for instance like this, Daikei makes an
adjustment centering hub so that you can turn up to 9 degrees
to center up the steering wheel completely. For Momo steering wheels like mine, I would use model AS-01.
purchased it again from japanparts.com should have it
some time next week. total with shipping about $40.
not bad. i dont think there is any store or manufacturer that has these in the US.
japanparts.com is great!
Old 05-19-2003, 08:32 AM   #3
GoodFinder
Member#: 8943
2006 MINI + Corvette
Both Blue
Thanks for the information.
Do you still have the use of your turn signals with auto cancel, as well as cruise control, with the new setup?
GoodFinder
GoodFinder is offline   Reply With Quote
Old 05-19-2003, 01:32 PM   #4
kenchan
Member#: 15106
everything like factory less cruise control and airbag.
but, you can probably fabricate a switch to work the
cruise control. its only 4wires.
Old 05-20-2003, 12:50 PM   #5
kenchan
Member#: 15106
Received the AS-01 center adjustment spacer already yesterday, dang japanparts.com is FAST!
Anyway, installed the center adj. spacer and fixed my steering's
centering. its PERFECT now and that means, I am very happy.
man, Daikei should start selling these parts in the US.
their quality is top notch, much better than Momo's hubs
and very user friendly.
special thanks to japanparts.com for their great service.
Old 05-20-2003, 01:20 PM   #6
GoodFinder
Member#: 8943
Both Blue
If you don't mind me asking, who are you working with there at www.japanparts.com? I got an email reply today from one of their people who was not familiar with these Daikei items. I'd like to email dialog with somebody there who knows about these specific items!
GoodFinder
Old 06-04-2003, 01:58 AM   #8
kenchan
Member#: 15106
Default follow up...
its almost about 3-4 weeks since i installed the steering wheel.
very good. will not go back to stock.
the AS01 really helped out too. the steering continue to be
dead center.
Old 06-13-2003, 02:00 AM   #9
whiterabbit
Member#: 16755
know anything about the daikei s-055?
whiterabbit is offline   Reply With Quote
Old 06-13-2003, 03:29 AM   #10
kenchan
Member#: 15106
no idea..which car is it for?
Old 06-13-2003, 01:03 PM   #11
whiterabbit
Member#: 16755
subaru impreza and i think legacy
Old 06-13-2003, 06:01 PM   #12
kenchan
Member#: 15106
yah, if you have a 02wrx, get the S501 just to be sure.
Old 07-11-2003, 09:37 PM   #13
NeoGeo
Member Sales Rating: (5)
Member#: 3776
Take a wild guess
Just wanna chime in on a great product. I got my MOMO tuner wheel and CF horn button from japanparts, along with the Daikei s-501 and AS-01. It took a while to get but the quality is top of the line!
The daikei s-501 is "OEM" quality for a steering wheel adapter. Came with torx tool to remove airbag, airbag plug-n-play resistor, and horn plug-play. It's designed especially for subarus, and installation was a pleasant experience, no additional mods...everything just snaps together. AS-01 corrected my wheel's inherent crookness too, excellent build.
Daikei should really sell this stuff over here...makes installing aftermarket steering wheels a piece of cake.
Thanks to kenchan for his help and posting a great product!
I'll try to post pics when I get time to borrow my friend's digicam.
NeoGeo is offline   Reply With Quote
Old 07-15-2003, 10:05 PM   #14
superg
Member Sales Rating: (6)
Member#: 3385
Default Daikei S-501 work with OMP Velocita?
Thanks for the info on the Daikei adapter. You guys have used it with Momo wheels. Any idea whether an OMP rally wheel will fit using the same adapter? I think Momo and OMP use the same pattern, but would like to be sure before I order the Daikei from Japan. Japanparts replied that they have no idea, as they do not get OMP wheels in japan.
Superg
superg is offline   Reply With Quote
Old 07-29-2003, 02:38 AM   #15
james nicol
Member#: 17690
2013 wrx 5dr base
black
Default daikei steering hub
i ordered the daikei hub and the center adjustment spacer from japanparts and they sent both items in a few days. japanparts is a first rate vendor. i intend to use these parts with a sparco lap 5 wheel on my 2002 wrx wagon. many thanks to kenchan for sharing his info on this part.
james nicol
james nicol is offline   Reply With Quote
Old 08-01-2003, 12:13 PM   #16
kenchan
Member#: 15106
glad i could help!
DAIKEI + japanparts.com =
Old 10-02-2003, 09:48 AM   #17
kenchan
Member#: 15106
Default kana's last day
Guys, tomorrow 10/03/03 is Kanako's last day at japanparts.com
She sent me an email this morning. I thanked her for her
superb customer service and support. She was the originator
for arranging those Daikei steering wheel boss (hub) and
centering adapters for me.
Please join me to say "good luck" to her. Please send her
an email wishing her the best from us Impreza family!!!
[email protected]
Old 10-15-2003, 03:32 PM   #18
HighTachPrez
Member#: 15247
99 2.5 RS
found some semi-useful sites for this Daikei Hub (because i'm looking into purchasing one myself )
Not sure if this is the model of the Subaru, but this is a good price:
http://www.metromotorsports.com/prod...sp?PprodID=157 $109.95 + 9.95 shipping
If you can read Japanese it tells you step by step how to install (on non-airbaged cars)
http://www7.ocn.ne.jp/~kamataka/boss3.htm
Nothin but the best for my scoob!
HighTachPrez is offline   Reply With Quote
Old 10-19-2003, 08:23 PM   #19
kenchan
Member#: 15106
http://www.daikei-s.co.jp/airteki005.htm
Here's the actual daikei link to the subaru fitment chart. Too bad its in Japanese, huh? hahaha
Anyway, the chart looks like this.
SUBARU CARS
Impreza
GF, GC1, 2, 4 6 use Type156 or Type158
Ver4/GC8 use Type157
Ver5,6/GC; GF8 use Type501
GD, GG use Type501
GD,GG latest version use Type507
I think the 99-01 (Ver5,6/GC) and 02-03 (GD) use
Type501 (mine's a 02).
I also think the 04+ (GD) and the STI use Type507...but
don't quote me on it cause the chart above is for JDM cars.
I know for a fact that the STi's have different harness connectors
than my 02...but not sure about the non-STI 04's if they are similar to the 02's or not.
Old 10-22-2003, 02:17 PM   #20
HighTachPrez
Member#: 15247
99 2.5 RS
Default Daikei steering wheel hub
I did some research and it seems the Daikei hub for our subbies are superior to the sparco and momo hub (mainly because of the ease of installation and the attachment of the horn).
daikei -->
My question is, does this hub put the steering wheel closer or further away than the stock location??? I'm not sure if i want to get a dished wheel or semi-flat aftermarket steering wheel.
Any help is appreciated!
Old 10-23-2003, 03:29 PM   #21
kenchan
Member#: 15106
its about the same. if you get the AS01, its a tad closer to you.
Old 10-23-2003, 06:03 PM   #22
svxr8dr
Member#: 1702
2001 2.5 RS-T
Blueridge Pearl
I just ordered mine and am awaiting delivery
svxr8dr is offline   Reply With Quote
Old 10-26-2003, 07:50 PM   #23
Robmat
Member#: 2173
2005 LGT Wagon 5MT
ABP
What do these cost and what wheels will they work with?
Thanks-
Robmat
Robmat is offline   Reply With Quote
Old 09-04-2004, 01:20 PM   #24
kenchan
Member#: 15106
Never mind... already sold the AS-01.
Old 04-12-2008, 08:28 PM   #25
Spooled
Member Sales Rating: (16)
Member#: 14958
1991 318is
bump. anyone know where to find these?
i looked on japanparts.com to track down the part numbers, but the searches returned 0 results...I entered S-501 and AS-01 by the way.
I have an OMP steering wheel on my 03 wrx now, and i have an el cheapo hub that won't allow me to hook up my horn (my main concern).
Any help would be appreciated, as my daily driver is horn-less at the moment
r!az
Spooled is offline   Reply With Quote
WTB: Adapter Hub for aftermarket wheel Freakstyle101891 Tri-State Area Private Classifieds 0 12-26-2009 04:54 PM
WTB: Hub for aftermarket steering wheel for my 03... Ricewagon VIC Private Classifieds 6 10-31-2007 05:53 AM
WTB: hkb steering hub for 04 sti/wrx STI808 Private 'Wanted' Classifieds 1 08-16-2004 12:06 AM
WTT: Stock WRX Momo Steering wheel w/airbag for aftermarket steering wheel 2000vfr800 Private 'Wanted' Classifieds 3 09-18-2003 11:23 AM
need help - airbag resistor trick for aftermarket steering wheel MrZone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-21-2003 11:08 AM
