Old 12-09-2013, 04:17 AM   #2326
theoutbackdream
Member#: 301179
2013 WRX Limited
Originally Posted by kurt95gt View Post
Trust me I won't be that guy
I'm going to keep digging around an see what I can come up with. I still have to pay on the car for the next 3 years an its only got 66,000 miles. I'm not doing anything in a big hurry
Thanks for the info
No prob. BTW what are your intentions of getting an exhaust and intake?
TBH, they did nothing for me other than create noise. In terms of power, I felt the power band moved up in the RPM band, which made low end torque feel low. The car did feel less restricted, but Cost vs gain in performance, didn't make sense to me honestly.
theoutbackdream is offline   Reply With Quote
Old 12-09-2013, 10:44 AM   #2327
kurt95gt
Member#: 375538
08 legacy 2.5i
black
I'm mainly wanting it for the sound.
I already have 2 play toys. The legacy is just a dd
kurt95gt is offline   Reply With Quote
Old 12-09-2013, 05:51 PM   #2328
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
It's so nice to have a Top-Mount Cold Air Intake when there's plenty of cold air to take in.
Reverend_ is offline   Reply With Quote
Old 01-02-2014, 02:59 PM   #2329
DirknJirkn13
Member#: 249696
2010 Outback Sport
2010 Impreza Outback Sport Automatic
Custom UEL Headers (97-05 EJ25, cut to fit)
Magnaflow High Flow Cat
2012 WRX Resonator
18" Magnaflow Muffler
4" Stainless Steel Tip
Cost: Parts were around $300 and labor was around $200. $500 total and it's less than the price of headers made to fit this model.
Likes: BOXER RUMBLE!
Dislikes: CEL every once and a while, but I can easily clear it with an OBDII bluetooth adapter & the Torque Pro app.
A lot of cutting and welding was done to make everything fit together, but in the long run to me it was worth it. No noticeable power loss, but idle seems to be a little bit lower on the RPM scale.
Pics: (magnaflow cat not pictured)
Video:
DirknJirkn13 is offline   Reply With Quote
Old 01-03-2014, 03:29 AM   #2330
cookievea
Member#: 377641
Mostly like that.
cookievea is offline   Reply With Quote
Old 01-04-2014, 07:52 PM   #2331
Aluxes
Member#: 341471
1997 Impreza OBS
2.2L N/A
5 speed
Bought the car with a Magnaflow Glasspack muffler. It sounds great, not too loud at idle, nice rumble on acceleration, really nice rumble off throttle. Stock headers, stock CC, and stock( I think) exhaust resonator. I removed the intake resonator and installed a 3 inch adjustable length CAI hose( purchased from Amazon for 20.00) that goes directly into the stock air box using a K&N panel filter. The other end of the CAI hose is routed through the fender down to the mounting hole for the fog lights. So I get cold air, forced induction straight into my stock air box. Pros: I noticed a smoother, lower idle, better sound during acceleration, better throttle response, a bit of improvement in low rpm torque, and a lot of improvement in acceleration through out the entire rpm range, great responsiveness at 70+ MPH, better gas mileage, about 1-3 gallons per mile highway. Cons: I drive on some very dusty roads and have had to clean my K&N more often. If it gets too dirty my check engine light comes on, but goes off after I clean it. For 20 bucks and about 45 minutes of work, it was definitely worth the gains.
Aluxes is offline   Reply With Quote
Old 01-09-2014, 11:43 PM   #2332
Adam17
Member#: 378254
2012 Impreza 2.0i
Default 2012 Impreza 2.0i MT
hybrid intake/resonator delete
charcoal filter delete
K&N panel filter
muffler delete
It's really opened things up a bit, revs more easily and sounds great. Gas mileage is the same and power is the same but because it revs more easily it gets up to speed more quickly. When I installed the intake tubing (same diameter as stock resonator) to replace the deleted resonator the car hesitated slightly for a few seconds right after startup while it was still warming up. This lasted for about a week, I'm not sure but I'm assuming that the ecu adjusted for the difference.
Adam17 is offline   Reply With Quote
Old 01-24-2014, 03:04 AM   #2333
Flat Face
Member#: 275220
2000 Bugeye
Blue Ridge Pearl
So after researching and finding many contradictory answers online I gave in and bought a full STI exhaust being sold as a unit for a good deal.
Turns out that after checking to see if it would bolt up directly like half the info online seemed to indicate, the axle back is.. a few MM too big to fit on my mid pipe and the mid pipe flange is 90 degrees off from my cat flange like some of the info suggested it would be.
I'm wondering, what do you guys think it would cost to get a small adapter made to fit the STI midpipe to my cat? The STI midpipe is maybe.. 5cm's shorter than my RX one so I'm pretty sure 5cm's plus the 90 degree turn gives me enough room to stick an adapter in instead of cutting and re welding.
Also when I get this connected I'll make a little post about my stock pipes and the process of fitting the STI ones on because all the info I found online was for 2.5RS's or 2.0 WRX's the 2.0 RX seems to be quite an uncommon model which is why I had such trouble finding out the right info :/ hopefully it'll help someone in the future
EDIT: Some mock ups of how I could connect them, although the second from the right, I'm not sure I could stretch the rubber mounts enough for that to work, so I'm assuming either extending the cat or an adapter would be the only ways
Flat Face is offline   Reply With Quote
Old 02-05-2014, 06:15 AM   #2334
subbielov3r32
Member#: 341281
would any 02-07 wrx/sti uel's fit a 02-05 2.5rs?
subbielov3r32 is offline   Reply With Quote
Old 02-05-2014, 06:29 AM   #2335
GrundleJuice
Member#: 165749
Not without cutting/welding. And then you would have a crappy n/a exhaust manifold.
Use the Search tool or even google. This has been asked by tons of n00bs like yourself.
Old 02-05-2014, 09:31 AM   #2336
amcn831
Member#: 235777
2000 RS BuRP
2007 2.5i CGM
Originally Posted by Flat Face View Post
So after researching and finding many contradictory answers online I gave in and bought a full STI exhaust being sold as a unit for a good deal....... I'm wondering, what do you guys think it would cost to get a small adapter made to fit the STI midpipe to my cat?
Search Google. I forget who makes one but they're out there. If I find it I'll report back.
Edit: they do exist...just gotta find them. This is an old FS thread but it should be what you need. http://www.rs25.com/forums/f177/t152...t-adapter.html
amcn831 is offline   Reply With Quote
Old 02-06-2014, 10:25 PM   #2337
Guatiao
Member#: 104264
Chapter/Region: PRSIC
2005 Impreza RS
So, after reading some 15-20 of the most recent posts of this thread, I gather than, besides getting a nice rumble sound, there is no other *real* benefit in getting a catback, am I right? I am looking for a few mods for my 05 RS (auto tranny), and this is one of the mods I have/ had in mind. Now, I'm not so sure I wanna do it first.
Options? Suggestions? Thanks in advance!
Guatiao is offline   Reply With Quote
Old 02-06-2014, 11:48 PM   #2338
Shecker141
Member#: 368756
2005 STI
Originally Posted by Guatiao View Post
So, after reading some 15-20 of the most recent posts of this thread, I gather than, besides getting a nice rumble sound, there is no other *real* benefit in getting a catback, am I right? I am looking for a few mods for my 05 RS (auto tranny), and this is one of the mods I have/ had in mind. Now, I'm not so sure I wanna do it first. Options? Suggestions? Thanks in advance!
I've got the same car except manual, I put on a magnaflow muffler and cut out the last cat and put in a resonator, it's loud, not raspy, and has an awesome rumble.
Shecker141 is offline   Reply With Quote
Old 02-21-2014, 11:43 PM   #2339
the5ifty
Member#: 382228
2007 Imp2.5i 98OBW2"
Obsidian Black
Originally Posted by wiUFsh View Post
Thanks to New England salty roads and my cars age it wasn't easy but here it is. It was well worth the effort. It sounds deeper at idle and through about 2,500 RPM and it's not too loud at all. I'm really enjoying it. It's way better than the odd whistle my muffler had before.
If anybody needs some info on the swap let me know. I took a bunch of other pictures.
I would love some more info/pictures about the swap if possible.
the5ifty is offline   Reply With Quote
Old 02-22-2014, 08:37 AM   #2340
wiUFsh
Member#: 296667
2015 WRX Premium 6MT
Galaxy Blue
Default 2006 Impreza 2.5i with STI Axle Back
As you wish. If anybody wants some more pictures of the install please feel free to PM me.
wiUFsh is offline   Reply With Quote
Old 03-04-2014, 01:49 AM   #2341
NY2VT
Member#: 122139
'16 Legacy,
15 Impreza & 05 Forester
subscribe.
NY2VT is offline   Reply With Quote
Old 03-04-2014, 08:40 AM   #2342
campanozzi
Member#: 336415
2011 Impreza limited
Just ordered a nameless muffled exhaust!
campanozzi is offline   Reply With Quote
Old 03-04-2014, 08:39 PM   #2343
Jsm93
Member#: 368551
02 Impreza rs2.5
Midnight black pearl
Buy a srs catback exhaust !!! Best sounding system our cars can get
When I bought mine it was a 250$... It's now 230$ not bad at all . Come with adapter pice as well . I don't have any rust on it all!!! And I live in pittsbrugh pa . Lots of salt and snow/ice
http://www.ebay.com/itm/SR-S-CATBACK...5b63b1&vxp=mtr
Jsm93 is offline   Reply With Quote
Old 03-04-2014, 09:21 PM   #2344
Shecker141
Member#: 368756
2005 STI
Originally Posted by Jsm93 View Post
Buy a srs catback exhaust !!! Best sounding system our cars can get When I bought mine it was a 250$... It's now 230$ not bad at all . Come with adapter pice as well . I don't have any rust on it all!!! And I live in pittsbrugh pa . Lots of salt and snow/ice http://www.ebay.com/itm/SR-S-CATBACK...5b63b1&vxp=mtr
and you need uel headers if you want a serious rumble.
Old 03-09-2014, 07:20 PM   #2345
jliveit
Member#: 377915
I have a 2006 2.5i impreza and I want to get a Stromung dual-tip axle-back and a Stromung Intermediate pipe. But on their website it only lists a mid pipe for 99-05 impreza's. I am guessing this won't just bolt right up to my down pipe/cat
jliveit is offline   Reply With Quote
Old 03-09-2014, 08:22 PM   #2346
amcn831
Member#: 235777
2000 RS BuRP
2007 2.5i CGM
The 06-07 has a different piping layout. You'd need a header and cat pipe for 99-05 to match. The axle back will work. The mid pipe is the issue. Too short I think?
Old 03-09-2014, 08:36 PM   #2347
jliveit
Member#: 377915
Yeah. Either that or they stopped making an '06-'07 mid pipe. Because this guy seems to have one. In his description it says "Stock headers and cat section, stromung midpipe and single-tip axle back."
Old 03-09-2014, 10:10 PM   #2348
amcn831
Member#: 235777
2000 RS BuRP
2007 2.5i CGM
Yeah. Either that or they stopped making an '06-'07 mid pipe. Because this guy seems to have one. In his description it says "Stock headers and cat section, stromung midpipe and single-tip axle back." Video Link: http://www.youtube.com/watch?v=fXyuE6zwCz0
Yes, they had it on their site a while back when I was looking at exhausts, that was long ago.
Old 03-10-2014, 06:16 PM   #2349
Jsm93
Member#: 368551
02 Impreza rs2.5
I'll post a vid or the srs cat back.. Soon
Old 03-29-2014, 08:16 AM   #2350
LSJOEY
Member#: 381482
2009 Impreza 2.5i Pr
I can get my hands on an earlier sti muffler. Anybody knows if it will fit/sound good on a 09 impreza wagon 2.5i?
LSJOEY is offline   Reply With Quote
****Official '80s Freestylin' thread****for the old guys!!! MyRad25rs Off-Topic 21 12-09-2011 10:39 PM
The Official "Things I Hate For No Good Reason" Thread. RaceCarRiot Off-Topic 109 02-14-2006 10:00 AM
The Official Pittsburgh's DILLIGAF Racing for Mod Thread Mancini Mid Atlantic Impreza Club -- MAIC 11 09-20-2005 10:29 PM
The official 2005 volleyball thread for NOVA slim speedy Mid Atlantic Impreza Club -- MAIC 57 04-12-2005 04:51 PM
The OFFICIAL no rain/snow for the learning curve thread Bart Mid West Subaru Owners Club Forum -- MWSOC 8 03-27-2003 02:22 PM
