Old 04-14-2003, 10:45 PM   #1
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Question Valve Cover Oil In/Outs
How hard would it be to modify a valve cover to use for oil in/outs like the one in the link below?
http://forcedairtech.com/FORCED-AIR-...-CONTENTS.html
seven881 is offline   Reply With Quote
Old 04-14-2003, 11:14 PM   #2
Hondaslayer
Brain Stew
Member#: 4562
1998 Forester,lifted
1975 VW Westfalia tin top
Dont be lazy,Do it right once,Tap the pan.
Old 04-14-2003, 11:26 PM   #3
seven881
Member#: 8828
01 BRP 2.2T Hybrid
hehe I already have a pan tapped, but does the valvel cover oil in/outs work better. That is the question.
Old 04-14-2003, 11:35 PM   #4
Hondaslayer
Brain Stew
Member#: 4562
My opinion is it is too tight of an angle and the possibility of oil backing up is greater.
Old 04-16-2003, 10:24 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
For a gravity fed turbo system, the greater height difference between the turbo and the oil return, the better. Some of the early Minnam turbo kits had almost a horizontal line going from the turbo to the oil pan and they were known to smoke the oil due to poor flow. You want a fat line and you want it to drop a ways to get clear of the turbo.
Unless your turbo sits very high, it wouldn't be as feasible to go to the valve cover. The oil pan gives you the best results and allows the froth to settle before going back through the engine. It is also goign to be putting the heat from the turbo into a reservoir, as opposed to right on your valvetrain.
-Jon
EJ257 Bits: Oil Feed Lines, Timing Covers, STI Valve Covers, Timing Gears,Oil Pan etc DSM_Outback Engine/Power/Exhaust 16 10-20-2009 01:01 PM
a lot of oil coming out valve cover breathers.... Jeff54 Normally Aspirated with bolt-on Forced Induction Powertrain 18 07-22-2008 11:21 PM
smoked during smog test (2500 rpm in neutral). Also oil on valve cover breather. rex n effect Service & Maintenance 0 04-20-2008 12:35 PM
Valve Cover Oil Leak Question MiamiLife Factory 2.0L Turbo Powertrain 1 03-25-2006 03:50 PM
Valve Cover Oil Leak whitet777 Service & Maintenance 10 07-28-2003 09:44 PM
Message Board Statistics All times are GMT -4. The time now is 08:35 PM.
