Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 04-14-2003, 11:43 PM   #1
stickygreen
Member#: 22175
Question Sti - 2.5RS
What are the difference between the 2.5RS engine and the Sti engine, besides the fact that the Sti has a turbo? Are the engine blocks basically the same and what about the heads??
stickygreen is offline
Old 04-15-2003, 12:37 AM   #2
Crawdads
Member#: 30907
SWP GDB-G
wow, cast iron pistons! And bored out too make 2.5l from 2.5l?
sorry man, i dont want to be a total ass, but that paragraph made no sense and was full of misinformation.
Having not read all the specific posts concerning the new motor, IIRC the new block will be semi closed deck design, the heads include have sodium filled valves for better heat transfer and variable valve timing.
Crawdads is offline
Old 04-15-2003, 12:40 AM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Oooh, more SCC disinformation.
I don't believe any of the major components are common with the 2.5 RS or Legacy (naturally aspirated) motors.
The STi 2.5 has unique: block, rods, crank, pistons, cams.
The heads are the AVCS 16v DOHC heads. The RS/Legacy etc use 16 v SOHC heads. Big difference.
Glenn
ANZAC_1915 is offline
Old 04-15-2003, 01:19 AM   #4
CloNeGTS
Member#: 23341
04 Rex STi
WRB/Gold
Where are you finding documentation on the STi engine? Anywhere public?
CloNeGTS is offline
Old 04-15-2003, 12:48 PM   #5
Jewbaru
Member#: 1994
2013 Impreza WRX
It was printed in SCC that the motor was a tweaked EJ25 from the RS, which like Glenn said, is wrong.
AFAIK, it's pretty much the EJ20 STi block, only worked to make more displacement (prolly different stroke/bore).
Jewbaru is offline
Old 04-19-2003, 01:23 AM   #6
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
It is similar to the block but there are some new and important differences.
It does sound like there is a lot in common with the 2.5 XT Forester and Baja turbo and the STi engine.
I suspect the revised block etc. was used in all of them.
I was reading a SCC on the newstand today and found even more errors (picture of 04 WRX interior labelled as STi, and they also said the DCCD uses a "clutch pack", which it doesn't).
So, my advice is to pretty much ignore anything you see in SCC.... or at the least the finer details.
For anyone who wants to know more about the mechanical part of the DCCD, I direct you to the Legacy H6/WRX Auto VTD documentation.
Glenn
Old 04-19-2003, 03:14 AM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I think this engines closest relative is the AVCS EJ25 in Japan, although the semi-closed block and special valve are aparently different I think the head design is simular. In my eyes, this engine is more of an emalgamation of various current EJ engines, most of which we dont have here in the states
Kostamojen is offline
Old 04-19-2003, 11:13 AM   #8
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
No, the block, crank, rods, pistons are all new modifications of current components.
Apart from heads etc, it is not a parts bin special.
Even the cams used in the heads are different (the metalurgy, don't know about the profile though).
I am not even sure it has an EJ designation.
Glenn
Old 04-20-2003, 12:45 AM   #9
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Well I dont mean "from the parts bin" I mean previous design ideas. The closed deck design and forged parts are obviously 22B related experiments, combined with new technology like the valves and drive by wire, combined with recent JDM AVCS and DOHC tech. The ideas were all there, just not all put into the EJ25 before.
Old 04-20-2003, 01:01 AM   #10
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
This is not an EJ25...
Old 04-20-2003, 02:15 AM   #11
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
As far as ive heard, its still the same dimensions as an EJ25 but with the semi-closed block and different material construction... Still the same dimensions and everything, so why not an EJ25?
Old 04-20-2003, 02:56 AM   #12
shirokuma
Member#: 5489
2013 FR-S
AVO Orange
I think we are running up against a dictionary definition of "all new" vs. "evolutionary".
The 2.5 turbo is an evolution of previous Subaru motors. In some ways it is definitely brand new - there was no 2.5-litre turbo factory motor before. In some ways it's merely evolutionary - much of the design isn't going to differ greatly from previous designs used in their flat fours.
Technically, the current JDM 2.0-turbo isn't terribly different from the original, hand-made motors in the Ver. 0 STi's. However, it's obvious nearly everything has evolved and been tweaked since then.
Base line - the 2.5 turbo motor is not a "tweaked" 2.5 NA motor. It certainly is related to it, but then, Whoopi Goldberg and Halle Berry's physical makeup also may technically be 90% the same, but it's the other 10% that makes a world of difference.
Cheers,
Paul Hansen
www.apexjapan.com
shirokuma is offline
Old 04-20-2003, 11:00 AM   #13
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I'll take Halle Berry.
Old 04-20-2003, 07:55 PM   #14
gills
Member#: 11316
1988 E30 M3
S54
Ha! are you kidding?!? Whoopi Goldberg is a friggin' alien!!!
gills is offline
FS: Greddy Evo2 Catback WRX STi 2.5rs kokob NWIC Private Classifieds 4 03-25-2009 07:35 PM
FS: NEW STi/2.5RS OEM Front and Rear Bumpers conoval21 1993 - 2001 Impreza Specific Parts 4 02-18-2008 11:10 AM
So Cal: FS Brand New Sealed H&R Coilvers For WRX, STI, 2.5RS Impreza ichibausa Suspension/Brakes/Handling 8 10-23-2006 01:42 AM
05+ wrx/sti/2.5RS manual shifter trim silver-RS Private 'Wanted' Classifieds 0 09-25-2006 05:56 PM
white sti 2.5rs w/ 22b engine swap in austin......... finksta Texas Impreza Club Forum -- TXIC 14 05-23-2001 11:06 AM
