Old 04-12-2003, 10:56 PM   #1
obyone
Member#: 16523
Default Need some CEL code info.
OK...This is the code I pulled from my 00 RS with a ProECM, MRT header back, and Cobb Intake.
P0136 - O2 sensor Circuit malfunction bank 1 sensor 2.
Freeze frame data
Fuel System 1 - Closed Loop
Fuel system 2 - not supported
Load value - 18.8%
Coolant temp - 181F
Short term fuel trim 1 - 1.5%
Long term fuel trim 1 - 4.6%
Map sensor - 14 in.hg
Engine RPM - 2827rpm
Vehicle speed - 44mph
Now I was expecting a cat efficiency code, becuase of my header, but got this instead. So.......what does it mean?
obyone is offline   Reply With Quote
Old 04-13-2003, 12:34 AM   #2
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
I'd say clear it, and see if it comes back.
If it follows you home again, might be worth purchasing a new O2 sensor.
Only thing I can think of might be something with the wires, or maybe how it's connected to the ECU. If it's a "circuit" malfunction, it might not be the sensor itself, but it's hard to say. Check your wiring (if you've touched it at all before) and make sure the sensor is still securely plugged in. Otherwise, I'm outta ideas.
AJ
AJ711 is offline   Reply With Quote
Old 04-14-2003, 09:34 PM   #3
obyone
Member#: 16523
any other suggestions? Just want to cover all basis.
Old 04-15-2003, 03:25 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
well either your A/F sensor is screwed or you are losing too much heat thru the headers and it should read slow response.
Jeremy
HndaTch627 is offline   Reply With Quote
Need a CEL code pulled? Look in here for people to PM for help! Penphoe Vancouver Impreza Club Forum -- VIC 10 11-22-2008 11:10 AM
Some simple hybrid EJ questions. Need some help and info mranlet Built Motor Discussion 0 06-25-2008 08:31 AM
after swap some CEL codes vipergtrdj Subaru Conversions 0 10-17-2007 04:43 PM
Need a CEL code pulled smokey25 Vancouver Impreza Club Forum -- VIC 17 03-21-2007 05:29 AM
I need a CEL code identified Travis Graham Service & Maintenance 4 03-10-2006 05:25 PM
